I’m using Jetson TX2 with JetPack 3.2.1 with tegra-l4t-r28.2.1
I’m having trouble debugging a kernel NULL pointer dereference fault when using the tc358743 driver. After the fault, the TX2 locks up until a watchdog reset. The error I’m getting upon boot is.
[ 4.398957] tegra-vi4 15700000.vi: initialized
[ 4.400068] tegra-vi4 15700000.vi: subdev 150c0000.nvcsi-0 bound
[ 4.400072] tegra-vi4 15700000.vi: subdev tc358743 2-000f bound
[ 4.400417] Unable to handle kernel NULL pointer dereference at virtual address 00000000
[ 4.400419] pgd = ffffffc001525000
[ 4.400423] [00000000] *pgd=000000026cd7f003, *pud=000000026cd7f003, *pmd=000000026cd80003, *pte=00e8000003881707
[ 4.400426] Internal error: Oops: 96000005 [#1] PREEMPT SMP
[ 4.400428] Modules linked in:
[ 4.400431] CPU: 5 PID: 54 Comm: kworker/u12:1 Not tainted 4.4.38+ #5
[ 4.400433] Hardware name: quill (DT)
[ 4.400439] Workqueue: events_unbound async_run_entry_fn
[ 4.400440] task: ffffffc1eb499900 ti: ffffffc1eb518000 task.ti: ffffffc1eb518000
[ 4.400445] PC is at tegra_channel_init_subdevices+0x464/0x660
[ 4.400446] LR is at tegra_channel_init_subdevices+0x414/0x660
[ 4.400448] pc : [<ffffffc0007d7e3c>] lr : [<ffffffc0007d7dec>] pstate: 20000045
[ 4.400448] sp : ffffffc1eb51b9a0
[ 4.400451] x29: ffffffc1eb51b9a0 x28: ffffffc07b2003e0
[ 4.400452] x27: ffffffc1eabe21a0 x26: ffffffc1eabe2070
[ 4.400454] x25: ffffffc07b09ac00 x24: ffffffc000c8b000
[ 4.400456] x23: ffffffc07b202000 x22: ffffffc07b2004f8
[ 4.400457] x21: ffffffc07b00f800 x20: ffffffc07b201000
[ 4.400459] x19: ffffffc07b200018 x18: 0000000000020000
[ 4.400461] x17: 0000000000001a1d x16: 0000000000001a1d
[ 4.400462] x15: 0000000000001490 x14: 0000000000000028
[ 4.400464] x13: ffffff0000000000 x12: 0000000000000090
[ 4.400465] x11: 0000000000000000 x10: ffffffc1eabe2038
[ 4.400467] x9 : fefefefefefefeff x8 : 0000000000000000
[ 4.400469] x7 : ffffffffffffffff x6 : ffffffc07b2010d0
[ 4.400470] x5 : 0000000000000000 x4 : 0000000000000000
[ 4.400472] x3 : 0000000000000001 x2 : ffffffc07b2010d0
[ 4.400473] x1 : 0000000000000000 x0 : ffffffc1e59e8000
[ 4.400473]
[ 4.400475] Process kworker/u12:1 (pid: 54, stack limit = 0xffffffc1eb518020)
[ 4.400476] Call trace:
[ 4.400478] [<ffffffc0007d7e3c>] tegra_channel_init_subdevices+0x464/0x660
[ 4.400480] [<ffffffc0007d8d80>] tegra_vi_graph_notify_complete+0x220/0x660
[ 4.400483] [<ffffffc0007c8510>] v4l2_async_test_notify+0xf0/0x100
[ 4.400485] [<ffffffc0007c8644>] v4l2_async_notifier_register+0x124/0x190
[ 4.400487] [<ffffffc0007d9878>] tegra_vi_graph_init+0x1c8/0x298
[ 4.400489] [<ffffffc0007d59d0>] tegra_vi_media_controller_init+0x190/0x200
[ 4.400492] [<ffffffc000955258>] tegra_vi4_probe+0x210/0x2c8
[ 4.400496] [<ffffffc000598d78>] platform_drv_probe+0x50/0xb8
[ 4.400499] [<ffffffc000596874>] driver_probe_device+0xcc/0x428
[ 4.400500] [<ffffffc000596c6c>] __driver_attach+0x9c/0xa0
[ 4.400503] [<ffffffc000594768>] bus_for_each_dev+0x60/0xa0
