OK, I just tried this again on JetPack 4.4.1 and applied the patch, and it is working here. This is the source of /usr/src/tensorrt/samples/sampleUffSSD_rect/sampleUffSSD.cpp
after the patch is applied:
#include <cassert>
#include <chrono>
#include <cublas_v2.h>
#include <cudnn.h>
#include <iostream>
#include <sstream>
#include <string.h>
#include <time.h>
#include <unordered_map>
#include <vector>
#include "BatchStreamPPM.h"
#include "NvUffParser.h"
#include "common.h"
#include "argsParser.h"
#include "NvInferPlugin.h"
using namespace nvinfer1;
using namespace nvuffparser;
using namespace sample;
using namespace std;
/*static Logger gLogger;*/
static samplesCommon::Args args;
#define RETURN_AND_LOG(ret, severity, message) \
do \
std::string error_message = "sample_uff_ssd: " + std::string(message); \
gLogger.log(ILogger::Severity::k##severity, error_message.c_str()); \
return (ret); \
} while (0)
static constexpr int OUTPUT_CLS_SIZE = 37;
static constexpr int OUTPUT_BBOX_SIZE = OUTPUT_CLS_SIZE * 4;
const char* OUTPUT_BLOB_NAME0 = "NMS";
const char* CLASSIFIER_CLS_SOFTMAX_NAME = "random_name";
//INT8 Calibration, currently set to calibrate over 500 images
static constexpr int CAL_BATCH_SIZE = 50;
static constexpr int FIRST_CAL_BATCH = 0, NB_CAL_BATCHES = 10;
// Concat layers
// mbox_priorbox, mbox_loc, mbox_conf
const int concatAxis[2] = {1, 1};
const bool ignoreBatch[2] = {false, false};
DetectionOutputParameters detectionOutputParam{true, false, 0, OUTPUT_CLS_SIZE, 100, 100, 0.5, 0.6, CodeTypeSSD::TF_CENTER, {1, 2, 0}, true, true};
// Visualization
const float visualizeThreshold = 0.4;
void printOutput(int64_t eltCount, DataType dtype, void* buffer)
std::cout << eltCount << " eltCount" << std::endl;
assert(samplesCommon::getElementSize(dtype) == sizeof(float));
std::cout << "--- OUTPUT ---" << std::endl;
size_t memSize = eltCount * samplesCommon::getElementSize(dtype);
float* outputs = new float[eltCount];
CHECK(cudaMemcpyAsync(outputs, buffer, memSize, cudaMemcpyDeviceToHost));
int maxIdx = std::distance(outputs, std::max_element(outputs, outputs + eltCount));
for (int64_t eltIdx = 0; eltIdx < eltCount; ++eltIdx)
std::cout << eltIdx << " => " << outputs[eltIdx] << "\t : ";
if (eltIdx == maxIdx)
std::cout << "***";
std::cout << "\n";
std::cout << std::endl;
delete[] outputs;
std::string locateFile(const std::string& input)
std::vector<std::string> dirs{"data/ssd/",
"data/ssd/VOC2007/",
"data/ssd/VOC2007/PPMImages/",
"data/samples/ssd/",
"data/samples/ssd/VOC2007/",
"data/samples/ssd/VOC2007/PPMImages/"};
return locateFile(input, dirs);
void populateTFInputData(float* data)
auto fileName = locateFile("inp_bus.txt");
std::ifstream labelFile(fileName);
string line;
int id = 0;
while (getline(labelFile, line))
istringstream iss(line);
float num;
iss >> num;
data[id++] = num;
return;
void populateClassLabels(std::string (&CLASSES)[OUTPUT_CLS_SIZE])
// auto fileName = locateFile("ssd_coco_labels.txt");
auto fileName = locateFile("sample_labels.txt");
string line;
int id = 0;
CLASSES[id++] = line;
return;
std::vector<std::pair<int64_t, DataType>>
calculateBindingBufferSizes(const ICudaEngine& engine, int nbBindings, int batchSize)
std::vector<std::pair<int64_t, DataType>> sizes;
for (int i = 0; i < nbBindings; ++i)
Dims dims = engine.getBindingDimensions(i);
DataType dtype = engine.getBindingDataType(i);
int64_t eltCount = samplesCommon::volume(dims) * batchSize;
sizes.push_back(std::make_pair(eltCount, dtype));
return sizes;
ICudaEngine* loadModelAndCreateEngine(const char* uffFile, int maxBatchSize,
IUffParser* parser, IHostMemory*& trtModelStream)
// Create the builder
IBuilder* builder = createInferBuilder(gLogger);
// Parse the UFF model to populate the network, then set the outputs.
