Datatype of metadata is the same with it of rawdata
My sensor can output 640480 rawdata, and 2480 metadata with data types 0x2c and 0x12, respectively.
I change the datatype of metadata from 0x12 to 0x2c through serdes and deserdes.
And I also change the device tree.
Is this approach feasible?
when I test it with v4l2 command
v4l2-ctl --set-fmt-video=width=640,height=482,pixelformat=RG12 --stream-mmap --set-ctrl=sensor_mode=0  -d /dev/video0
the dmesg shows below:
trace log:
trace.log (22.0 MB)
If this is feasible, please help to see what went wrong.Thanks!
The log tell short frame.
Check the size is modify correct by below command.
v4l2-ctl --list-formats-ext
Thanks for your quick reply.
pcai@pcai-desktop:~$ v4l2-ctl --list-formats-ext
ioctl: VIDIOC_ENUM_FMT
        Type: Video Capture
        [0]: 'RG12' (12-bit Bayer RGRG/GBGB)
                        Interval: Discrete 0.017s (60.000 fps)
The size is correct. Could you try report 640x480?
sorry, I can’t understand what you mean.
The trace log tells the receive less line than report.
Check the log by report the less height.
