I am having a problem with the example I see in VPI - Vision Programming Interface: DCF tracker. It seems that I cannot get the outMaxCorrelationResponses data from vpiSubmitDCFTrackerLocalizeBatch. It only produces the value 0.
Sample code below :
Tracking is working but cannot get data from max cor.
#include <opencv2/core.hpp>
#include <opencv2/features2d.hpp>
#include <opencv2/imgcodecs.hpp>
#include <opencv2/imgproc.hpp>
#include <opencv2/videoio.hpp>
#include <vpi/OpenCVInterop.hpp>
#include <vpi/Array.h>
#include <vpi/Image.h>
#include <vpi/Pyramid.h>
#include <vpi/Status.h>
#include <vpi/Stream.h>
#include <vpi/algo/ConvertImageFormat.h>
#include <vpi/algo/CropScaler.h>
#include <vpi/algo/DCFTracker.h>
#include <cmath>
#include <cstdio>
#include <cstring>
#include <fstream>
#include <iostream>
#include <list>
#include <map>
#include <numeric>
#include <optional>
#include <sstream>
#include <vector>
#include <opencv2/opencv.hpp>
#include <opencv2/highgui.hpp>
#define CHECK_STATUS(STMT) \
do \
VPIStatus status = (STMT); \
if (status != VPI_SUCCESS) \
char buffer[VPI_MAX_STATUS_MESSAGE_LENGTH]; \
vpiGetLastStatusMessage(buffer, sizeof(buffer)); \
std::ostringstream ss; \
ss << vpiStatusGetName(status) << ": " << buffer; \
throw std::runtime_error(ss.str()); \
} while (0);
namespace {
// Information about the target track.
struct TrackInfo
int idTarget;
cv::Scalar color;
bool enabled; // whether target is lost or not.
// idTarget -> info
using TargetTrackInfoMap = std::map<int, TrackInfo>;
// Stores information about a detected target.
struct DetectedTargetInfo
int idTarget;
VPIAxisAlignedBoundingBoxF32 bbox;
bool lostTrack() const
return bbox.width == 0 || bbox.height == 0;
// idTarget -> info
using DetectedTargetInfoMap = std::multimap<int, DetectedTargetInfo>;
VPIBackend ParseBackend(const std::string &str)
if (str == "cuda")
return VPI_BACKEND_CUDA;
else if (str == "pva")
return VPI_BACKEND_PVA;
else
throw std::runtime_error("Backend '" + str + "' not recognized, it must be either cuda or pva.");
// Opens the video given by its file name.
cv::VideoCapture ParseVideo(const std::string &fname)
cv::VideoCapture video;
if (!video.open(fname))
throw std::runtime_error("Can't open '" + fname + "'");
return video;
// Parse the target bounding boxes at the frame they show up.
DetectedTargetInfoMap ParseTargetInfoAtFrame(const std::string &fname)
std::ifstream in(fname);
if (!in)
DetectedTargetInfoMap out;
// For each bounding box,
int frame;
DetectedTargetInfo tinfo;
while (in >> tinfo.idTarget >> frame >> tinfo.bbox.left >> tinfo.bbox.top >> tinfo.bbox.width >> tinfo.bbox.height)
out.emplace(frame, tinfo);
return out;
// Returns random high-saturated colors.
cv::Scalar GetRandomColor(cv::RNG &rng)
std::vector<cv::Vec3b> color = {cv::Vec3b{(unsigned char)rng.uniform(0, 180), 255, 255}};
cvtColor(color, color, cv::COLOR_HSV2BGR);
return cv::Scalar(color[0][0], color[0][1], color[0][2], 255);
// Adds to 'targets' the new targets found in frame 'idxFrame'.
bool AddNewTargetsFromFrame(int idxFrame, DetectedTargetInfoMap &tgtInfos, TargetTrackInfoMap &trackInfo,
VPIArrayData &targets)
// Tries to add the new target in the slot of an existing target
// whose tracking was lost. If these no such targets, will append to the
// end of the array.
auto *pTarget = static_cast<VPIDCFTrackedBoundingBox *>(targets.buffer.aos.data);
const auto *tgtBegin = pTarget;
static cv::RNG rng(1);
// For all new targets in 'idxFrame',
auto tgtInfoRange = tgtInfos.equal_range(idxFrame);
for (auto it = tgtInfoRange.first; it != tgtInfoRange.second; ++it)
// If info indicates the target's track has finished,
if (it->second.lostTrack())
// skip it, we're only adding new targets here.
