• Hardware Platform (Jetson / GPU) - Building on x86 deploy on x86 or Jetson
• DeepStream Version - 6.2
• JetPack Version (valid for Jetson only) - NA
• TensorRT Version - NA
• NVIDIA GPU Driver Version (valid for GPU only) - NA
• Issue Type( questions, new requirements, bugs) - NA
I have used Container Builder as part of Graph Composer to build images and they are relatively small, e.g. 6 GB. If you aren’t using Graph Composer and just using Python Bindings or C++ to build Deepstream Graphs can you still use Container Builder to build the images? If not the only other way I see to do it is to use start with the 6.2-base image which is 11 GB out of the box.
