deep copy does not seem to work for arrays two levels down
I am using deepcopy in PGI 17.7.
I have a type defined as:
      type :: vvec_bc
        type(vvec_bcr) :: r0
        type(vvec_bcr) :: r1
      end type
with
      type :: vvec_bcr
        real(r_typ), dimension(:,:), pointer :: r
        real(r_typ), dimension(:,:), pointer :: t
        real(r_typ), dimension(:,:), pointer :: p
      end type
I then declare
type(vvec_bc) :: vb
which has all its arrays inside allocated.
When I try to use “vb” with deepcopy, it does not work and segfaults:
!$acc enter data copyin(vb)
followed by
!$acc parallel present(vv,vb)
!$acc loop gang worker
        do k=2,npm1
!$acc loop vector
          do j=2,ntm1
            vv%r(1,j,k)=bcmask*vb%r0%r(j,k)
          enddo
        enddo
I instead have to do:
!$acc enter data copyin(vb%r0,vb%r1)
and
!$acc parallel present(vv,vb%r0)
        do k=2,npm1
!$acc loop vector
          do j=2,ntm1
          enddo
        enddo
Can deepcopy only go down one level?
Hi sumseq,
It should be able to go down multiple levels (we’ve tested it using multi-levels), but obviously missed this case. Deepcopy is brand new and should be considered beta.
I was able to recreate the error with this simplified version below and have filed a problem report (TPR#24770). If you can, please send in a reproducing example to PGI Customer Service (trs@pgroup.com). We can then attach it to the report and ensure that the problem is the same as what I have below.
Thanks for the report!
Mat
% cat test2.f90
program main
      type :: vvec_bcr
         real, dimension(:,:), pointer :: r
       end type
       type :: vvec_bc
       end type
       type(vvec_bc) :: vb
      allocate(vb%r0%r(128,128))
      !$acc kernels loop present(vb)
      do i=1,128
        do j=1,128
          vb%r0%r(i,j)=1.0
        enddo
     enddo
     !$acc exit data copyout(vb)
     print *, vb%r0%r(2,3)
     deallocate(vb%r0%r)
end program main
% pgf90 test2.f90 -ta=tesla:cc60,deepcopy -Minfo=accel
main:
     13, Generating enter data copyin(vb)
     14, Generating present(vb)
     15, Loop is parallelizable
     16, Loop is parallelizable
         Accelerator kernel generated
         Generating Tesla code
         15, !$acc loop gang, vector(128) ! blockidx%x threadidx%x
         16, !$acc loop gang ! blockidx%y
     20, Generating exit data copyout(vb)
% a.out
Segmentation fault
Your example looks exactly what my problem is.
24770 - OpenACC: Deepcopy of multiple leveled UDT causes segv
has been fixed in the current 17.10 release.
dave