continue;
// If the corresponding target is enabled (i.e. is being tracked)
auto itTrackInfo = trackInfo.find(it->second.idTarget);
if (itTrackInfo != trackInfo.end() && itTrackInfo->second.enabled)
// also skip it
continue;
// @note: when an array is allocated, its content is filled with zeroes,
// up to its capacity. This implies that the state of the targets is lost.
static_assert(VPI_TRACKING_STATE_LOST == 0, "Unexpected value for lost state");
// Search for the first target whose tracking was lost.
while (pTarget->state != VPI_TRACKING_STATE_LOST && pTarget < tgtBegin + targets.buffer.aos.capacity)
++pTarget;
assert(pTarget < tgtBegin + targets.buffer.aos.capacity);
pTarget->bbox = it->second.bbox;
pTarget->state = VPI_TRACKING_STATE_NEW;
pTarget->seqIndex = 0;
// Reasonable defaults.
pTarget->filterLR = 0.075;
pTarget->filterChannelWeightsLR = 0.1;
// Is it the first time we're seeing this target?
if (itTrackInfo == trackInfo.end())
// Create a track info for it.
TrackInfo tinfo;
tinfo.idTarget = it->second.idTarget;
tinfo.color = GetRandomColor(rng);
tinfo.enabled = true;
itTrackInfo = trackInfo.emplace(tinfo.idTarget, tinfo).first;
else
// It's now enabled.
itTrackInfo->second.enabled = true;
pTarget->userData = &itTrackInfo->second;
++pTarget;
// Update the array size only if we've appended targets to the end of the array.
*targets.buffer.aos.sizePointer = std::max<int32_t>(*targets.buffer.aos.sizePointer, pTarget - tgtBegin);
assert(*targets.buffer.aos.sizePointer >= 0);
return true;
// Mark as lost the targets whose bounding box falls outside the frame area, or are deemed lost by the detector.
bool DetectTrackingLost(int idxFrame, DetectedTargetInfoMap &tgtInfos, VPIArrayData &targets, cv::Size frameSize)
// This is a simplistic method that isn't reliable in a robust tracker.
// A robust method needs to be implemented by the user.
bool atLeastOneLost = false;
// For all targets, back to front so that we can easily reduce array size if needed.
for (auto *pBeginTarget = static_cast<VPIDCFTrackedBoundingBox *>(targets.buffer.aos.data),
*pTarget = pBeginTarget + *targets.buffer.aos.sizePointer - 1;
pTarget >= pBeginTarget; --pTarget)
bool trackingLost = false;
// Is it a valid target but its bounding box isn't entirely inside the frame,
if (pTarget->state != VPI_TRACKING_STATE_LOST && (pTarget->bbox.left < 0 || pTarget->bbox.top < 0 ||
pTarget->bbox.left + pTarget->bbox.width > frameSize.width ||
pTarget->bbox.top + pTarget->bbox.height > frameSize.height))
// Consider its tracking to be lost.
trackingLost = true;
else
// Go through all target infos in current frame
for (auto itInfo = tgtInfoRange.first; itInfo != tgtInfoRange.second; ++itInfo)
// Is it the info of the current target, and the tracking is lost?
static_cast<const TrackInfo *>(pTarget->userData)->idTarget == itInfo->second.idTarget &&
itInfo->second.lostTrack())
// Flag it,
break;
if (trackingLost)
atLeastOneLost = true;
// Update the target state to reflect it.
pTarget->state = VPI_TRACKING_STATE_LOST;
static_cast<TrackInfo *>(pTarget->userData)->enabled = false;
assert(*targets.buffer.aos.sizePointer >= 1);
// If the target is at the end of the target array,
if (pTarget == pBeginTarget + *targets.buffer.aos.sizePointer - 1)
// We can reduce the array size to improve tracking processing times.
