We have a TX1 motherboard that won’t power up. Is there a schematic for this board that would show where the fuses would be?
Thanks,
K-
Thanks,
K-
This URL requires a separate login/registration from the forums, but has schematics (under Product select Jetson TX1 first…but the carrier board is in common to both TX1 and TX2):
[url]https://developer.nvidia.com/embedded/downloads[/url]
Note that if the fuse is on the module itself there is no published module schematic…the carrier board has complete documentation.
Are you using the supplied power supply? There have been issues in the past with third-party power supplies requiring a large capacitor at the connection point.
