DeepSeek Models - newbie python programmer - calling the wizards out there (you know who you are)
Hello bright minds.
Mr. Newbie here again (I should have made that my username). I’ve been using almost exclusively the Qwen 3.5 coder models for python programming (mostly vibe coding yes I admit it, I do know some basic python so I can follow most of the code, nothing I’m doing is going to be production grade anyways so please be kind on me about vibe coding), its been really great and fast, and after doing so many reptitive asks my KV cache hit ratio is in the 90% using vLLM (@eugr ‘s not so secret implementation) which is AMAZING. It’s always super fast and not super heavy on the RAM. I will admit I actually asked Qwen 3 if there were better model’s for programming in python the way I am and it suggested deepseek. I know there are few new ones out, are there any plans. on adding any of those to say sparkrun or the sparkarea sites, someone out there working on tuning one of those to run awesome? I wish I could I suck I don’t understand how it all works and I tried to copy a recipe from the vLLM I run from Eugr but I passed a bunch of flags without knowing what I’m doing (I told you I’m totally new at all this!!) and it failed to run, I eventually got it to run, but it didn’t seem to work, I mean I could curl to it but it would give me a garbled mess response. (status 200 OK though) open webui couldn’t even pick up the model name it just showed somthing like {model_name} or something similar I dont recall. It simply wouldn’t chat either. So I screwed it up even though it was running.
now sure I could probably have lms fire it up but I’ve kinda been on the vLLM bandwagon. I still don’t understand why lms runs models so fast with less ram than vLLM (I understand vLLM will eat up all of your RAM if you allow it), but usually unless tuned by the experts here. lms consistently uses less RAM and runs models faster, what gives? Isn’t vLLM a more higher tier system specially when using a spark than lms(LMStudio cli on the spark if you didn’t know)?
Anyways that’s not important, i’m just curious if anyone is working to optimize some of the other models out there like deepseek. When you all did Gemma4 WOW that is so insanely fast I was blown away. I kid you not I had an entire Sunday’s worth of questions to it via openwebui never starting a new chat. It kept going giving detailed answers like a champ, it wasn’t until I got into deep electrical engineering where it started to fail and repeat itself, could have been the long chat dont know. Again doesn’t matter. Curious on what models are coming next!
Cheers mates!
Asking LLM about other models is kinda pointless, because their knowledge cutoff date is between 6 months and 2 years in the past (usually), so unless it has an access (through tools) to a good search engine, any answer you will get from it would be pretty outdated.
Right now the only model that runs on Sparks that beats Qwen3.5 series seems to be MiniMax M2.7, but you need two Sparks to run it.
As for vLLM vs. llama.cpp (LM Studio is using llama.cpp under the hood)… llama.cpp is more memory efficient and generally faster in token generation, but prompt processing is much faster in vLLM, so if you do a lot of coding, it becomes important. Also, if you have a cluster, then vLLM/SGLang are your only good options on Spark.
I made this decision tree to help people to decide between vLLM and llama.cpp (and its derivatives, like LM Studio):
As always your wisdom is greatly appreciated. It makes sense. I didn’t realize some of those models were that old. I’m hoping one day I’ll get another spark. Well borrow I should say. I dont even own the one I’m using! Belongs to work! Good to know to stick with Qwen, is there a variant that’s better at python than another as I know there’s a few variants floating around
They are all pretty good with Python - it’s one of the languages LLMs have the most exposure to.
Models themselves are not that old, but the data and datasets used for training are “old.” A cutoff date simply means that all data in the dataset is from before that date. Right now this is not a major issue, because most agentic solutions rely on external knowledge sources (web search, RAG, or other techniques) as part of context engineering. The current focus is more on reasoning and other model capabilities, rather than on the amount of “built‑in” knowledge inside the model.