*targets.buffer.aos.sizePointer = -1;
return atLeastOneLost;
// Update target's bounding box with input from detector output.
bool RefineTracksAtFrame(int idxFrame, DetectedTargetInfoMap &tgtInfos, VPIArrayData &targets)
bool atLeastOneUpdated = false;
for (auto *pBeginTarget = static_cast<VPIDCFTrackedBoundingBox *>(targets.buffer.aos.data), *pTarget = pBeginTarget;
pTarget < pBeginTarget + *targets.buffer.aos.sizePointer; ++pTarget)
// If tracking is lost,
if (pTarget->state == VPI_TRACKING_STATE_LOST)
// there's nothing to refine.
continue;
bool found = false;
// For all targets in 'idxFrame',
// If info indicates the tracking is lost,
if (itInfo->second.lostTrack())
// skip it, we're only updating existing targets.
continue;
if ((pTarget->state == VPI_TRACKING_STATE_TRACKED || pTarget->state == VPI_TRACKING_STATE_SHADOW_TRACKED) &&
static_cast<const TrackInfo *>(pTarget->userData)->idTarget == itInfo->second.idTarget)
pTarget->bbox = itInfo->second.bbox;
found = true;
break;
if (found)
atLeastOneUpdated = true;
pTarget->state = VPI_TRACKING_STATE_TRACKED;
else if (pTarget->state == VPI_TRACKING_STATE_TRACKED)
pTarget->state = VPI_TRACKING_STATE_SHADOW_TRACKED;
return atLeastOneUpdated;
void DrawTargets(cv::Mat &frame, VPIArray targets)
VPIArrayData tgtData;
CHECK_STATUS(vpiArrayLockData(targets, VPI_LOCK_READ, VPI_ARRAY_BUFFER_HOST_AOS, &tgtData));
auto *ptgt = static_cast<VPIDCFTrackedBoundingBox *>(tgtData.buffer.aos.data);
int numObjs = *tgtData.buffer.aos.sizePointer;
for (int o = 0; o < numObjs; ++o, ++ptgt)
// Only draw objects that are not lost
if (ptgt->state == VPI_TRACKING_STATE_LOST)
continue;
auto &tinfo = *static_cast<TrackInfo *>(ptgt->userData);
rectangle(frame,
cv::Rect{(int)ptgt->bbox.left, (int)ptgt->bbox.top, (int)ptgt->bbox.width, (int)ptgt->bbox.height},
tinfo.color);
CHECK_STATUS(vpiArrayUnlock(targets));
void PreprocessFrame(VPIStream stream, const cv::Mat &in, VPIImage &wrapper, VPIImage out)
// Pre-process current frame
if (wrapper == NULL)
CHECK_STATUS(vpiImageCreateWrapperOpenCVMat(in, 0, &wrapper));
else
CHECK_STATUS(vpiImageSetWrappedOpenCVMat(wrapper, in));
CHECK_STATUS(vpiSubmitConvertImageFormat(stream, VPI_BACKEND_CUDA, wrapper, out, NULL));
} // namespace
int main(int argc, char *argv[])
VPIPayload cropScale = NULL;
VPIPayload dcf = NULL;
VPIStream stream = NULL;
VPIArray inTargets = NULL, outTargets = NULL,outMaxCorrelationResponses = NULL;
VPIImage tgtPatches = NULL;
VPIImage frame = NULL, t = NULL;
VPIImage wrappedOCVFrame = NULL;
int retval = 0;
try
// Command line argument processing
// if (argc != 4)
// throw std::runtime_error(std::string("Usage: ") + argv[0] + " <pva|cuda> <input_video> <bbox descr>");
argv[1] = "cuda";
argv[2] = "/home/sample.mp4";
argv[3] = "/home/sample.txt;
VPIBackend backend = ParseBackend(argv[1]); // ---> pva or cuda
cv::VideoCapture invid = ParseVideo(argv[2]);
DetectedTargetInfoMap targetInfoAtFrame = ParseTargetInfoAtFrame(argv[3]);
TargetTrackInfoMap trackInfo;
// Allocate all VPI resources needed
const int maxTrackedTargets = targetInfoAtFrame.size();
// Create the CropScale payload
CHECK_STATUS(vpiCreateCropScaler(backend,
1, // max number of sequences (only processing one video)
maxTrackedTargets, &cropScale));
// Configure and create the DCFTracker payload
VPIDCFTrackerCreationParams dcfInitParams;
CHECK_STATUS(vpiInitDCFTrackerCreationParams(&dcfInitParams));
VPIPayload dcf;
CHECK_STATUS(vpiCreateDCFTracker(backend,
maxTrackedTargets, &dcfInitParams, &dcf));
// Optionally user can retrieve the internal array that stores the channel weights and
// the maximum correlation response for each tracked target. These can be used, together
// with the correlation map, to decide whether tracking was lost or not.
// This is not being done in this sample, though.
