Debugging BCCPLEXWDT reset source
Hi @DaveYYY , Do you have an update on this?
Hi @bsirang1,
our developers are evaluating the patch, and we’ll update with you given any progress.
Any update on a fix for this? I am hitting this same issue where if I have a USB WIFI device attached to either the Orin Dev board or my custom board, same kernel panic. If I boot with it, it never fully boots. If I plug it in after I boot, it immediately kernel panics.
I have not tried the patch above yet.
Yes, I believe it’s already fixed in our internal code base, and might be able to catch up with the next L4T release.
Is there anything we can download to test ahead of time?
Rick
35.4.1 will be released soon, and please wait for the public release.
(Again, I’m just saying It might be able to catch up with the next L4T release.)
We usually don’t release patches on the forum.
Okay. Thanks for the heads up! Should I ask back here when it drops to see if it included those updates?
Feel free to do so.
I just reported another kernel bug that may be related: [80864.598452] BUG: scheduling while atomic: perception/9656/0x00000302
Hi @bsirang1 @enc0der,
please try this patch.
diff --git a/drivers/crypto/tegra-se-nvhost.c b/drivers/crypto/tegra-se-nvhost.c
index 62e005d..c077db7 100644
--- a/drivers/crypto/tegra-se-nvhost.c
+++ b/drivers/crypto/tegra-se-nvhost.c
@@ -4,7 +4,7 @@
  * Support for Tegra Security Engine hardware crypto algorithms.
- * Copyright (c) 2015-2022, NVIDIA CORPORATION.  All rights reserved.
+ * Copyright (c) 2015-2023, NVIDIA CORPORATION.  All rights reserved.
  * This program is free software; you can redistribute it and/or modify it
  * under the terms and conditions of the GNU General Public License,
@@ -5219,8 +5219,9 @@
 		total += ilen;
 		/* 2.2 - Copy adata and map it */
-		adata = dma_alloc_coherent(se_dev->dev, assoclen,
-						&adata_addr, GFP_KERNEL);
+		adata = dma_alloc_coherent(se_dev->dev, assoclen, &adata_addr,
+					(req->base.flags & CRYPTO_TFM_REQ_MAY_SLEEP) ?
+					GFP_KERNEL : GFP_ATOMIC);
 		num_sgs = tegra_se_count_sgs(sg, assoclen);
 		sg_copy_to_buffer(sg, num_sgs, adata, assoclen);
@@ -5415,7 +5416,7 @@
 	 * cryptlen case.
 	dst_buf = dma_alloc_coherent(se_dev->dev, cryptlen+1, &dst_buf_dma_addr,
-		GFP_KERNEL);
+		(req->base.flags & CRYPTO_TFM_REQ_MAY_SLEEP) ? GFP_KERNEL : GFP_ATOMIC);
 	if (!dst_buf)
 		return -ENOMEM;
@@ -5955,7 +5956,8 @@
 	 * cryptlen case.
-					GFP_KERNEL);
 	if (!dst_buf)
 		return -ENOMEM;
After applying the patch, we did encounter another kernel panic. Not sure if it’s a coincidence or related.
[ 4636.915356] BUG: scheduling while atomic: foxglove/69724/0x00000302
[ 4636.916228] Unable to handle kernel execute from non-executable memory at virtual address ffff800010003920
[ 4636.916516] Mem abort info:
[ 4636.916584]   ESR = 0x8600000f
[ 4636.916674]   EC = 0x21: IABT (current EL), IL = 32 bits
[ 4636.916814]   SET = 0, FnV = 0
[ 4636.916897]   EA = 0, S1PTW = 0
[ 4636.916978] swapper pgtable: 4k pages, 48-bit VAs, pgdp=000000032f3c1000
[ 4636.917153] [ffff800010003920] pgd=00000001000b3003, p4d=00000001000b3003, pud=00000001000b4003, pmd=00000001000b5003, pte=00680001000b2f03
[ 4636.917477] Internal error: Oops: 8600000f [#1] PREEMPT SMP
