Deep Stream App SIGEGV after restart
Hi all,
Problem:
When I stop(NULL) an analytics pipeline , re-create the pipeline and then try to play. I get Process finished with exit code 139 (interrupted by signal 11: SIGSEGV). I want to be able to recreate the pipeline with new sources and new analytics config and then start it again. Ive recreated the issue with the sample app which ive hacked to simulate what im trying to do. Please just change the input URI and point nvinfer to your own classfier files and analytics to your own config.
Log just before crash:
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream-5.1/lib/libnvds_nvdcf.so
gstnvtracker: Batch processing is ON
gstnvtracker: Past frame output is OFF
~~ CLOG[/dvs/git/dirty/git-master_linux/deepstream/sdk/src/utils/nvdcf/src/modules/NvDCF/NvDCF.cpp, NvDCF() @line 670]: !!![WARNING] Can’t open config file (tracker_config_nvDCF_orig.yml). Will go ahead with default values
~~ CLOG[/dvs/git/dirty/git-master_linux/deepstream/sdk/src/utils/nvdcf/src/modules/NvDCF/NvDCF.cpp, NvDCF() @line 682]: !!![WARNING] Invalid low-level config file is provided. Will go ahead with default values
[NvDCF] Initialized
sample.txt (18.0 KB)
Ive attached the sample code i used to reproduce the issue
Deep Stream 5.1
classifier: yolov3
Regards
• DeepStream Version
• TensorRT Version
Hardware Platform: Jetson Xavier AGX devkit
DS: 5.1
Jetpack: 4.5.1
TensorRt: 8.0.1.6-1+cuda10.2
Issue: SIGSEGV after deep stream pipeline re-create and start. The first pipeline play works perfectly, but after stopping the pipeline and re-creating it(new instance of pipeline with new instances of elements) and then starting again i get SIGSEGV just before deserializing yolo
first play log:
[NvDCF] Initialized
WARNING: [TRT]: Using an engine plan file across different models of devices is not recommended and is likely to affect performance or even cause errors.
Deserialize yoloLayerV3 plugin: yolo_83
Deserialize yoloLayerV3 plugin: yolo_95
Deserialize yoloLayerV3 plugin: yolo_107
second play log:
[NvDCF] Initialized
so you can see it happens after [NvDCF] Initialized, this leads me to believe it is to do with running nvinfer on the second instance that causes the crash
How to reproduce the issue: run my adapted version of the analytics sample app which ive attached in the original post. Please insert your own URI and point the nvinfer to your own classifier files
  1. which deepstream sample is your code based on? can your modify code based on deepstream sample?
  2. after test your code, there is an error:
    python3 sample.py file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_720p.mp4
    File “sample.py”, line 449, in
    main(uri)
    File “sample.py”, line 227, in main
    Gst.debug_set_active(True)
    File “/usr/lib/python3/dist-packages/gi/overrides/Gst.py”, line 605, in fake_method
    raise NotInitialized(“Please call Gst.init(argv) before using GStreamer”)
