Dedicated Engine file path
• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version:7.0
• TensorRT Version8.6
• NVIDIA GPU Driver Version (valid for GPU only) 12.2
• Issue Type( questions, new requirements, bugs) bugs
docker image:nvcr.io/nvidia/deepstream:7.0-gc-triton-devel
GPU: 4070 8GB
I am using yolov8 as back to back detectors in python
I am using 1 primary infer and multiple secondry infer using nvinfer plugin.
I need all secondary nvinfer to have same batch size.
My problem is when engine file is created for one secondary infer, it replaces the engine file created by other secondary infer because of deepstream default naming of the engine file (model_b6_gpu0_fp32.engine) and all engine files are created in cwd. I want
I tried passing the path “model-engine-file” but still it saves the engine file in cwd directory
Saw some other issues where it was mentioned, model-engine-file will be saved at the same place of “onnx-file” but still it is saving the engine file in cwd
I need to save the the engine file at a dedicated path
Attaching my infer config for reference
[property]
gpu-id=0
net-scale-factor=0.0039215697906911373
model-color-format=0
onnx-file=weights/parts/bodyPartDetectionModel.onnx
#model engine file will be created on its own.
model-engine-file=weights/parts/model_b6_gpu0_fp32.engine
#int8-calib-file=calib.table
labelfile-path=parts_labels.txt
batch-size=6
network-mode=0
num-detected-classes=6
interval=0
gie-unique-id=4
process-mode=2
network-type=0
cluster-mode=2
maintain-aspect-ratio=1
symmetric-padding=1
#workspace-size=2000
parse-bbox-func-name=NvDsInferParseYolo
#parse-bbox-func-name=NvDsInferParseYoloCuda
custom-lib-path=/opt/nvidia/deepstream/deepstream-7.0/DeepStream-Yolo/nvdsinfer_custom_impl_Yolo/libnvdsinfer_custom_impl_Yolo.so
engine-create-func-name=NvDsInferYoloCudaEngineGet
[class-attrs-all]
nms-iou-threshold=0.45
pre-cluster-threshold=0.5
topk=300
Following things I tried:
Passing absolute paths, still engine file is saved in cwd.
Checked the Permission chmod 755 /opt/nvidia/deepstream/deepstream-7.0/app/weights/part
Tried to pause other nvinfers and manually copied engine file in /opt/nvidia/deepstream/deepstream-7.0/app/weights/part and this is able to read successfully but I want to avoid this step if possible.
It is a known issue, please refer to this topic
Apply this patch, then rebuild and reinstall the nvinfer plugin.
diff --git a/src/utils/nvdsinfer/nvdsinfer_model_builder.cpp b/src/utils/nvdsinfer/nvdsinfer_model_builder.cpp
index 35457f0..ebf42ff 100644
--- a/src/utils/nvdsinfer/nvdsinfer_model_builder.cpp
+++ b/src/utils/nvdsinfer/nvdsinfer_model_builder.cpp
@@ -489,9 +489,17 @@
         if (cudaEngineGetFcn || cudaEngineGetDeprecatedFcn)
             /* NvDsInferCudaEngineGet interface provided. */
-            char *cwd = getcwd(NULL, 0);
-            modelPath = std::string(cwd) + "/model";
-            free(cwd);
+            std::string onnxFilePath = initParams.onnxFilePath;
+            std::string modelEngineFilePath = initParams.modelEngineFilePath;
+            if (onnxFilePath != "") {
+                modelPath = onnxFilePath.substr(0, onnxFilePath.find(".onnx")).substr(onnxFilePath.rfind("/") + 1);
+            } else if (modelEngineFilePath != "") {
+                modelPath = modelEngineFilePath.substr(0, modelEngineFilePath.find(".engine")).substr(modelEngineFilePath.rfind("/") + 1);
+            } else {
+                char *cwd = getcwd(NULL, 0);
+                modelPath = std::string(cwd) + "/model";
+                free(cwd);
         else
Ohh, sorry I did not know.
Is this issue handled in Deepstream 7.1?
Not yet, please follow the patch above and modify it in the open source code
Sure, thanks.
