Hello! I am searching a fast way to forward data from NIC to HOST via PCI-e. Can you give me some recipe please?
Hi Yuri,
Can you please elaborate on what exactly you are trying to achieve and provide detailed information on your requirement to assist in best possible way. In addition, do you already have our NIC’s or you are looking for purchase based on the response for your desired requirement/question? If you already have our HCA, please provide the details about the HCA along with details on your requirement.
Thanks,
Namrata.
Hi, Namrata!
NIC is Bluefield MBF1M332A-ASNA_Ax PSID: MT_0000000229
We are trying to forward data from application on the board to application on the host via PCIe bus. What is the best way to do it? Also we are searching the way to simply connect the socket apllications on both sides via PCIe. Should we use OFED stack?
Thank you
Hi Yuri,
It would be great if you could address this issue by opening a support case. You may send an email to supportadmin@mellanox.com to open a case.
Thanks,
Namrata.
