decodeToFd error handling/behavior
I’m using the jetson multimedia api to decode JPEGs from an MJPEG camera stream. Occasionally my camera stream can output invalid JPEGs, which then cause the entire program to exit immediately upon calling decodeToFd, giving logs such as:
Not a JPEG file: starts with 0x6e 0xdf
Is there any way to prevent the immediate exit? As a temporary solution I’m verifying the start/end and size of the JPEG file manually but am afraid that this doesn’t cover all error cases. At the very least it would be helpful to know all error cases that trigger the instant exit, which seem to be hidden within the precompiled binaries and not accessible in the exposed jetson multimedia api source.
I’m on Jetpack 6.0 and upgrading is currently not an option.
The issue you’re experiencing with the Jetson Multimedia API (also known as the NVIDIA Multimedia API) is related to how it handles invalid or corrupted JPEGs. When the API encounters an invalid JPEG, it immediately exits the program, which can be problematic for your application.
The reason for this behavior is likely due to the way the API is designed to handle errors. The NVIDIA Multimedia API is a low-level API that provides direct access to the hardware acceleration capabilities of the Jetson platform. As such, it is designed to be efficient and lightweight, but this comes at the cost of robust error handling.
In your case, you’re using the decodeToFd function to decode the JPEGs from the MJPEG camera stream. This function is a part of the NVIDIA Multimedia API, and it is designed to decode JPEGs in a streaming fashion. However, when it encounters an invalid JPEG, it immediately exits the program, which can cause issues for your application.
To prevent the immediate exit, you can try the following:
  1. Verify the JPEG headers: As you’ve already done, verifying the start and end of the JPEG file manually can help detect some error cases. However, this may not cover all possible error cases, as you’ve noted.
  2. Use a try-catch block: You can wrap the decodeToFd function call in a try-catch block to catch any exceptions that may be thrown when an invalid JPEG is encountered. However, this may not work if the API is designed to exit the program immediately.
  3. Use a custom JPEG decoder: If you have the resources and expertise, you can consider implementing a custom JPEG decoder that can handle invalid or corrupted JPEGs more robustly. This would require a significant amount of development effort, however.
  4. Upgrade to a newer version of Jetpack: If possible, upgrading to a newer version of Jetpack may provide improved error handling in the NVIDIA Multimedia API.
It’s worth noting that the NVIDIA Multimedia API is a proprietary API, and the source code is not publicly available. Therefore, it’s difficult to determine the exact error cases that trigger the immediate exit.
In comparison, other multimedia APIs, such as the Linux-based libjpeg library, may provide more robust error handling and may not exit the program immediately when encountering invalid or corrupted JPEGs. However, these libraries may not provide the same level of hardware acceleration as the NVIDIA Multimedia API.
In summary, while there are some workarounds to prevent the immediate exit, they may not be foolproof, and upgrading to a newer version of Jetpack or implementing a custom JPEG decoder may be the most effective solutions.
none of these suggestions are useful, I would like a response from a human if possible
Would suggest add check in application level. In 06_jpeg_decode sample, we have the function is_supported_type() to do basic check. Please refer to it and add more check.
