I recently created a script to change the monitor input via the terminal using ddcutil. This allows me to switch between DP (computer) and HDMI (Switch 2), but the script sometimes fails. After some investigation, I discovered it might be an issue with the Nvidia driver regarding I2C; sometimes ddcutil “loses” the reference to the monitor I want to switch, causing the script to fail. I tested this by enabling my integrated AMD GPU, and the script didn’t fail a single time—in fact, the input switching was even faster. I searched the forum and found someone with a similar problem, though not exactly the same: the monitor appears in /dev/i2c-* but sometimes disappears. Does anyone have any idea what might be causing this?
Computer specs:
GPU: NVIDIA GeForce RTX 3060 Lite Hash Rate
Driver: 610.57.04
Kernel: Linux 7.1.8-1-cachyos
Here’s the script:
#!/bin/bash
DISPLAY_BUS=17
current=$(ddcutil -b "$DISPLAY_BUS" getvcp 0x60 | grep -oP 'sl=0x\K[0-9a-fA-F]+')
if [ -z "$current" ]; then
notify-send -a "Alternador" "Monitor" "Não foi possível detectar a entrada atual" -u critical
exit 1
fi
if [ "$current" == "01" ] || [ "$current" == "1" ]; then
target=0x03
target_name="DisplayPort (PC)"
else
target=0x01
target_name="HDMI (Switch)"
fi
for i in 1 2 3; do
if ddcutil -b "$DISPLAY_BUS" setvcp 0x60 "$target"; then
notify-send -a "Alternador" "Monitor" "Entrada alterada para $target_name"
exit 0
fi
sleep 0.5
done
notify-send -a "Alternador" "Monitor" "Falha ao trocar para $target_name" -u critical
exit 1
ddcutil detect --verbose:
Display 1
I2C bus: /dev/i2c-4
DRM_connector: card1-HDMI-A-1
/sys/class/drm/card1-HDMI-A-1/dpms On
/sys/class/drm/card1-HDMI-A-1/enabled enabled
/sys/class/drm/card1-HDMI-A-1/status connected
/sys/class/drm/card1-HDMI-A-1/connector_id 823
Driver: nvidia
I2C address 0x30 (EDID block#) present: false
EDID exists: true
I2C address 0x37 (DDC) responsive: true
Is LVDS or EDP display: false
Is laptop display by EDID: false
Is laptop display: false
/sys/bus/i2c/devices/i2c-4/name NVIDIA i2c adapter 5 at 1:00.0
PCI device path: /sys/devices/pci0000:00/0000:00:01.1/0000:01:00.0/i2c-4
EDID synopsis:
Mfg id: GSM - LG Electronics
Model: LG FULL HD
Product code: 23547 (0x5bfb)
Serial number:
Binary serial number: 220846 (0x00035eae)
Manufacture year: 2023, Week: 3
EDID version: 1.3
Extra descriptor:
Video input definition: 0x80 - Digital Input
Supported features:
DPMS standby
DPMS suspend
DPMS active-off
Digital display type: RGB 4:4:4 + YCrCb 4:4:4
Standard sRGB color space: False
White x,y: 0.313, 0.329
Red x,y: 0.645, 0.335
Green x,y: 0.305, 0.630
Blue x,y: 0.148, 0.050
Extension blocks: 1
EDID source: I2C
EDID hex dump:
+0 +4 +8 +c 0 4 8 c
+0000 00 ff ff ff ff ff ff 00 1e 6d fb 5b ae 5e 03 00 .........m.[.^..
+0010 03 21 01 03 80 30 1b 78 ea 31 35 a5 55 4e a1 26 .!...0.x.15.UN.&
+0020 0c 50 54 a5 4b 00 71 4f 81 80 95 00 b3 00 a9 c0 .PT.K.qO........
+0030 81 00 81 c0 90 40 2a 44 80 a0 70 38 27 40 30 20 .....@*D..p8'@0
+0040 35 00 e0 0e 11 00 00 1e 00 00 00 fd 00 30 4b 1e 5............0K.
+0050 55 12 00 0a 20 20 20 20 20 20 00 00 00 fc 00 4c U... .....L
+0060 47 20 46 55 4c 4c 20 48 44 0a 20 20 02 3a 80 18 G FULL HD. .:..
+0070 71 38 2d 40 58 2c 45 00 e0 0e 11 00 00 1e 01 f9 q8-@X,E.........
VCP version: 2.1
Controller mfg: Novatek
Firmware version: 3.5
Monitor uses all data bytes 0 in DDC reply packet to indicate unsupported feature.
Current dynamic sleep adjustment multiplier: 0.20
Monitor Model Id: GSM-LG_FULL_HD-23547
Feature definition file GSM-LG_FULL_HD-23547.mccs not found.
