Hello there, is there a way to get the memory transfer metrics between DLA and the system memory?
Thanks in advance.
Thanks in advance.
Do you want to use DLA with TensorRT?
If yes, do you want a bandwidth test for GPU ↔ CPU memory?
/usr/local/cuda-10.2/samples/1_Utilities/bandwidthTest
Yes, I use DLA with TensorRT, so I want to capture the system memory read/write bytes caused by DLA.
I saw the bandwidthTest
file that you provided, where device
means GPU (not equal to DLA) and host
means CPU, no clues on how to test for DLA <-> CPU.
Therefore, my only question is:
How to get memory read/write bytes for DLA <-> CPU?
Since only TensorRT can deploy a task on DLA, we don’t have a sample that only measure the bandwidth.
Sorry for the inconvenience.
