Debugging an application with parameters
I’m currently trying to debug an application using pgdbg in text mode.
Here is my command:
pgdbg -text rams -f RAMSIN.hist
-f specify a filename
Here is the result using that command:
Missing -f argument
So i tried using double cote as following:
pgdbg -text rams “-f RAMSIN.hist”
The debugger starts but my application can’t find the file (RAMSIN.hist) specified with -f parameter.
Same result using an absolute path for my RAMSIN.hist path.
What is the proper way to use pgdbg in that case ?
Regards
Hi nnaudier,
What does the file RAMSIN.hist contain? Is it commands for the debugger or commands for your executable?
“-f” is not a supported swtich for x86 based processors and it appears to be an oversite that PGDBG accepts it.
Sorry for the confusion,
Mat
RAMSIN.hist is commands for my executable.
-f is for my executable.
To pass commands to your exe, first start the debugger using “pgdbg -text rams”, then from the pgdbg command prompt type “run -f RAMSIN.hist”. More detailed information about using PGDBG can be found in the PGI Tools Guide.
  • Mat
Thank you for your quick answer.
