Debug USB - Interface - Paramter Configuration
Hello together!
I need the correct Configuration for Putty to connect COM7 via USB-Cable to my Nividia Thor AGX Dev. Kit.
Baudrate seems to be 115200.
But whats about: Stop-Bit, etc…
I cannot reboot. No output on the screen. Try to reset into delivery state.
The Output on com7 looks like:
[0001.025] I> Binary[21] block-91136 (partition size: 0x140000)
[0001.030] I> Binary name: SB-PKG
[0001.034] I> Size of crypto header is 8192
[0001.037] I> Size of crypto header is 8192
[0001.042] I> BCH of SB-PKG read from storage
[0001.046] I> SB-PKG header integrity check is success
[0001.050] I> Binary magic in BCH component 0 is SBPK
[0001.055] I> component binary type is 21
[0001.059] I> Size of crypto header is 8192
[0001.068] I> SB-PKG binary is read fro▒▒HPSE▒▒m st▒▒-FW ▒▒orag▒▒Buil▒▒e
[▒▒t: 6▒▒0001▒▒535b▒▒.069▒▒8d. ▒▒] I>▒▒Tue ▒▒ SB-▒▒Mar ▒▒PKG ▒▒18 0▒▒bina▒▒1:33▒▒ry i▒▒:01 ▒▒nteg▒▒PDT ▒▒rity▒▒2025▒▒ che▒▒
HP▒▒ck i▒▒SE-F▒▒s su▒▒W Bo▒▒cces▒▒ot
▒▒s
[0001.073] I> Task: TZDRAM carveout at runtime stage
[0001.077] I> Task: CPU UCF post init
[0001.089] I> CPU clk switch preping to PLLP
[0001.096] I> Invalid crab clk override 1 4 2
[0001.100] I> CPU clk switched to PLLP
[0001.104] I> min_freq_clamp 9
[0001.107] I> CPU NAFLL started
[0001.109] I> CPU PLLP enabled
[0001.113] I> scc_creg_defeature 0x08207ff1a07f932▒▒SB-F▒▒b
[▒▒W Bu▒▒0001▒▒ilt:▒▒.117▒▒ 653▒▒] I>▒▒5b8d▒▒ SCF▒▒. Tu▒▒ NAF▒▒e Ma▒▒LL l▒▒r 18▒▒ocke▒▒ 01:▒▒d
[▒▒33:0▒▒0001▒▒1 PD▒▒.120▒▒T 20▒▒] I>▒▒25
▒▒ SCF▒▒SB-F▒▒ SPL▒▒W Bo▒▒L lo▒▒ot
▒▒cked
[0001.122] I> SCF PLLP locked
[0001.125] I> SCF clk switch preping to NAFLL
[0001.133] I> SCF clk switched to NAFLL
[0001.143] I> CPU NAFLL locked
Thanks in advantage!
Best regards,
Humphrey.
Dear @humphrey.vanweyden ,
Is the used platform DRIVE AGX Thor Devkit or Jetson Thor Devkit?
Could you please provide any update for this topic?
Please see Configuring Minicom — NVIDIA DriveOS 7.0.3 Linux SDK Developer Guide for configuring minicom.
