Please share your latest error and the command which will run into this error.
It is the same error -
Can you share the result of $nvidia-smi ?
NVIDIA-SMI has failed because it couldn’t communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
Please restart the wsl.
$ sudo reboot
Can’t reboot
Error -
System has not been booted with systemd as init system (PID 1). Can’t operate.
Failed to connect to bus: Host is down
Failed to talk to init daemon.
I shutdown the wsl by running
wsl --shutdown in command shell
but nvidia-smi is still showing the same prompt
Still showing the same error - – nvdia-smi
That’s not expected. Need to make nvdia-smi work in wsl. Please try to search something and double check WSL setup.
Evertything is working fine now! Thanks a lott.
