To bring up the DDR3, what are the minimal parameters, we need to configure for initial testing?
instead of all parameters in BCT cfg file. New to DDR3 timing. Please help.
Please try to run memory test from the below topic #3:
https://devtalk.nvidia.com/default/topic/841202/a-tegra-k1-problem-on-sdrams-found-when-flashing-the-emcc-flash-probably-something-on-hardware/?offset=3
The low frequency 300MHz should have enough margin. 792MHz should be pass for most design. 924MHz is max supported frequency.
The BCT is all necessary parameters for a fixed frequency. The package have BCT config file for 300MHz and 792MHz.
DVFS table contain the different parameters for each frequency.
Thanks a lot.
