We are configuring Mellanox ConnectX-5 EN adapters (MCX512A-ACU_Ax_Bx, device ID mt4119) for Azure Local RDMA compliance. The goal is to enable LLDP and IEEE DCBX negotiation for PFC/ETS using Mellanox firmware and Windows QoS.
Steps Taken:
Updated NIC firmware and Mellanox WinOF2 drivers.
Used
mlxconfig.exeto enable LLDP and IEEE DCBX:PowerShell
.\mlxconfig.exe -d mt4119_pciconf0 set LLDP_NB_DCBX_P1=1 LLDP_NB_RX_MODE_P1=ALL LLDP_NB_TX_MODE_P1=ALL DCBX_IEEE_P1=1 DCBX_CEE_P1=0 LLDP_NB_DCBX_P2=1 LLDP_NB_RX_MODE_P2=ALL LLDP_NB_TX_MODE_P2=ALL DCBX_IEEE_P2=1 DCBX_CEE_P2=0
Verified via
mlxconfig querythat LLDP/DCBX settings are active.
LLDP_NB_DCBX_P1 True(1)
LLDP_NB_RX_MODE_P1 ALL(2)
LLDP_NB_TX_MODE_P1 ALL(2)
LLDP_NB_DCBX_P2 True(1)
LLDP_NB_RX_MODE_P2 ALL(2)
LLDP_NB_TX_MODE_P2 ALL(2)
DCBX_IEEE_P1 True(1)
DCBX_CEE_P1 True(1)
DCBX_WILLING_P1 True(1)
DCBX_IEEE_P2 True(1)
DCBX_CEE_P2 True(1)
DCBX_WILLING_P2 True(1) -
Changed DcbxMode in Windows NIC advanced properties:
Initially set to Firmware in Charge (NIC negotiates with switch).
Changed netadapteradvancedproperties to Host in Charge for OS-level DCBX control
Verified via
Get-NetAdapterAdvancedPropertythat mode changed successfully.
Windows QoS was configured via network intents and verified.
Observed Issues:
When Firmware in Charge is active:
Get-NetAdapterQosshowsDcbxSupport:IEEE.-
Switch (Cisco Nexus 9k) IEEE is detected with show lldp dcbx interface E1/X
LLDP/DCBX TLVs appear inconsistent with Windows QoS settings.
When Host in Charge is active:
Get-NetAdapterQosshowsDcbxSupport: Noneinstead of IEEE. -
DCBX negotiation does not appear operational from Windows or Nexus perspective.
RDMA (
Get-NetAdapterRdma) is enabled, but PFC/ETS negotiation is unsuccessful on Nexus side. -
Need clarification on:
Correct mode for Azure Local (Firmware vs Host in Charge).
Why switch detects CIN when NIC is configured for IEEE.
Why Windows reports
DcbxSupport: Nonein Host in Charge mode.
Environment Details:
NIC: Mellanox ConnectX-5 EN (MCX512A-ACU_Ax_Bx)
Driver: 25.10.26965.0
OS: Windows Server 2025
Switch: Cisco Nexus 9k - NXOS: version 10.4(5)
Azure Local deployment scenario (SMB Direct RDMA required)
Expected Outcome:
NIC and switch negotiate IEEE DCBX successfully.
Windows reports
DcbxSupport: IEEEwhen Host in Charge is selected. -
RDMA and QoS settings align with Azure Local requirements (PFC on priority 3, ETS configured).