INetworkDefinition* network = builder->createNetwork();
std::cout << "Begin parsing model..." << std::endl;
if (!parser->parse(uffFile, *network, nvinfer1::DataType::kFLOAT))
RETURN_AND_LOG(nullptr, INTERNAL_ERROR, "Fail to parse");
std::cout << "End parsing model..." << std::endl;
// for (int i = 0; i < network->getNbLayers(); ++i) {
// if (! strcmp(network->getLayer(i)->getName(), OUTPUT_BLOB_NAME0)) {
// auto top_layer = network->getLayer(i);
// cout << "unmark " << OUTPUT_BLOB_NAME0 << endl;
// network->unmarkOutput(*top_layer->getOutput(0));
// if (! strcmp(network->getLayer(i)->getName(), BACKBONE_OUTPUT)) {
// // auto prob = network->addSoftMax(*top_layer->getOutput(0));
// // prob->getOutput(0)->setName(CLASSIFIER_CLS_SOFTMAX_NAME);
// // network->markOutput(*prob->getOutput(0));
// network->markOutput(*top_layer->getOutput(0));
// cout << "mark " << BACKBONE_OUTPUT << endl;
// Build the engine.
builder->setMaxBatchSize(maxBatchSize);
// The _GB literal operator is defined in common/common.h
builder->setMaxWorkspaceSize(1024*1024*128); // We need about 1GB of scratch space for the plugin layer for batch size 5.
builder->setHalf2Mode(true);
//if (args.runInInt8)
// builder->setInt8Mode(true);
// builder->setInt8Calibrator(calibrator);
std::cout << "Begin building engine..." << std::endl;
auto t_start = std::chrono::high_resolution_clock::now();
ICudaEngine* engine = builder->buildCudaEngine(*network);
auto t_end = std::chrono::high_resolution_clock::now();
float total = std::chrono::duration<float, std::milli>(t_end - t_start).count();
std::cout << "Time lapsed to create an engine: " << total << "ms" << std::endl;
if (!engine)
RETURN_AND_LOG(nullptr, INTERNAL_ERROR, "Unable to create engine");
std::cout << "End building engine..." << std::endl;
// We don't need the network any more, and we can destroy the parser.
network->destroy();
parser->destroy();
// Serialize the engine, then close everything down.
trtModelStream = engine->serialize();
builder->destroy();
shutdownProtobufLibrary();
return engine;
void doInference(IExecutionContext& context, float* inputData, float* detectionOut, int* keepCount, int batchSize)
const ICudaEngine& engine = context.getEngine();
// Input and output buffer pointers that we pass to the engine - the engine requires exactly IEngine::getNbBindings(),
// of these, but in this case we know that there is exactly 1 input and 2 output.
int nbBindings = engine.getNbBindings();
std::cout << nbBindings << " Binding" << std::endl;
std::vector<void*> buffers(nbBindings);
std::vector<std::pair<int64_t, DataType>> buffersSizes = calculateBindingBufferSizes(engine, nbBindings, batchSize);
auto bufferSizesOutput = buffersSizes[i];
buffers[i] = samplesCommon::safeCudaMalloc(bufferSizesOutput.first * samplesCommon::getElementSize(bufferSizesOutput.second));
std::cout << "Allocating buffer sizes for binding index: " << i << " of size : " ;
std::cout << bufferSizesOutput.first << " * " << samplesCommon::getElementSize(bufferSizesOutput.second);
std::cout << " B" << std::endl;
// In order to bind the buffers, we need to know the names of the input and output tensors.
// Note that indices are guaranteed to be less than IEngine::getNbBindings().
