I am using a routine to transfer data from a CUDA context to an opengl display routine. With some debugging, I have found that the data becomes clamped between 0 and 1 before reaching my display routine. The display routine works in a pure opengl environment with unclamped data, so I am sure that it is not the cause of the problem I am seeing.
The code I use to do the display is shown below:
// Setup
GLuint cuda_opengl_bridge;
GLuint display_texture;
float* cuda_mem;
glGenBuffers(1, &cuda_opengl_bridge);
glBindBuffer(GL_ARRAY_BUFFER, cuda_opengl_bridge);
// buffer data
int display_size = . . .;
void* data = malloc(display_size);
glBufferData(GL_ARRAY_BUFFER, display_size, data, GL_DYNAMIC_DRAW);
free(data);
glBindBuffer(GL_ARRAY_BUFFER, 0);
glGenTextures(1,&display_texture);
glBindTexture(GL_TEXTURE_RECTANGLE_NV,display_texture);
glTexImage2D(GL_TEXTURE_RECTANGLE_NV,0,FLOAT_RGBA32,width/2,height/2,0,GL_RGBA,GL_FLOAT,NULL);
// Display
float* transfer_data;
cudaGLRegisterBufferObject(cuda_opengl_bridge);
cudaGLMapBufferObject((void**)&transfer_data, cuda_opengl_bridge);
// cuda routine that reorders the data in cuda_mem, copying to transfer_data
pack_for_display(transfer_data, cuda_mem);
// Data is clamped somewhere between here . . .
cudaGLUnmapBufferObject(cuda_opengl_bridge);
cudaGLUnregisterBufferObject(cuda_opengl_bridge);
glBindBuffer(GL_PIXEL_UNPACK_BUFFER_EXT, cuda_opengl_bridge);
glTexSubImage2D(GL_TEXTURE_RECTANGLE_NV, 0, 0, 0, width, height, GL_RGBA, GL_FLOAT, NULL);
glBindBuffer(GL_PIXEL_UNPACK_BUFFER_EXT, 0);
// and here . . .
// my display routine
show(display_texture);
Please excuse any simple syntactic errors with the above, as I had to cut this down a bit from the real source. Any thoughts?
after texture creation solved my issue. Is the above clamping mode set somwhere by default? The document you referenced seemed to indicate otherwise:
To rebut that, however, clearing it once after texture creation solved the issue, so I am sure that I am not inadvertently setting it after that point. I don’t use that call anywhere else; do any other common functions set this as a side effect? Thanks for your help/insight.
Are you sure the internal tex format is correct? What is the FLOAT_RGBA32 value? I expect some GL_ constant here. As you use texRect this should be GL_FLOAT_RGBA32_NV (= 0x888b)
You are mixing the GL_NV_float_buffer and the GL_ARB_texture_float extension. If you use the GL_TEXTURE_RECTANGLE_NV target, you have to use GL_FLOAT_RGBA32_NV. For GL_RGBA32F_ARB format, you need a GL_TEXTURE_2D target.
