Could you verify public-inference access and model routing for deepseek-ai/deepseek-v4.1-flash on my account?
GET /v1/models returns HTTP 200 and lists the model. However, POST https://integrate.api.nvidia.com/v1/chat/completions ends without an HTTP response or request ID. This happened using both a standard HTTP client and the OpenAI-compatible SDK with retries disabled. NVIDIA Playground also returns “Failed to fetch” / ERR_CONNECTION_CLOSED after about 63–66 seconds.
Tests used only the synthetic prompt “Reply only OK”; one follow-up used max_tokens=262144. The request fields match the documented schema. DNS, TCP, and TLS 1.3 to the API and Playground hosts succeed, and no proxy is configured. The tests ran on Oct 25, 2026, around 06:25–06:33 UTC.
Please confirm whether this account has public inference access to this model and whether its serving/routing is healthy. What additional diagnostic details would help investigate?
No tools, no streaming, no reasoning settings. It just hangs. My client gave up after 30 s without getting any response headers, so there’s no status code and no request ID to share. Earlier tries with 60 to 120 s timeouts ended the same way. GET /v1/models answers in under a second, so basic connectivity is fine.
@se_an thanks for the queue link. I opened it today (Oct 27) and it showed functionStatus ACTIVE with queueDepth 1964, so it does look like requests are just stuck in a very long queue.
A few things I still can’t work out, if someone from NVIDIA can confirm:
Do hosted API calls go through that same queue, or is it only the Playground?
Is there a way to tell a long queue apart from an access problem on my account, without sending more long requests?
If the client drops the connection, does the request keep running and use up credits?