VPIArray channelWeights;
int32_t numFeatureChannels
CHECK_STATUS(vpiDCFTrackerGetChannelWeights(dcf, &channelWeights, &numFeatureChannels));
// Create target arrays
VPIArray inTargets, outTargets;
CHECK_STATUS(vpiArrayCreate(maxTrackedTargets, VPI_ARRAY_TYPE_DCF_TRACKED_BOUNDING_BOX, 0, &inTargets));
CHECK_STATUS(vpiArrayCreate(maxTrackedTargets, VPI_ARRAY_TYPE_DCF_TRACKED_BOUNDING_BOX, 0, &outTargets));
CHECK_STATUS(vpiArrayCreate(maxTrackedTargets, VPI_ARRAY_TYPE_F32, 0, &outMaxCorrelationResponses));
// Create image that stores the targets' patches
const int tgtPatchSize = dcfInitParams.featurePatchSize * dcfInitParams.hogCellSize;
const VPIImageFormat tgtPatchFormat = backend == VPI_BACKEND_PVA
? VPI_IMAGE_FORMAT_RGB8p
: VPI_IMAGE_FORMAT_RGBA8; // use supported patch-format for backend
CHECK_STATUS(vpiImageCreate(tgtPatchSize, tgtPatchSize * maxTrackedTargets, tgtPatchFormat, 0, &tgtPatches));
// Create stream for processing
CHECK_STATUS(vpiStreamCreate(0, &stream));
// Create the image that stores the input frame
CHECK_STATUS(vpiImageCreate(invid.get(cv::CAP_PROP_FRAME_WIDTH), invid.get(cv::CAP_PROP_FRAME_HEIGHT),
VPI_IMAGE_FORMAT_RGBA8, 0, &frame));
// Target tracking
int curFrame = 0;
// Populate the targets array with targets found the first frame.
VPIArrayData corData;
CHECK_STATUS(vpiArrayLockData(inTargets, VPI_LOCK_READ_WRITE, VPI_ARRAY_BUFFER_HOST_AOS, &tgtData));
CHECK_STATUS(vpiArrayLockData(outMaxCorrelationResponses, VPI_LOCK_READ_WRITE, VPI_ARRAY_BUFFER_HOST_AOS, &corData));
try
AddNewTargetsFromFrame(curFrame, targetInfoAtFrame, trackInfo, tgtData);
catch (...)
CHECK_STATUS(vpiArrayUnlock(inTargets));
CHECK_STATUS(vpiArrayUnlock(outMaxCorrelationResponses));
throw;
// For each input frame,
cv::Mat cvFrame;
VPIArrayData outCor;
while (invid.read(cvFrame))
auto start_time = std::chrono::steady_clock::now();
// printf("Frame %d\n", curFrame);
// Transform the opencv frame (cvFrame) into a suitable VPIImage (frame).
PreprocessFrame(stream, cvFrame, wrappedOCVFrame, frame);
// Crop the targets from the current frame using their bbox from previous iteration,
// then rescale them into tgtPatches.
CHECK_STATUS(vpiSubmitCropScalerBatch(stream, 0, cropScale, &frame, 1, inTargets, tgtPatchSize,
tgtPatchSize, tgtPatches));
// If we're in the first frame,
VPIArray targets;
if (curFrame == 0)
// The targets are simply the ones found.
targets = inTargets;
else
// Localize and refine current targets' bbox in the current frame.
CHECK_STATUS(vpiSubmitDCFTrackerLocalizeBatch(stream, 0, dcf, NULL, 0, // process all sequences
NULL, // feature masking window (not needed)
tgtPatches, inTargets, outTargets,
NULL, // outCorrelationResponses (not needed)
outMaxCorrelationResponses, // outMaxCorrelationResponses (not needed)
NULL)); // algorithm knobs (use defaults)
targets = outTargets;
// Assuming you have maxTrackedTargets as the number of tracked targets
VPIArrayData outMaxCorrelationResponsesData;
CHECK_STATUS(vpiArrayLockData(outMaxCorrelationResponses, VPI_LOCK_READ, VPI_ARRAY_BUFFER_HOST_AOS, &outMaxCorrelationResponsesData));
auto *pCorValues = reinterpret_cast<float *>(outMaxCorrelationResponsesData.buffer.aos.data);
std::cout<<*pCorValues<<"\n";
// Custom target update
// At this point some other additional processing can be done,
// such as target lifetime management and bounding box refinement.
// It typically uses information from 'outMaxCorrelationResponses',
// 'outCorrelationResponses' and/or 'channelWeights'.
// Since this processing is usually time consuming,
// it is usually performed once every few frames.
// Since we're updating the target arrays on host, we need to synchronize the stream.
