Hey,
I’ve finally been able to install the 20.03 branch correctly but when I want to call “retinanet” command I have this error occuring:
File "/home/nvidia/.virtualenvs/cv/bin/retinanet", line 33, in <module>
sys.exit(load_entry_point('retinanet==0.2.3', 'console_scripts', 'retinanet')())
File "/home/nvidia/.virtualenvs/cv/bin/retinanet", line 25, in importlib_load_entry_point
return next(matches).load()
File "/home/nvidia/.virtualenvs/cv/lib/python3.6/site-packages/importlib_metadata/__init__.py", line 105, in load
module = import_module(match.group('module'))
File "/usr/lib/python3.6/importlib/__init__.py", line 126, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 994, in _gcd_import
File "<frozen importlib._bootstrap>", line 971, in _find_and_load
File "<frozen importlib._bootstrap>", line 955, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 665, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 678, in exec_module
File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
File "/home/nvidia/.virtualenvs/cv/lib/python3.6/site-packages/retinanet-0.2.3-py3.6-linux-aarch64.egg/retinanet/main.py", line 10, in <module>
from retinanet import infer, train, utils
File "/home/nvidia/.virtualenvs/cv/lib/python3.6/site-packages/retinanet-0.2.3-py3.6-linux-aarch64.egg/retinanet/infer.py", line 12, in <module>
from .dali import DaliDataIterator
File "/home/nvidia/.virtualenvs/cv/lib/python3.6/site-packages/retinanet-0.2.3-py3.6-linux-aarch64.egg/retinanet/dali.py", line 5, in <module>
from nvidia.dali import pipeline, ops, types
ModuleNotFoundError: No module named 'nvidia'
I found some package to install “nvidia-dali-cuda100” but it seems that I can’t install it through “pip” command.
Here is the error after typing “pip install nvidia-dali-cuda100”:
ERROR: Command errored out with exit status 1:
command: /home/nvidia/.virtualenvs/cv/bin/python -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-lit2rmf_/nvidia-dali-cuda100/setup.py'"'"'; __file__='"'"'/tmp/pip-install-lit2rmf_/nvidia-dali-cuda100/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' egg_info --egg-base /tmp/pip-pip-egg-info-cbuvqo74
cwd: /tmp/pip-install-lit2rmf_/nvidia-dali-cuda100/
Complete output (18 lines):
File "<string>", line 1, in <module>
File "/tmp/pip-install-lit2rmf_/nvidia-dali-cuda100/setup.py", line 150, in <module>
raise RuntimeError(open("ERROR.txt", "r").read())
RuntimeError:
The package you are trying to install is only a placeholder project on PyPI.org repository.
This package is hosted on NVIDIA Python Package Index.
This package can be installed as:
$ pip install nvidia-pyindex
$ pip install nvidia-dali-cuda100
Please refer to NVIDIA DALI installation guide for instructions:
https://docs.nvidia.com/deeplearning/dali/user-guide/docs/installation.html
ERROR: Command errored out with exit status 1: python setup.py egg_info Check the logs for full command output.
I have installed nvidia-pyindex but I don’t get how to get dali from this package…