int inputIndex = engine.getBindingIndex(INPUT_BLOB_NAME),
outputIndex0 = engine.getBindingIndex(OUTPUT_BLOB_NAME0),
outputIndex1 = outputIndex0 + 1; //engine.getBindingIndex(OUTPUT_BLOB_NAME1);
cudaStream_t stream;
CHECK(cudaStreamCreate(&stream));
// DMA the input to the GPU, execute the batch asynchronously, and DMA it back:
CHECK(cudaMemcpyAsync(buffers[inputIndex], inputData, batchSize * INPUT_C * INPUT_H * INPUT_W * sizeof(float), cudaMemcpyHostToDevice, stream));
float t_average = 0;
float t_iter = 0;
int iterations = 10;
int avgRuns = 100;
for (int i=0; i < iterations; i++)
t_average = 0;
for (int j=0; j < avgRuns; j++)
context.execute(batchSize, &buffers[0]);
t_average += total;
t_average /= avgRuns;
std::cout << "Time taken for inference per run is " << t_average << " ms." << std::endl;
t_iter += t_average;
t_iter /= iterations;
std::cout << "Average time spent per iteration is " << t_iter << " ms." << std::endl;
for (int bindingIdx = 0; bindingIdx < nbBindings; ++bindingIdx)
if (engine.bindingIsInput(bindingIdx))
continue;
#ifdef SSD_INT8_DEBUG
auto bufferSizesOutput = buffersSizes[bindingIdx];
printOutput(bufferSizesOutput.first, bufferSizesOutput.second,
buffers[bindingIdx]);
#endif
CHECK(cudaMemcpyAsync(detectionOut, buffers[outputIndex0], batchSize * detectionOutputParam.keepTopK * 7 * sizeof(float), cudaMemcpyDeviceToHost, stream));
CHECK(cudaMemcpyAsync(keepCount, buffers[outputIndex1], batchSize * sizeof(int), cudaMemcpyDeviceToHost, stream));
cudaStreamSynchronize(stream);
std::cout << "Time taken for inference is " << t_average << " ms." << std::endl;
// Release the stream and the buffers
cudaStreamDestroy(stream);
CHECK(cudaFree(buffers[inputIndex]));
CHECK(cudaFree(buffers[outputIndex0]));
CHECK(cudaFree(buffers[outputIndex1]));
namespace
const char* FLATTENCONCAT_PLUGIN_VERSION{"1"};
const char* FLATTENCONCAT_PLUGIN_NAME{"FlattenConcat_TRT"};
// Flattens all input tensors and concats their flattened version together
// along the major non-batch dimension, i.e axis = 1
class FlattenConcat : public IPluginV2
public:
// Ordinary ctor, plugin not yet configured for particular inputs/output
FlattenConcat() {}
// Ctor for clone()
FlattenConcat(const int* flattenedInputSize, int numInputs, int flattenedOutputSize)
: mFlattenedOutputSize(flattenedOutputSize)
for (int i = 0; i < numInputs; ++i)
mFlattenedInputSize.push_back(flattenedInputSize[i]);
// Ctor for loading from serialized byte array
FlattenConcat(const void* data, size_t length)
const char* d = reinterpret_cast<const char*>(data);
const char* a = d;
size_t numInputs = read<size_t>(d);
for (size_t i = 0; i < numInputs; ++i)
mFlattenedInputSize.push_back(read<int>(d));
mFlattenedOutputSize = read<int>(d);
assert(d == a + length);
int getNbOutputs() const override
// We always return one output
return 1;
Dims getOutputDimensions(int index, const Dims* inputs, int nbInputDims) override
// At least one input
assert(nbInputDims >= 1);
// We only have one output, so it doesn't
// make sense to check index != 0
assert(index == 0);
size_t flattenedOutputSize = 0;
int inputVolume = 0;
for (int i = 0; i < nbInputDims; ++i)
// We only support NCHW. And inputs Dims are without batch num.
assert(inputs[i].nbDims == 3);
inputVolume = inputs[i].d[0] * inputs[i].d[1] * inputs[i].d[2];
flattenedOutputSize += inputVolume;
return DimsCHW(flattenedOutputSize, 1, 1);
int initialize() override
// Called on engine initialization, we initialize cuBLAS library here,
// since we'll be using it for inference
CHECK(cublasCreate(&mCublas));
return 0;
void terminate() override
// Called on engine destruction, we destroy cuBLAS data structures,
// which were created in initialize()
CHECK(cublasDestroy(mCublas));
size_t getWorkspaceSize(int maxBatchSize) const override
// The operation is done in place, it doesn't use GPU memory
return 0;
int enqueue(int batchSize, const void* const* inputs, void** outputs, void*, cudaStream_t stream) override
// Does the actual concat of inputs, which is just
// copying all inputs bytes to output byte array
size_t inputOffset = 0;
float* output = reinterpret_cast<float*>(outputs[0]);
