In giexec.cpp, the createMemory function, this lines means it will always create the same size when using half2 or int8 mode.
“size_t eltCount = dimensions.c()*dimensions.h()*dimensions.w()*gParams.batchSize, memSize = eltCount * sizeof(float);”
When using int8 mode, should it create a samller size, such as “size_t eltCount = dimensions.c()*dimensions.h()*dimensions.w()*gParams.batchSize, memSize = eltCount * sizeof(char);”