[ 4.400504] [<ffffffc000596168>] driver_attach+0x20/0x28
[ 4.400506] [<ffffffc000594c64>] driver_attach_async+0x14/0x58
[ 4.400508] [<ffffffc0000c5000>] async_run_entry_fn+0x40/0x168
[ 4.400509] [<ffffffc0000bc218>] process_one_work+0x138/0x4c0
[ 4.400511] [<ffffffc0000bc6c4>] worker_thread+0x124/0x498
[ 4.400513] [<ffffffc0000c240c>] kthread+0xdc/0xf0
[ 4.400516] [<ffffffc000084f90>] ret_from_fork+0x10/0x40
[ 4.400619] ---[ end trace d8f373c7ca73e141 ]---
My dtsi is as follows
#define CAM0_RST_L TEGRA_MAIN_GPIO(R, 5)
host1x {
/* vi_base: vi */
vi@15700000 {
status = "okay";
num-channels = <1>;
ports {
#address-cells = <1>;
#size-cells = <0>;
status = "okay";
vi_port0: port@0 {
status = "okay";
reg = <0>;
tc358743_vi_in0: endpoint {
status = "okay";
csi-port = <0>; /* CSI-A */
bus-width = <4>; /* Use CSI-A */
remote-endpoint = <&tc358743_csi_out0>;
nvcsi@150c0000 {
num-channels = <1>;
#size-cells = <0>;
channel@0 {
status = "okay";
reg = <0>;
ports {
#size-cells = <0>;
port@0 {
status = "okay";
reg = <0>;
tc358743_csi_in0: endpoint@0 {
status = "okay";
csi-port = <0>;
bus-width = <4>;
remote-endpoint = <&tc358743_out0>;
port@1 {
status = "okay";
reg = <1>;
tc358743_csi_out0: endpoint@1 {
status = "okay";
remote-endpoint = <&tc358743_vi_in0>;
/* does this map to i2c bus 2? */
i2c@3180000 {
status = "okay";
/* The following is based on the example discussed here : https://devtalk.nvidia.com/default/topic/1011640/tc358743-on-tx2 */
tc358743@0f {
status = "okay";
compatible = "toshiba,tc358743";
reg = <0x0f>; /* shifted by 2 */
/* clocks copied from tegra186-quill-camera-li-mipi-adpt-a00.dtsi */
clocks = <&tegra_car TEGRA186_CLK_EXTPERIPH1>;
clock-names = "extperiph1";
refclk_hz = <27000000>;
reset-gpios = <&tegra_main_gpio CAM0_RST_L GPIO_ACTIVE_HIGH>;
/* Physical dimensions of sensor */
physical_w = "4.713";
physical_h = "3.494";
/* Sensor Model */
sensor_model ="tc358743";
ports {
#size-cells = <0>;
port@0 {
status = "okay";
reg = <0>;
tc358743_out0: endpoint {
status = "okay";
csi-port = <0>;
data-lanes = <1 2 3 4>;
clock-lanes = <0>;
clock-noncontinuous;
bus-width = <4>;
link-frequencies = /bits/ 64 <297000000>;
remote-endpoint = <&tc358743_csi_in0>;
tcp: tegra-camera-platform {
status = "okay";
compatible = "nvidia, tegra-camera-platform";
/* from tegra186-camera-li-mipi-adpt-a00.dtsi */
num_csi_lanes = <4>;
max_lane_speed = <1500000>;
min_bits_per_pixel = <10>;
vi_peak_byte_per_pixel = <2>;
vi_bw_margin_pct = <25>;
isp_peak_byte_per_pixel = <5>;
isp_bw_margin_pct = <25>;
modules {
module0 {
status = "okay";
badge = "tc358743_top_i2c1";
position = "top";
orientation = "3";
drivernode0 {
status = "okay";
pcl_id = "v4l2_sensor";
devname = "tc358743 30-000f";
/* Declare the device-tree hierarchy to driver instance */
proc-device-tree = "/proc/device-tree/i2c@3180000/tc358743@0f";
Do you have any advice as to how I can go about debugging this fault?
Thanks,
