Debug level the mlx5_core driver
Dear all,
the documentation mentions to increase the verbosity of the driver by e.g.
echo 3 > /sys/modules/mlx5_core/parameters/debug_mask
But where does the output end up?
Cheers, Peter
Hi p.niessen,
Thank you for posting your inquiry to the NVIDIA Developer Forums!
To enable full debug output from the driver, you will need to use dynamic-debug:
https://www.kernel.org/doc/Documentation/dynamic-debug-howto.txt
1. Mount debugfs on the filesystem:
mount -t debugfs none /sys/kernel/debug
Review:
/sys/kernel/debug/dynamic_debug/control
Example:
// enable all the messages available in the mlx5_ib module
echo -n 'module mlx5_ib +p' > /sys/kernel/debug/dynamic_debug/control
// enable all messages
echo -n '+p' > /sys/kernel/debug/dynamic_debug/control​
These outputs will be captured in /dev/kmsg (dmesg).
To capture data related to function calls which are not provided by dynamic debug, you would need to use another method - ie, bpftrace.
Best,
NVIDIA Enterprise Experience
