I use /Zi /Od /Fo /Fd to compile Raytracing.hlsl and export Raytracing.lld.When Profile Shaders,I can see the hlsl sourcecode.But in Linked Programs tab,Debug Info Load failed.What’s the problem?
plus: use /Zi /Od /Fo without /Fd,it’s ok to load the debug info.
Thank you for your your feedback on Nsight Graphics. Sorry you ran into this issue. Can you tell me what the tooltip says when you hover over the ‘Load Failed’ indicator?
Regards,
