I had to remove the -g flags to compile with the -ta=multicore flag. It compiles without a problem, but when the executable is ran, it core dumps (seg faults). Normally would run under Valgrind, but with the -g option not being allowed to be enabled alongside the -ta=multicore flag, it is a bit harder to debug. My next option would be to start adding print statements until figuring out around where the program is seg faulting. I was wondering if there is a more efficient manner of debugging the -ta=multicore code generated executable?
Thank you!
