Dear Nvidia, I totally apricate your efforts in offering these models, Thank you for making NVIDIA NIM APIs available through NVIDIA Build as free serverless APIs for development. I spent roughly 4 hours troubleshooting deepseek-ai/deepseek-v4-pro on NVIDIA Build before concluding the issue is not my prompt, browser, workflow, or API usage.
The problem appears to be NVIDIA’s hosted inference endpoint itself.
The model fails even on the trivial prompt: “hi”, returning:
Error — Internal server error
That strongly suggests a hosted NIM / GPU allocation / backend capacity problem, not a user-side problem.
This is especially frustrating because DeepSeek V4 Pro is presented as a showcase model on NVIDIA Build. A user should not have to spend hours debugging a service-side capacity failure with no clear status message, queue notice, degradation warning, or incident banner.
Please investigate:
Whether the DeepSeek V4 Pro endpoint is under-provisioned.
Whether the public Build/NIM endpoint has enough GPU capacity allocated.
Whether the backend is overloaded.
Whether NVIDIA can show a clear service-status message instead of a generic internal server error.
From the user side, this currently looks like insufficient GPU support for the demand placed on the model. If the endpoint is overloaded or degraded, the UI should say that directly.
