Hi, I’m training detectnet_v2 in order to recognize vehicle.
My dataset comes from some video that have been labeled. When I do the partition I do not want the random mode, else in test part there can be a vehicle already known from a precedent videoframe. I have to split the 6 minutes video into something like: 5 min for train, discard 15 sec for better separation, keep the last 45 sec for test.
I know that sequence mode requires a particular file, kitti_sequence_to_frames_file, but I didn’t find any documentation about how to configure it.
I tried something like this with tfrecord specs, one for train one for test:
kitti_config {
root_directory_path: "/workspace/tlt-experiments/210825/data/train"
image_dir_name: "images"
label_dir_name: "labels"
image_extension: ".png"
partition_mode: "sequence" # it needs kitti_sequence_to_frames_file
# partition_mode: "random"
num_partitions: 1 # use 2 to create train-valid partition.
val_split: 10
num_shards: 10
kitti_sequence_to_frames_file: "kstff.txt"
# For most cases, this will be the same as the root_directory_path. If
# for some reason the images are in a different directory, then
# the images will be dereferenced as
# image_directory_path/image_dir_name/<xxxx><image_extension>
image_directory_path: "/workspace/tlt-experiments/210825/data/train"
my directory is:
data - train - images
- labels
- kstff.txt
- test - images
- labels
- kstff.txt
kstff.txt contains just the fake string: “What do you need here?” Where can I find how to configure it?
The command is:
# Creating a new directory for the output tfrecords dump.
print("Converting Tfrecords for kitti trainval dataset")
!tlt-dataset-convert -d $SPECS_DIR/detectnet_v2_tfrecords_kitti_trainval_1.txt \
-o $DATA_DOWNLOAD_DIR/tfrecords/kitti_trainval_1/kitti_trainval
The output is:
2021-09-03 08:51:55.491859: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudart.so.10.0
Using TensorFlow backend.
2021-09-03 08:51:57,493 - iva.detectnet_v2.dataio.build_converter - INFO - Instantiating a kitti converter
File "/usr/local/bin/tlt-dataset-convert", line 8, in <module>
sys.exit(main())
File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/scripts/dataset_convert.py", line 63, in main
File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/dataio/build_converter.py", line 76, in build_converter
File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/dataio/kitti_converter_lib.py", line 101, in __init__
File "/home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/dataio/kitti_converter_lib.py", line 199, in _read_sequence_to_frames_file
File "/usr/lib/python3.6/json/__init__.py", line 299, in load
parse_constant=parse_constant, object_pairs_hook=object_pairs_hook, **kw)
File "/usr/lib/python3.6/json/__init__.py", line 354, in loads
return _default_decoder.decode(s)
File "/usr/lib/python3.6/json/decoder.py", line 339, in decode
obj, end = self.raw_decode(s, idx=_w(s, 0).end())
File "/usr/lib/python3.6/json/decoder.py", line 357, in raw_decode
raise JSONDecodeError("Expecting value", s, err.value) from None
json.decoder.JSONDecodeError: Expecting value: line 1 column 1 (char 0)
Thanks for any help!