Display 2
I2C bus: /dev/i2c-5
DRM_connector: card1-DP-1
/sys/class/drm/card1-DP-1/dpms On
/sys/class/drm/card1-DP-1/enabled enabled
/sys/class/drm/card1-DP-1/status connected
/sys/class/drm/card1-DP-1/connector_id 826
Driver: nvidia
EDID exists: true
/sys/bus/i2c/devices/i2c-5/name NVIDIA i2c adapter 6 at 1:00.0
PCI device path: /sys/devices/pci0000:00/0000:00:01.1/0000:01:00.0/i2c-5
EDID synopsis:
Model: LG ULTRAGEAR
Product code: 23692 (0x5c8c)
Serial number: 509AZNKHA791
Binary serial number: 588791 (0x0008fbf7)
Manufacture year: 2025, Week: 9
EDID version: 1.4
Extra descriptor:
Video input definition: 0xb5 - Digital Input (DisplayPort), Bit depth: 10
Supported features:
DPMS standby
Digital display type: RGB 4:4:4 + YCrCb 4:4:4 + YCrCb 4:2:2
Standard sRGB color space: True
Red x,y: 0.676, 0.320
Green x,y: 0.298, 0.640
Blue x,y: 0.146, 0.061
Extension blocks: 1
EDID source: I2C
EDID hex dump:
+0 +4 +8 +c 0 4 8 c
+0000 00 ff ff ff ff ff ff 00 1e 6d 8c 5c f7 fb 08 00 .........m.\....
+0010 09 23 01 04 b5 3c 22 78 9f 07 a5 ad 52 4c a3 25 .#...<"x....RL.%
+0020 0f 50 54 25 4b 00 d1 c0 61 40 31 7c 45 7c 61 7c .PT%K...a@1|E|a|
+0030 45 40 01 01 01 01 4f a7 80 a0 70 38 40 40 30 30 E@....O...p8@@00
+0040 35 00 58 54 21 00 00 1a 00 00 00 fd 00 30 b4 c8 5.XT!........0..
+0050 c8 2a 01 0a 20 20 20 20 20 20 00 00 00 fc 00 4c .*.. .....L
+0060 47 20 55 4c 54 52 41 47 45 41 52 0a 00 00 00 ff G ULTRAGEAR.....
+0070 00 35 30 39 41 5a 4e 4b 48 41 37 39 31 0a 01 d0 .509AZNKHA791...
VCP version: 2.1
Firmware version: 3.4
Monitor correctly uses invalid feature flag in DDC reply packet to indicate unsupported feature.
Monitor Model Id: GSM-LG_ULTRAGEAR-23692
Feature definition file GSM-LG_ULTRAGEAR-23692.mccs not found.
ddcutil environment | head -n 40:
The following tests probe the runtime environment using multiple overlapping methods.
*** Basic System Information ***
ddcutil version: 2.2.7
/proc/version:
Linux version 7.1.6-1-cachyos (linux-cachyos@cachyos) (clang version 22.1.8, LLD 22.1.8) #1 SMP PREEMPT_DYNAMIC Mon, 03 Aug 2026 16:03:35 +0000
Architecture: x86_64
Distributor id: cachyos
Release: rolling
Found a known architecture
/proc/cmdline:
quiet nowatchdog splash rw rootflags=subvol=/@ root=UUID=0cfe10fb-565a-43d6-9fc4-705c68b29483
*** Primary Check 1: Identify video card and driver ***
Obtaining card and driver information from /sys...
Primary video controller at PCI address 0000:01:00.0 (boot_vga flag is set)
Device class: x030000 VGA compatible controller
Vendor: x10de NVIDIA Corporation
Device: x2504 GA106 [GeForce RTX 3060 Lite Hash Rate]
Subvendor/Subdevice: 10de/1536 NVIDIA Corporation
Driver name: nvidia
Driver version: 610.57.04
I2C device: i2c-3 name: NVIDIA i2c adapter 2 at 1:00.0
I2C device: i2c-6 name: NVIDIA i2c adapter 7 at 1:00.0
I2C device: i2c-4 name: NVIDIA i2c adapter 5 at 1:00.0
I2C device: i2c-2 name: NVIDIA i2c adapter 1 at 1:00.0
I2C device: i2c-7 name: NVIDIA i2c adapter 8 at 1:00.0
I2C device: i2c-5 name: NVIDIA i2c adapter 6 at 1:00.0
*** Primary Check 2: Check that /dev/i2c-* exist and writable ***
Current user: fhilipe (1000)
Checking /dev/i2c-* devices...
Devices /dev/i2c-* must exist and the logged on user must have read/write permission for those devices (or at least those devices associated