for (size_t i = 0; i < mFlattenedInputSize.size(); ++i)
const float* input = reinterpret_cast<const float*>(inputs[i]);
for (int batchIdx = 0; batchIdx < batchSize; ++batchIdx)
CHECK(cublasScopy(mCublas, mFlattenedInputSize[i],
input + batchIdx * mFlattenedInputSize[i], 1,
output + (batchIdx * mFlattenedOutputSize + inputOffset), 1));
inputOffset += mFlattenedInputSize[i];
return 0;
size_t getSerializationSize() const override
// Returns FlattenConcat plugin serialization size
size_t size = sizeof(mFlattenedInputSize[0]) * mFlattenedInputSize.size()
+ sizeof(mFlattenedOutputSize)
+ sizeof(size_t); // For serializing mFlattenedInputSize vector size
return size;
void serialize(void* buffer) const override
// Serializes FlattenConcat plugin into byte array
// Cast buffer to char* and save its beginning to a,
// (since value of d will be changed during write)
char* d = reinterpret_cast<char*>(buffer);
char* a = d;
size_t numInputs = mFlattenedInputSize.size();
// Write FlattenConcat fields into buffer
write(d, numInputs);
write(d, mFlattenedInputSize[i]);
write(d, mFlattenedOutputSize);
// Sanity check - checks if d is offset
// from a by exactly the size of serialized plugin
assert(d == a + getSerializationSize());
void configureWithFormat(const Dims* inputs, int nbInputs, const Dims* outputDims, int nbOutputs, nvinfer1::DataType type, nvinfer1::PluginFormat format, int maxBatchSize) override
// We only support one output
assert(nbOutputs == 1);
// Reset plugin private data structures
mFlattenedInputSize.clear();
mFlattenedOutputSize = 0;
// For each input we save its size, we also validate it
for (int i = 0; i < nbInputs; ++i)
// All inputs dimensions along non concat axis should be same
for (size_t dim = 1; dim < 3; dim++)
assert(inputs[i].d[dim] == inputs[0].d[dim]);
// Size of flattened input
mFlattenedInputSize.push_back(inputVolume);
mFlattenedOutputSize += mFlattenedInputSize[i];
bool supportsFormat(DataType type, PluginFormat format) const override
return (type == DataType::kFLOAT && format == PluginFormat::kNCHW);
const char* getPluginType() const override { return FLATTENCONCAT_PLUGIN_NAME; }
const char* getPluginVersion() const override { return FLATTENCONCAT_PLUGIN_VERSION; }
void destroy() override {}
IPluginV2* clone() const override
return new FlattenConcat(mFlattenedInputSize.data(), mFlattenedInputSize.size(), mFlattenedOutputSize);
void setPluginNamespace(const char* pluginNamespace) override
mPluginNamespace = pluginNamespace;
const char* getPluginNamespace() const override
return mPluginNamespace.c_str();
private:
template <typename T>
void write(char*& buffer, const T& val) const
*reinterpret_cast<T*>(buffer) = val;
buffer += sizeof(T);
T read(const char*& buffer)
T val = *reinterpret_cast<const T*>(buffer);
return val;
// Number of elements in each plugin input, flattened
std::vector<int> mFlattenedInputSize;
// Number of elements in output, flattened
int mFlattenedOutputSize{0};
// cuBLAS library handle
cublasHandle_t mCublas;
// We're not using TensorRT namespaces in
// this sample, so it's just an empty string
std::string mPluginNamespace = "";
// PluginCreator boilerplate code for FlattenConcat plugin
class FlattenConcatPluginCreator : public IPluginCreator
public:
FlattenConcatPluginCreator()
mFC.nbFields = 0;
mFC.fields = 0;
~FlattenConcatPluginCreator() {}
const char* getPluginName() const override { return FLATTENCONCAT_PLUGIN_NAME; }
const PluginFieldCollection* getFieldNames() override { return &mFC; }
IPluginV2* createPlugin(const char* name, const PluginFieldCollection* fc) override
return new FlattenConcat();
IPluginV2* deserializePlugin(const char* name, const void* serialData, size_t serialLength) override
return new FlattenConcat(serialData, serialLength);
private:
static PluginFieldCollection mFC;
static std::vector<PluginField> mPluginAttributes;
PluginFieldCollection FlattenConcatPluginCreator::mFC{};
std::vector<PluginField> FlattenConcatPluginCreator::mPluginAttributes;
REGISTER_TENSORRT_PLUGIN(FlattenConcatPluginCreator);
int main(int argc, char* argv[])
// Parse command-line arguments.
