Sorry to be reviving such an old thread, but I seem to running into some issues that seem related to the ones encountered here almost 3 years ago. Except the NVRM message I’m getting is:
I just happened to be interactively on a machine when the GPU got stuck.
The machine was just rebootet, on the first GPU another job run, on the second the first job crashed.
There was no crash related output from the job itself.
nvidia-smi -a | grep Driver
Driver Version : 275.09.07
nvidia-smi -s
COMPUTE mode rules for GPU 0: 1
COMPUTE mode rules for GPU 1: 1
COMPUTE mode rules for GPU 2: 2
uname -a
HOSTNAME 2.6.18-238.12.1.el5 #1 SMP Tue May 31 13:22:04 EDT 2011 x86_64 x86_64 x86_64 GNU/Linux
After booting I took the system into “init 3”.
So there was no X-Server running.
Ah before I forget, the crashs dont seem to be predictable. Sometimes the machine works for 10 runs or more, and now the second started job produced the problem.
Are a table of Xid error codes and their descriptions published anywhere?
Above, you mention that Xid 31 means an MMU fault, probably due to bad pointer dereference. However, can it also be caused by something else, e.g. MMU fault for some reason during full duplex memory transfer between the device and host?
Yes, I am also looking for NVRM Xid error codes table from Nvidia.
Normally, I have seen Xid 13 whenever there is “cuda launch failure” from any cuda program. The only way to rescue round it is to cold reboot the machine.
