DCGM 4.7.0 reports Power Health Warning on one L40S but Healthy on identical GPU in same TensorFlow process
Hello
Sorry if this not the right category
I am running on Rocky Linux 8.10 on a server with 2 GPU L40S and CUDA 13.4 . I have created a slurm job which is like this
GROUP_ID=$(echo “$GROUP_OUT” | sed -nE ‘s/.group ID of ([0-9]+)./\1/p’)
echo “Created DCGM Group ID: GROUP_ID”
echo $GROUP_ID
dcgmi group -g “$GROUP_ID” gpu:0,gpu:1
dcgmi stats -g “$GROUP_ID” --enable
dcgmi stats --jstart $SLURM_JOB_ID
test2gpu.py # My tensorflow python using 2 GPUS
dcgmi stats --jstop $SLURM_JOB_ID
dcgmi stats --job $SLURM_JOB_ID -v
dcgmi stats -jremove $SLURM_JOB_ID
dcgmi group -d “$GROUP_ID”
When i see the output i get the following
TensorFlow version: 2.21.0
GPUs detected: [PhysicalDevice(name=‘/physical_device:GPU:0’, device_type=‘GPU’), PhysicalDevice(name=‘/physical_device:GPU:1’, device_type=‘GPU’)]
Number of replicas: 2
Starting 2-GPU workload…
Iteration 0
Iteration 10
Iteration 20
Iteration 30
Iteration 40
Iteration 50
Iteration 60
Iteration 70
Iteration 80
Iteration 90
Iteration 100
Iteration 110
Iteration 120
Iteration 130
Iteration 140
Iteration 150
Iteration 160
Iteration 170
Iteration 180
Iteration 190
Iteration 200
Iteration 210
Iteration 220
Iteration 230
Iteration 240
Iteration 250
Iteration 260
Iteration 270
Iteration 280
Iteration 290
Finished in 45.22 seconds
Successfully stopped recording stats for 4449825.
Successfully retrieved statistics for job: 4449825.
| GPU ID: 0 |
|----- Execution Stats ------------±----------------------------------------|
| Start Time | Wed Oct 7 15:54:45 2026 |
| End Time | Wed Oct 7 15:56:41 2026 |
| Total Execution Time (sec) | 115.94 |
| No. of Processes | 17 |
±---- Performance Stats ----------±----------------------------------------+
| Energy Consumed (Joules) | 5207 |
| Power Usage (Watts) | Avg: 79.7733, Max: 134.674, Min: 35.435 |
| Max GPU Memory Used (bytes) | 1535115264 |
| SM Clock (MHz) | Avg: 1365, Max: 2520, Min: 210 |
| Memory Clock (MHz) | Avg: 4703, Max: 9001, Min: 405 |
| SM Utilization (%) | Avg: 11, Max: 34, Min: 0 |
| Memory Utilization (%) | Avg: 2, Max: 6, Min: 0 |
| PCIe Rx Bandwidth (megabytes) | Avg: N/A, Max: N/A, Min: N/A |
| PCIe Tx Bandwidth (megabytes) | Avg: N/A, Max: N/A, Min: N/A |
±---- Event Stats ----------------±----------------------------------------+
| Single Bit ECC Errors | 0 |
| Double Bit ECC Errors | 0 |
| PCIe Replay Warnings | 0 |
| Critical XID Errors | 0 |
±---- Slowdown Stats -------------±----------------------------------------+
| Due to - Power (%) | 601.342 |
| - Thermal (%) | 0 |
| - Reliability (%) | Not Supported |
| - Board Limit (%) | Not Supported |
| - Low Utilization (%) | Not Supported |
| - Sync Boost (%) | 0 |
±- Compute Process Utilization —±----------------------------------------+
| PID | 878083 |
| Avg SM Utilization (%) | 24 |
| Avg Memory Utilization (%) | 3 |
±- Graphics Process Utilization —±----------------------------------------+
| PID | 0 |
| Avg SM Utilization (%) | Not Found |
| Avg Memory Utilization (%) | Not Found |
| PID | 0 |
| PID | 0 |
| PID | 0 |
| PID | 0 |
| PID | 0 |
| PID | 0 |
| PID | 0 |
| PID | 0 |
| PID | 0 |
| PID | 0 |
| PID | 0 |
| PID | 0 |
| PID | 0 |
| PID | 0 |
| PID | 0 |
±---- Overall Health -------------±----------------------------------------+
| Overall Health | Warning |
| Power Health | Warning |
| GPU ID: 1 |
| Energy Consumed (Joules) | 7303 |
| Power Usage (Watts) | Avg: 75.4373, Max: 124.966, Min: 34.308 |
| SM Utilization (%) | Avg: 6, Max: 17, Min: 0 |
| Memory Utilization (%) | Avg: 3, Max: 6, Min: 0 |
| - Thermal (%) | 0 |
| PID | 878083 |
| Avg SM Utilization (%) | 13 |
| PID | 0 |
| PID | 0 |
| PID | 0 |
| PID | 0 |
| PID | 0 |
| PID | 0 |
| PID | 0 |
| PID | 0 |
| PID | 0 |
| PID | 0 |
| PID | 0 |
| PID | 0 |
| PID | 0 |
| PID | 0 |
| PID | 0 |
| PID | 0 |
| Overall Health | Healthy |
Why the dcgm is showing Warning for one GPU and other healthy when the power is only 135K max ? is there something i am doing wrong ?
It might beinteresting to know what happens if you can run 1 instance of the same job on each card in turn rather than at the same time. Will it complain on the same card but still not on the other? Not complain at all?
