DCF tracker significantly faster than KLT
• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version 5.1
• TensorRT Version 7.2
• NVIDIA GPU Driver Version (valid for GPU only) 460.80
• Issue Type( questions, new requirements, bugs) Question
When using the peoplenet model with the default deepstream_app_source1_peoplenet.txt and DCF enabled, we see that the DCF tracker setting has an FPS at least 2x that of the KLT tracker on a single stream. Based on the information provided on the relative performance at the below link, we would expect it to be the other way around and KLT to be much higher performance. What could be the reason for this difference?
https://docs.nvidia.com/metropolis/deepstream/dev-guide/text/DS_FAQ.html#what-trackers-are-included-in-deepstream-and-which-one-should-i-choose-for-my-application
KLT configuration (default):
[tracker]
enable=1
tracker-width=640
tracker-height=384
# C-AIQ: uncomment .so below depending on which tracker to use
#ll-lib-file=/opt/nvidia/deepstream/deepstream-5.1/lib/libnvds_mot_iou.so
#ll-lib-file=/opt/nvidia/deepstream/deepstream-5.1/lib/libnvds_nvdcf.so
ll-lib-file=/opt/nvidia/deepstream/deepstream-5.1/lib/libnvds_mot_klt.so
#ll-config-file required for DCF/IOU only
ll-config-file=/opt/nvidia/deepstream/deepstream-5.1/samples/configs/deepstream-app/tracker_config.yml
#ll-config-file=iou_config.txt
gpu-id=0
#enable-batch-process applicable to DCF only
enable-batch-process=1
DCF configuration:
[tracker]
enable=1
tracker-width=640
tracker-height=384
# C-AIQ: uncomment .so and config below depending on which tracker to use
gpu-id=0
KLT use CPU to implement the algorithm however NVDCF using GPU Gst-nvtracker — DeepStream 6.1.1 Release documentation
Thanks for the reply! That potentially makes sense, but that same link explicitly says that DCF is “Slower than KLT and IOU due to increased computational complexity.” If DCF is faster and more accurate than KLT, what is the use case for KLT?
Hey customer, I think that should depend on your use case, assume your detector occupies more GPU, then I don’t think NvDCF will still faster than KLT. So you should evaluate the whole pipeline and the HW resource to decide which Tracker you should use.
Good to know, thank you!