CHECK_STATUS(vpiStreamSync(stream));
// Target patches must be updated if the corresponding target is new, or its bounding
// box was refined.
bool mustUpdateTargetPatches = false;
CHECK_STATUS(vpiArrayLockData(targets, VPI_LOCK_READ_WRITE, VPI_ARRAY_BUFFER_HOST_AOS, &tgtData));
try
// These functions update the target array based on the
// output of a object detector on the current frame. This
// detector is responsible for associating the detected
// objects with the corresponding existing target (if
// possible).
// Based on this information, the functions update the
// object lifetime (whether the object is new or tracking
// was lost), and also update its bounding box and state.
// For this sample application, the detection and
// reassociation is hardcoded in 'targetInfoAtFrame'. For
// production-level quality, a robust and generic solution
// needs to be implemented by the user.
// Note: Target update implemented in three separate
// functions for exposition purposes only.
// Detect whether a target tracking was lost and update tgtData accordingly.
DetectTrackingLost(curFrame, targetInfoAtFrame, tgtData, cv::Size{cvFrame.cols, cvFrame.rows});
// Target bounding box refinement
mustUpdateTargetPatches |= RefineTracksAtFrame(curFrame, targetInfoAtFrame, tgtData);
// Detect whether new targets are found in the current frame.
mustUpdateTargetPatches |= AddNewTargetsFromFrame(curFrame, targetInfoAtFrame, trackInfo, tgtData);
catch (...)
throw;
if (mustUpdateTargetPatches)
// Crop+rescale updated targets and copy them into tgtPatches.
CHECK_STATUS(vpiSubmitCropScalerBatch(stream, 0, cropScale, &frame, 1, targets, tgtPatchSize,
// Update the targets' internal metadata given their new bounding box.
CHECK_STATUS(vpiSubmitDCFTrackerUpdateBatch(stream, 0, dcf, nullptr, 0, // process all sequences
NULL, // featureMaskingWindow (not needed)
NULL, // modelMaskingWindow (not needed)
tgtPatches, targets,
// Wait for frame processing to finish
// Write frame to disk
DrawTargets(cvFrame, targets);
cv::imshow("cvFrame",cvFrame);
cv::waitKey(1);
auto end_time = std::chrono::steady_clock::now();
std::chrono::duration<double> frame_duration = end_time - start_time;
double fps = 1 / frame_duration.count();
std::cout << "FPS: " << fps << std::endl;
// Ping-pong the target arrays:
// Updated targets in this iteration will be input to the next iteration (inTargets),
// while current input will store the updated targets.
std::swap(inTargets, targets);
++curFrame;
catch (std::exception &e)
std::cerr << e.what() << std::endl;
retval = 1;
// Destroy all VPI resources
vpiStreamDestroy(stream);
vpiPayloadDestroy(cropScale);
vpiPayloadDestroy(dcf);
vpiArrayDestroy(inTargets);
vpiArrayDestroy(outTargets);
vpiImageDestroy(tgtPatches);
vpiImageDestroy(frame);
vpiImageDestroy(wrappedOCVFrame);
return retval;
Does the same issue also occur with the default sample and videos?
./vpi_sample_19_dcf_tracker cuda ../assets/pedestrians.mp4 ../assets/pedestrians_bboxes.txt
When I run it without making any changes, it works as expected.
The resulting outCorrelationResponses only gives 0. But the track continues.
Any updates ?
Sorry for the late update.
It looks like our default sample doesn’t take care of the outCorrelationResponses (feed NULL instead).
It is optional information so the tracking can still continue without issue.
Tracker’s correlation result needs to exceed a threshold to be considered successful. Can the threshold be managed without knowing the outCorrelationResponses value?
For example, if I want to use a higher threshold and accept only high matching tracks as correct, how should I proceed?
Any updates?
We will check this with our internal team and provide more info to you.
Hello, any updates ?
You should be able to get the outMaxCorrelationResponses and outCorrelationResponses information from the DCF tracker.
Please note that our sample demonstrates a simplistic tracking pipeline.
Proper object lifetime management and bounding box refinement are required for production-grade tracking quality.
Based on your implementation, you try to read the data before the tracker task finishes.
As vpiSubmitDCFTrackerLocalizeBatch is a nonblocking call, the data might not be ready yet when you lock the buffer.
Please move the synchronization before the array lock/unlock to make sure all the data is calculated.
vpiStreamSync and changing buffer type solved the problem.
Thank you for interest.
