DBscan on jetson nano
• Hardware Platform : Jetson Nano
• DeepStream Version: 5.1
• JetPack Version: 4.5.1
• TensorRT Version: 7.1.3-1+cuda10.2
• Issue Type: questions
• How to reproduce the issue: Not necessary
Is there any examples of using the DBScan Based Object Clustering API available? I can only find the minimal API documentation.
Or is there any other way I can use object clustering with a frame received from nvarguscamerasrc in an gstreamer plugin?
• TensorRT Version
Hi, I edited the original topic
@DaneLLL Do you have any hints for me?
There is implementation in nvinfer plugin. In config_infer_primary_nano.txt, you can set cluster mode = 1 to enable dbscan. May refer to
Gst-nvinfer — DeepStream 5.1 Release documentation
For demo code, please refer to source code of nvinfer plugin.