samplesCommon::parseArgs(args, argc, argv);
initLibNvInferPlugins(&gLogger, "");
auto fileName = locateFile("sample_unpruned_mobilenet_v2.uff");
std::cout << fileName << std::endl;
// changed BATCH SIZE back to 2
const int N = 1;
//const int N = 2;
auto parser = createUffParser();
// BatchStream calibrationStream(CAL_BATCH_SIZE, NB_CAL_BATCHES);
std::cout << "Registering UFF model" << std::endl;
parser->registerInput("Input", DimsCHW(INPUT_C, INPUT_H, INPUT_W), UffInputOrder::kNCHW);
std::cout << "Registered Input" << std::endl;
// parser->registerOutput("ssd_resnet18keras_feature_extractor/model/activation_16/Relu");
parser->registerOutput("NMS");
std::cout << "Registered output NMS" << std::endl;
IHostMemory* trtModelStream{nullptr};
// Int8EntropyCalibrator calibrator(calibrationStream, FIRST_CAL_BATCH, "CalibrationTableSSD");
std::cout << "Creating engine" << std::endl;
ICudaEngine* tmpEngine = loadModelAndCreateEngine(fileName.c_str(), N, parser, trtModelStream);
assert(tmpEngine != nullptr);
assert(trtModelStream != nullptr);
tmpEngine->destroy();
std::cout << "Created engine" << std::endl;
// Read a random sample image.
srand(unsigned(time(nullptr)));
// Available images.
std::vector<std::string> imageList = {"dog.ppm", "image1.ppm"};
std::vector<samplesCommon::PPM<INPUT_C, INPUT_H, INPUT_W>> ppms(N);
assert(ppms.size() <= imageList.size());
std::cout << " Num batches " << N << std::endl;
for (int i = 0; i < N; ++i)
readPPMFile(locateFile(imageList[i%2]), ppms[i]);
vector<float> data(N * INPUT_C * INPUT_H * INPUT_W);
// for (int i = 0, volImg = INPUT_C * INPUT_H * INPUT_W; i < N; ++i)
// for (int c = 0; c < INPUT_C; ++c)
// for (unsigned j = 0, volChl = INPUT_H * INPUT_W; j < volChl; ++j)
// data[i * volImg + c * volChl + j] = (2.0 / 255.0) * float(ppms[i].buffer[j * INPUT_C + c]) - 1.0;
// RGB preprocessing based on keras pipeline
data[i * volImg + 0 * volChl + j] = float(ppms[i].buffer[j * INPUT_C + 0]) - 123.68;
data[i * volImg + 1 * volChl + j] = float(ppms[i].buffer[j * INPUT_C + 1]) - 116.779;
data[i * volImg + 2 * volChl + j] = float(ppms[i].buffer[j * INPUT_C + 2]) - 103.939;
std::cout << " Data Size " << data.size() << std::endl;
// Deserialize the engine.
std::cout << "*** deserializing" << std::endl;
IRuntime* runtime = createInferRuntime(gLogger);
assert(runtime != nullptr);
ICudaEngine* engine = runtime->deserializeCudaEngine(trtModelStream->data(), trtModelStream->size(), nullptr);
assert(engine != nullptr);
trtModelStream->destroy();
IExecutionContext* context = engine->createExecutionContext();
assert(context != nullptr);
//SimpleProfiler profiler("layerTime");
//context->setProfiler(&profiler);
// Host memory for outputs.
vector<float> detectionOut(100000); //(N * detectionOutputParam.keepTopK * 7);
vector<int> keepCount(N);
// Run inference.
doInference(*context, &data[0], &detectionOut[0], &keepCount[0], N);
cout << " KeepCount " << keepCount[0] << "\n";
//cout << profiler;
std::string CLASSES[OUTPUT_CLS_SIZE];
populateClassLabels(CLASSES);
for (int p = 0; p < N; ++p)
for (int i = 0; i < keepCount[p]; ++i)
float* det = &detectionOut[0] + (p * detectionOutputParam.keepTopK + i) * 7;
if (det[2] < visualizeThreshold)
continue;
// Output format for each detection is stored in the below order
// [image_id, label, confidence, xmin, ymin, xmax, ymax]
assert((int) det[1] < OUTPUT_CLS_SIZE);
std::string storeName = CLASSES[(int) det[1]] + "-" + std::to_string(det[2]) + ".ppm";
printf("Detected %s in the image %d (%s) with confidence %f%% and coordinates (%f,%f),(%f,%f).\nResult stored in %s.\n", CLASSES[(int) det[1]].c_str(), int(det[0]), ppms[p].fileName.c_str(), det[2] * 100.f, det[3] * INPUT_W, det[4] * INPUT_H, det[5] * INPUT_W, det[6] * INPUT_H, storeName.c_str());
samplesCommon::writePPMFileWithBBox(storeName, ppms[p], {det[3] * INPUT_W, det[4] * INPUT_H, det[5] * INPUT_W, det[6] * INPUT_H});
// Destroy the engine.
context->destroy();
engine->destroy();
runtime->destroy();
return EXIT_SUCCESS;
