data movement time
I use pgfortran v10.3 to compile and run my code, and find that it is much slower than the serial version.
I just had a chance to access to a computer with v10.9 on it, and found that there is a big difference regarding the data movement time.
The structure of my code is:
!$acc data region
do time-loop
!$acc region
   do i-loop
!$acc end region
!$acc region
   do j-loop
!$acc end region
!$acc updateout(a)
 do k-loop   ! k-loop on CPU
!$acc updatein(b)
!$acc region
   do l-loop
!$acc end region
end do ! time-loop
!$acc end data region
v10.9:
57: region entered 1 time
        time(us): total=799971 init=693804 region=106167
                      data=15816
        w/o init: total=106167 max=106167 min=106167 avg=106167
v10.3
        time(us): total=50128612 init=60125 region=50068487
                  kernels=34054 data=50034433
where line 57 is the line of “!$acc data region”
The time spent in data movement using v10.3 is much longer than that using v10.9.
I was wondering if there is any problem with v10.3 to parallelize code with the structure as I showed above.
Hi WENYANG LIU,
It’s actually not a problem with the data movement. Rather in 10.3 the data movement times reported by the profiler are incorrect when using data regions. This has since been corrected.
  • Mat