[ 4636.917630] Modules linked in: nvidia_modeset(OE) xt_mark(E) xt_tcpudp(E) veth(E) nf_conntrack_netlink(E) nfnetlink(E) br_netfilter(E) binfmt_misc(E) ip6table_nat(E) overlay(E) micrel(E) lzo_rle(E) lzo_compress(E) zram(E) ip6table_filter(E) ip6_tables(E) xt_state(E) xt_conntrack(E) iptable_filter(E) xt_MASQUERADE(E) xt_nat(E) xt_multiport(E) xt_addrtype(E) iptable_nat(E) nf_nat(E) nf_conntrack(E) nf_defrag_ipv6(E) ramoops(E) reed_solomon(E) loop(E) nf_defrag_ipv4(E) libcrc32c(E) nvgpu(E) iwlmvm(E) mac80211(E) iwlwifi(E) aes_ce_blk(E) crypto_simd(E) cryptd(E) aes_ce_cipher(E) ghash_ce(E) sha2_ce(E) cfg80211(E) sha256_arm64(E) sha1_ce(E) pwm_fan(E) btusb(E) ftdi_sio(E) btrtl(E) usbserial(E) btbcm(E) tegra_bpmp_thermal(E) userspace_alert(E) nct1008(E) btintel(E) ina3221(E) spi_tegra114(E) nvmap(E) nvidia(OE) gs_usb(E) mttcan(E) can_dev(E) can_raw(E) can(E) ip_tables(E) x_tables(E) [last unloaded: mtd]
[ 4636.961770] CPU: 0 PID: 145 Comm: irq/150-host_sy Tainted: G        W  OE     5.10.104-tegra #1
[ 4636.970693] Hardware name: Unknown Jetson AGX Orin/Jetson AGX Orin, BIOS 2.1-32413640 01/24/2023
[ 4636.979618] pstate: 80c00089 (Nzcv daIf +PAN +UAO -TCO BTYPE=--)
[ 4636.985659] pc : 0xffff800010003920
[ 4636.989335] lr : __wake_up_common+0x90/0x150
[ 4636.993791] sp : ffff8000121fba20
[ 4636.997204] x29: ffff8000121fba20 x28: ffffc24172f75370
[ 4637.002720] x27: 0000000000000000 x26: 0000000000000000
[ 4637.008229] x25: 0000000000000003 x24: 0000000000000000
[ 4637.013742] x23: 0000000000000001 x22: ffff8000121fbad0
[ 4637.019254] x21: ffff70fc97b4dbd8 x20: 00000000843a6580
[ 4637.024766] x19: ffffc2410377e4fc x18: 0000000000000000
[ 4637.030105] x17: 0000000000018021 x16: 0000000000018020
[ 4637.035617] x15: 0000000000018001 x14: 0000000000000000
[ 4637.040953] x13: 0000000000000020 x12: 0101010101010101
[ 4637.046379] x11: 0000000000000001 x10: 0000000000000004
[ 4637.051891] x9 : 000000003af18906 x8 : 0000000000000000
[ 4637.057229] x7 : ffff8000121fbc58 x6 : ffff8000100038a0
[ 4637.062567] x5 : ffff800010003920 x4 : 0000000000000000
[ 4637.067991] x3 : 0000000000000000 x2 : 0000000000000000
[ 4637.073329] x1 : 0000000000000003 x0 : ffff8000100038a0
[ 4637.078667] Call trace:
[ 4637.081119]  0xffff800010003920
[ 4637.084270]  __wake_up_common_lock+0x88/0xe0
[ 4637.088554]  __wake_up+0x44/0x60
[ 4637.091793]  action_wakeup+0x54/0x80
[ 4637.095293]  run_handlers+0xd8/0x190
[ 4637.098966]  process_wait_list+0x264/0x300
[ 4637.102992]  nvhost_syncpt_thresh_fn+0x54/0x90
[ 4637.107281]  syncpt_thresh_cascade_isr+0x1b0/0x2b0
[ 4637.112093]  irq_thread_fn+0x34/0xa0
[ 4637.115767]  irq_thread+0x158/0x250
[ 4637.119267]  kthread+0x148/0x170
[ 4637.122506]  ret_from_fork+0x10/0x24
[ 4637.126182] Code: 48ee1a00 ffff70fe 64769500 c68d9f13 (100039b0)
[ 4637.132312] ---[ end trace 3026889686f40ac2 ]---
[ 4637.141597] Kernel panic - not syncing: Oops: Fatal exception
[ 4637.142458] SMP: stopping secondary CPUs
[ 4637.146049] Kernel Offset: 0x424162850000 from 0xffff800010000000
[ 4637.152342] PHYS_OFFSET: 0xffff8f0680000000
[ 4637.156369] CPU features: 0x0040006,4a80aa38
[ 4637.160567] Memory Limit: none
[ 4637.168292] ---[ end Kernel panic - not syncing: Oops: Fatal exception ]---
Notice nvhost_syncpt_thresh_fn in the call stack.
Can this issue still be reproduced with the JetPack 5.1.2/L4T 35.4.1?
