DeepSeek-V4.1-Flash-1017 on 4× DGX Spark (China OEM) with no switch: 90 tok/s single-stream, 296 tok/s at 8 streams, 1M-token prefill in under 6 minut
DeepSeek-V4.1-Flash-1017 on 4× DGX Spark (China OEM) with no switch: 90 tok/s single-stream, 296 tok/s at 8 streams, 1M-token prefill in under 6 minutes
TL;DR — Four Super Fusion FusionXpark GB10 boxes (the China-market DGX Spark OEM, DGX OS) cabled into a closed ring with four QSFP56 DACs, no switch. Running DeepSeek-V4.1-Flash-1017 (the official checkpoint, no extra quantization) on SGLang TP4 with the MiaAI-Lab stack. Code decode 90 tok/s single stream, 296 tok/s aggregate at 8 concurrent; cold prefill 3.3–3.5k tok/s up to 256K and 2.9k tok/s at 1M; 1M needle passes; qeval 72/75. Tuning progression, numbers from other public 4-node posts, and the gotchas below.
Why a ring
NVIDIA’s documented topologies are two Sparks back-to-back, three in a triangle, and four or more through a switch. A 200G/400G switch that fits four Sparks (MikroTik CRS812/CRS804 class) costs about as much as a fifth Spark here and was hard to find in stock. Each Spark has two CX-7 ports, so four nodes form a ring with each node directly connected to two neighbours. With the patched NCCL from the MiaAI repo, collectives run over the ring; TP4 inference does one small all-reduce per layer, so it is latency-bound rather than bandwidth-bound, and the extra hop costs very little. The repo author’s own same-hardware comparison put ring vs switch within 2–5% on decode.
Hardware and fabric
Item Value
Nodes 4 × FusionXpark GB10, 128 GB unified memory, 2 TB NVMe, DGX OS
Cost about ¥142k for all four (~US$20k), plus four DAC cables
Fabric ring of 4 × QSFP56 DAC; ib_write_bw 109 Gb/s per link; adjacent-pair NCCL busbw 22.4–22.5 GB/s
GPUDirect RDMA off (the image’s libmlx5 lacks dmabuf registration; NCCL falls back — same in the repo author’s ring logs)
Kernels 6.14 on three nodes, 7.0 on one; no measurable difference
The OEM boxes behaved exactly like reference Sparks: on the default profile we measured C1/C2 within 3% of the repo author’s published ring numbers.
Software stack
  • MiaAI-Lab DeepSeek-v4.1-Flash-DGX-Sparks, TP4 profile, docs/switchless-ring.md NCCL path, local weights on every node (NFS_SHARE=0).
  • Image built from Dockerfile.canary-roce (SGLang dsv4.1 branch + b12x + the repo’s adapters). RoCEnante off (SGLANG_ROCE_ALLREDUCE=0) because the plain ring has no all-to-all RDMA path.
  • Weights: deepseek-ai/DeepSeek-V4.1-Flash-1017 (510,311,045,870 bytes). config.json and tokenizer.json are byte-identical to the 0910 release, so it is a drop-in: change the model directory, restart.
Tuning progression (same ring, same scripts)
Step What changed
A Default profile, 0910 weights
B canary-roce image + only the flags the author documents as bit-identical (PREFILL_SP with EXACT, HC_FUSED, prefill TP split)
C Same as B, 1017 weights
D Full production line minus RoCE: EP_SIZE=1 + b12x_next MoE (deterministic), WO_A_W8, draft-head FP8, draft temperature + block verification, verify cap + router remap, replicated split, Engram prefetch, folded fence, non-EXACT prefill SP + FP8 gathers, fast load
Everything in step D is documented by the author as either bit-identical to the stock path, exact in distribution (speculative-decoding side: every token is still verified by the target model), or a kernel change with qeval unchanged. No weights were re-quantized.
Results
Code decode (decode_window.py, aggregate tok/s):
Concurrency A B C D
1 72 85 89 78 (steady window 90)
2 110 126 127 145
4 141 174 176 189
8 176 269 257 296
Prose / mixed (openai_serving.py, aggregate tok/s): B 35 / 52 / 82 / 114 → D 40 / 61 / 90 / 141 at C1/C2/C4/C8.
