Dealing with Class Imbalance in SegFormer Semantic Segmentation
• Hardware (T4/V100/Xavier/Nano/etc) T4
• Network Type (Detectnet_v2/Faster_rcnn/Yolo_v4/LPRnet/Mask_rcnn/Classification/etc) SegFormer
• TLT Version (Please run “tlt info --verbose” and share “docker_tag” here) TAO 5.5.0
• Training spec file(If have, please share here)
• How to reproduce the issue ? (This is for errors. Please share the command line and the detailed log here.)
I have SegFormer working with my semantic segmentation use case. I’ve got two classes - background and cables. The problem is during training I end up with nearly 100% accuracy for background and close to 0% for cables. My cables only take up 0.4% of the pixels in the image so there is a huge class imbalance. Research suggests the class imbalance may be the reason for the accuracy issue. Is there a recommended way to configure SegFormer to deal with this? One suggestion was to use a different loss function but I’m not sure how to configure that.
Any help would be appreciated.
Duane Harkness
Rendered.ai
That means the training does not converge yet.
It is not the reason. The network can work for this case.
Please make sure the mask images are expected. See https://docs.nvidia.com/tao/tao-toolkit/text/data_annotation_format.html#semantic-segmentation-mask-format.
For color/ RGB input images, each mask image is a single-channel or three-channel image with the size equal to the input image. Every pixel in the mask must have an integer value that represents the segmentation class label_id.
Please check every pixel of the mask image.
