I’ve used decuda to extract gpu assembly instructions from g80 cubin files on cuda sdk 2.3 and it worked flawlessly. However when I try to decuda a program compiled using cuda sdk 3.0, I got the following error:
File "/.../decuda-0.4.2/decuda", line 89, in <module>
main()
File "/.../decuda-0.4.2/decuda", line 52, in main
cu = load(args[0])
File "/.../decuda-0.4.2/CubinFile.py", line 255, in load
inst = [int(x,0) for x in inst]
ValueError: invalid literal for int() with base 0:
I know decuda only work for G80/G90 gpus and I used -arch=sm_11, but it did not help.
Thanks so much, your scripy is exactly what I need!
However, when I try to apply it to some of the kernels I’m exploring, I got following error:
File "/.../decuda-0.4.2/elfToCubin.py", line 431, in <module>
cubin = parse_objdump(output,code,arch)
File "/.../decuda-0.4.2/elfToCubin.py", line 217, in parse_objdump
raise ValueError("Got unexpected line in state INKERNEL\n%s"%line)
ValueError: Got unexpected line in state INKERNEL
a000 05020230 800710c4 05d40020 80472004 ...0....... .G .
