I’m getting the error:
make[1]: entrant dans le répertoire « /home/arturo/NVDIA_CUDA_SDK/projects/histogram64 »
/usr/local/cuda/lib/libcudart.so: file not recognized: Format de fichier non reconnu
When running make at sdk path.
This were already done:
1- PATH and LD_LIBRARY_PATH set.
2- ldconfig run after changed config.
After reading different threads I tried the following:
3 - Selinux disabled.
Yet the problem persists. Any ideas?
