I just installed Visual Studio 2013 Pro and all the components of tadp. I recompiled our apk using the version of the android sdk and ndk installed by tadp. It installs and runs on our Shield ok. The build process is a bit complicated, so to start with I just want to try debugging it with visual studio. I followed the instructions under Debugging an Existing APK on http://docs.nvidia.com/tegra/Content/Nsight_Tegra_Debugging.htm
When I click Start Debugging it copies to the Shield ok, but then the Launching application has a red X next to it and at the top it says: Precondition failed: activity != null
I tried both copying the AndroidManifest.xml from our project to the HelloWorld project, and I tried just editing the package and activity android:name in the generated AndroidManifest.xml to match ours. Both had the same results.
I also tested debugging a fresh Hello World project with no modifications and it worked ok.
Any ideas on what could be wrong and where to go from here?
