Data sharing between c++ and CUDA programs
I have a c++ file that captures images and converts them to a usable 2D matrix, and I have a separate CUDA file that uses the cuFFT library to perform fourier transforms on the GPU. I would like to compile these into a single file, but I am not sure how to ‘call’ and utilize the CUDA program to perform the fft on the image captured from the c++ program. I am aware of the cudaMemCpy() functions that will transfer data between the host and device, but I am not sure if this is the correct way to share variables and data between separate files. Is there possibly a way to define a function in the CUDA file to be called in the c++ program? Any insight appreciated.
cudaMemCpy() is correct.
A basic cuda program will be:
  1. copy data from cpu to gpu
  2. execute gpu kernel code
  3. copy results from gpu back to cpu
Here is a tutorial: http://www.nvidia.com/docs/io/116711/sc11-cuda-c-basics.pdf#9
In advanced,
You can use unified memory to avoid memory copy since cpu and gpu share same memory on Tegra.
But you should modify your camera driver to output um format memory.
Details: http://docs.nvidia.com/cuda/cuda-c-programming-guide/index.html#um-unified-memory-programming-hd