Cold prefill (random text, max_tokens=1):
Prompt A B D
32K 3,015 3,145 3,390
128K 2,277 3,070 3,500
256K 1,756 2,663 3,495
~1M 1,270 1,543 2,880 (347.6 s)
Reading a 1M-token document went from 12.7 minutes to 5.8 minutes. Follow-up questions on the same document hit the prefix cache and return in seconds — the KV cache pool is configured for 8M tokens across the four nodes.
Quality (the repo’s qeval.py: 75 auto-scored tasks — code run against hidden asserts, JSON schema checks, numeric math, format constraints — no LLM judge, temperature 0):
A B C D
Score 70/75 71/75 71/75 72/75
Tasks broken vs previous step — 0 0 0
Median single-stream tok/s 52.5 56.7 60.2 69.4
Needles pass at 32K (1 and 4 concurrent), 131K and ~957K tokens (needle at 70% depth). The full boot smoke test (structured output, tool round trip, native vision) passes on step D. Boot time dropped from ~25 minutes to ~3 minutes with fast load at EP1.
How this compares with other public 4-node numbers
Setup Model / engine Single-stream Concurrency peak Prefill
This ring, step D V4.1-Flash-1017 / SGLang code 90, prose 40 296 @ C8 (code) 3.5k @ 128K, 2.9k @ 1M
4 Sparks + HPE 3700M switch V4-Flash-0731 / vLLM 56 (peak 63) 126 @ C5 2.6–3.0k, 2.7k @ 100K
4 Sparks, switched RoCE fabric V4.1-Flash / vLLM code 72 (peak 77), prose 23 214 @ C6 —
MiaAI reference ring, default profile V4.1-Flash 0910 / SGLang 74 225 @ C8 —
Benchmarks, prompts and model versions differ, so read this as orders of magnitude. The point that survives the caveats: the switch was never the bottleneck — the inference engine and the tuning were.
Gotchas we hit
  1. Fast load at EP_SIZE=2 fills unified memory. With EP2 the fast loader pins a full half of the experts per rank: all four nodes went to 118–119 / 119 GB and shard loads slowed from ~3 s to 20–50 s. Use it only with EP_SIZE=1 and TP slicing (each rank then reads a quarter), where it is fine and boots in ~3 minutes.
  2. One node on a cold page cache can time out the others. On a first restart after changing weights, three nodes finished loading from cache and waited at the post-load barrier while the fourth was still reading from disk; the barrier timed out after ~8 minutes. Starting all four cold (or all warm) avoids it.
  3. L2 prefetch does nothing on an NCCL ring — it hooks RoCE collectives; the log says so. Leave it off.
  4. Check the full smoke test after any profile change. The default quick smoke only checks arithmetic; set SMOKE_QUICK=0 once to verify JSON, tool calls and vision.
  5. Moving 510 GB. Downloaded once from ModelScope (~10 MB/s, 16 hours), then rsync over the ring’s direct links at ~1 GB/s per link: 8 minutes per neighbour. Relaying to the far node through a neighbour with ssh -J drops to ~300 MB/s because the middle node re-encrypts; pushing from the far node’s own neighbours is faster.
  6. Shut down cleanly. Stop the serving stack before powering off the nodes; otherwise containers are killed mid-collective (exit 247) and caches get rebuilt on the next start.
Using it
Clients on the LAN and over Tailscale point at one OpenAI-compatible endpoint: DeepSeek Harness (desktop and web), OpenCode, Hermes. Reasoning effort works per request (reasoning_effort), and images work through the same endpoint.
A side experiment with the 0910 weights: the same model inside OpenCode and inside DeepSeek Harness, six tasks with hidden tests and blind grading. Both scored the same on code fixes, refactoring and long-document retrieval; Harness wrote better technical prose; OpenCode finished the suite in a quarter of the time with a fraction of the tokens. Neither reliably answered a yes/no question without starting to edit files, so rules in the agent’s instructions still matter.
Credit
All the heavy lifting is the MiaAI-Lab repository and its patched NCCL ring support. A detailed report with every step, the exact environment line and a few doc suggestions is here: https://github.com/MiaAI-Lab/DeepSeek-v4.1-Flash-DGX-Sparks/issues/59
Questions welcome — happy to run specific prompts or benchmarks on the ring.
