Dealing with conflicting Drivers on ZorinOS
Hi I’m trying to use my GPU rtx 3060 and comply with cuda 11.7 asking me for an nvidia driver with version 470 . It seems I’m at conflicting installation and backends like NCCL won’t push to cuda unless I resolve this .
On one end I have my Ubunutu 20 Updater interface telling me under “additional drivers” that I am
“Using NVIDIA Server Driver metapackage from nvidia-driver-470-server”
(i’m using a normal workstation not a server by the way so it defaulting to this is perplexing on it’s own).
On the other the bash command
(uname -r)/kernel/drivers/video/nvidia.ko | grep ^version
returns
bash: 5.14.0-1057-oem/kernel/drivers/video/nvidia.ko: No such file or directory
and on the side command nvidia-smi returns
Failed to initialize NVML: Driver/library version mismatch
and finally the cherry on top is that the site points only to the newest version of 525 whereas cuda 11.7 (the latest supported version supported by torch.distributed) only requires a driver of version 470 . Linux x64 (AMD64/EM64T) Display Driver | 525.85.05 | Linux 64-bit | NVIDIA .
so If anyone with an idea how to resolve this could help . I just need a driver that works on this OS with cuda11.7 and NCCL support .
in case we make progress here , u can look at more details on my other post : NCCL declaring Nvidia GPU missing using Pytorch distributed
Hi there aymentlili131,
my guess at first glance would be that your entire CUDA/driver installation is in a bad state and you should first revert everything. And then please read the installation instructions carefully. The documentation also contains details on how to purge both CUDA and GPU drivers.
The process involves quite a few steps, even in Ubuntu flavors, and they should be followed in order and to the letter, otherwise it is very easy to get the library version mismatch error of nvidia-smi.
Lastly I highly recommend to head over to CUDA Setup and Installation - NVIDIA Developer Forums and search through existing topics since others have faced similar problems before.
I hope this helps!
