How to make the data - which is transferred from host program to GPU (using cudaMemcpy function) memory- to be accessed in different cuda kernel calls at different intervals of program execution.
Is it possible?
Is it possible?
You can make two calls.
kernel01<<<>>>(din,dout)
kernel01<<<>>>(dout,dmoret)
Assuming - dout is an array of integers.
kernel01<<<>>>(din,dout) - In this cuda kernel definition, if some operation performed on dout array inside CUDA and values are modified, then in the next kernel call:
kernel02<<<>>>(dout, dmoret) - will it continue to take the modified values or will it take a original values.
Modified ones.
