Data sharing between lib gstdsexample and deepstream_app_main.c
I am using deepstream_app for my object detection.
I do some processing for detected boxes in gst-dsexample.cpp.
gst-dsexample is plugin to deepstream_app at the last stage.
So if I want to highlight with different color using obj->rect_params, the color is not updated in display.
So I need to share globaldata between the two source files, gstdsexample.cpp and deepstream_app_main.c
The globaldata is bounding box id (identified by my customized identification code in gstdsexample.cpp) and will be shared to deepstream_app_main.c to highlight with different color using obj->rect_params in all_bbox_generated() inside deepstream_app_main.c.
What I did was
sharedata.h (global variables pointerto hold BBOx id)
#ifndef __SHARE_DATA_H__
#define __SHARE_DATA_H__
#include <stdio.h>
#include <pthread.h>
#ifdef __cplusplus
extern "C" {
#endif
// declare your two vars in the header file as extern.
extern pthread_mutex_t mutex;
extern int *ptr;
#ifdef __cplusplus
#endif
#endif /* __SHARE_DATA_H__ */
deepstream_app_main.c has malloc and reading data from pointer.
#include "sharedata.h"
int all_bbox_generated(){
 pthread_mutex_lock( &mutex );
  for (int x = 0; x < 5; x++)
    printf("%d ", *(ptr+x));
  printf("\n");
  pthread_mutex_unlock( &mutex );
int main(){
  ptr = (int *)malloc((4 * 5) * sizeof(int));
Inside gstdsexample.cpp,
pthread_mutex_t mutex = PTHREAD_MUTEX_INITIALIZER;
int *ptr;
   printf("before lock\n");
      printf("before pointer\n");
      *(ptr+x) = 1;
I can compile and build libgstdsexample.
But I have undefined reference error for ptr and mutex in compilation at deepstrea-app.
How can I solve?
• DeepStream Version
• TensorRT Version
Xavier
5.1 (latest)
R32 (release), REVISION: 4.3, GCID: 21589087, BOARD: t186ref, EABI: aarch64, DATE: Fri Jun 26 04:34:27 UTC 2020
• TensorRT Version
latest
10.2
Can reproduce using gstdsexample.cpp, deepstream_app_main.c and
sharedata.h
#include <stdio.h>
#ifdef __cplusplus
extern "C" {
#endif
extern int *ptr;
#ifdef __cplusplus
#endif
I know sharing global variables is not a good practice.
For my requirement, what could be good approach?
My main project is deepstream-app.
I am doing my own illegal parking detection using Bboxes in gstdsexample.cpp.
Once those boxes are identified, I need to highlight on display.
Since gstdsexample is plugged in from last stage in deepstream-app,
Changing the color of box to highlight using obj->rect_params doesn’t change color of box on actual display.
So in that case, how can I do to change color of box in display?
May I have suggestion on this?
Suppose nvdsosd will take those parameter and draw rect on video.
https://docs.nvidia.com/metropolis/deepstream/dev-guide/text/DS_plugin_gst-nvdsosd.html
Yes from gstdsexample, how to send those box information to gst-nvdosd?
There is no update for a period, assuming this is not an issue any more.
What is the status here? Is there still any issue?
