DeepSeek V4.1 Flash on 8× DGX Spark: TP8/EP8 concurrency results
Sharing results from our SGLang TP8/EP8 + RoCEnante + DSPARK setup over 200GbE RoCE. One shared service, configured for 1M context and 6.6M shared FP8 KV token slots; full-window quality was not tested.
We tested cold inputs from 2K–200K tokens, 1–8 concurrent requests, code/prose workloads and three repetitions.
At 2K input, with a 1,024-token output cap:
Workload Single-request decode tok/s Eight-request batch output tok/s
Code 99.85 286.97
Prose 53.84 174.95
Decode uses a middle-of-response window; batch throughput includes prefill/queuing, so these are different metrics.
The tradeoff: at 100K coding context, four → eight requests added only 6% batch throughput, while median first-token delay rose 64 → 114 seconds. Spare request slots do not prevent long-prefill interference.
972 protocol-qualified observations, zero recorded request errors. An earlier unqualified soak is retained and excluded. These are capped serving tests—not code-quality or completed-agent benchmarks. The measured deployment is validated; a fresh rebuild of the portable recipe is not yet GPU-qualified.
Full recipe, profiles, 60-cell tables, charts and methodology.
Credit to DeepSeek, SGLang, RoCEnante, DSPARK and the upstream Spark contributors.
Thanks for sharing your decode token generation rates. I find your numbers interesting because I observe about the same speeds on my TP4 cluster running DeepSeek-V4.1-Flash-1017 with vLLM using eugr’s spark-vllm-docker recipe.
On my 4 nodes, the weights comfortably fit into memory, but the Engram tables must stay on disk due to lack of memory. (vLLM does that with the launch parameter --engram-config '{{"cpu_offload":false,"table_memory":"disk"}}').
But on your 8-node cluster you should be able to fit the engram tables into memory as well. Would you be able to confirm if your recipe keeps the engram tables in memory or on disk?
If they are on disk, I would be curious to know if you can increase your token generation rates by moving them into memory. And if the engram tables already are in memory, then your confirmation would be an interesting data point to show that keeping engram tables on disk does not negatively impact token generation rates.
I think issue might be in SGLang. Forum popular recipes use VLLM.
Actually the preferred TP=4 is using SGLang with great results.
Thanks for everyone’s feedback so far, trying a few more things around vLLM and engram size testing. Will post when I learn more.
you could give this a shot:
I just added switched TP3, TP4, TP5, TP6, TP7, and TP8 support.
It’s early days (literally just added it now), but for TP8:
Workload Single-request Eight-request Sixteen-request
Code 125.2 ±1.0% 471.3 ±0.8% 804.6 ±0.5%
Prose 110.8 ±0.5% 479.2 ±0.3% 753.6 ±0.7%
max_tokens: 256
The network I’m testing on only has a single cx7 plugged in per spark.
Quick follow-up after trying Chris’s vLLM recipe on the same eight Sparks with DeepSeek-V4.1-Flash-1017. The biggest repeatable C8 gain came from how the requests reached the scheduler.
A packed API call can carry eight prompts, but the engine normally receives them one at a time. It can start work on the first prompt before the other seven arrive. I tested a change that hands the scheduler the whole group at once. With that change, all eight prompts landed in one scheduler step in 10 out of 10 repeats for both workloads.
Using Chris’s exact short prompts, a 256-token cap, disk-backed Engram, and a 2 GHz GPU cap:
C8 packed requests Code tok/s Prose tok/s
Regular admission 424.3 383.0
All eight admitted together 560.4 501.4
These are median whole-batch rates from the same boot. All 960 timed responses matched the local reference text and token IDs exactly. Every all-eight code wave beat Chris’s fastest published C8 code wave. These short runs reached the cap during reasoning; the original 2K SGLang results are a separate workload.
On Engram: in a separate warm C16 test, device residency used about 24 GiB more per rank and was slightly slower than disk on this build. Changing client arrival timing alone also left C16 around 583 code / 558 prose tok/s. I haven’t tested the scheduler change at C16 yet.
Thanks, Chris, for publishing the recipe and raw C8 waves. Do you have per-wave timings or scheduler traces for the 805 / 754 tok/s C16 run? I’d be interested to see how those requests were grouped.
Full results, methodology, and per-wave CSV
Forgot to mentioned, my TP=8 is connected through a MikroTik CRS804, I was able to snag an open box early last month from B&H. Got lucky because the original order I placed in July with Baltic Networks still hasn’t come in.
Small follow-up: I have now tested atomic admission at C16 on the same official 1017 checkpoint, with disk Engram, 10.5 GiB KV per rank and the 2 GHz cap unchanged.
C16, all requests released together Code tok/s Prose tok/s
Regular admission 598.7 564.6
Atomic admission 728.3 689.0
Those are paired, same-boot medians over ten waves per cell. Code 8+8 was slightly higher at 730.1 tok/s. All 1,280 timed outputs matched the reference text and token IDs, and every atomic wave formed the intended groups. We are still below Chris’s published C16 means of about 805/754.
I also tested the normal streaming API with Hermes: all 240 background jobs and 15 foreground jobs passed their tool/state checks. Sixteen active coalesced workers gave 11% more checked-job throughput than regular dispatch at sixteen; eight coalesced workers reached the first usable foreground tool call faster (3.52 s versus 7.65 s). These were short synthetic tool tasks, not a completed coding benchmark.
Updated results, per-wave data, experimental patches and offline checker
Hi @jameslacriox! this is great work!
Getting all eight into one scheduler step 10 out of 10 times, and checking 960 responses against reference token IDs, is a better standard than most of what gets posted here, me included.
How the 805 / 754 C16 run grouped its requests: it didn’t, beyond firing them together. Each wave is a closed loop:
  • It waits until the server is idle, then opens 16 streaming requests at once from a 16-thread pool, with no barrier or batching on the client side.
  • It throws away and repeats any wave that overlapped other traffic.
  • Per request it keeps TTFT, first-token and last-token times, and acceptance from /metrics. At C16 the mean TTFT was about 0.41 s across 48 requests, so they all arrived close together.
  • I didn’t capture scheduler traces. The per-request records for the C16 points also didn’t make it into that manifest, only the point summaries (3 waves, 48 requests). That’s a gap I need to close.
A caveat that applies to both of our numbers: the code and prose cases send every stream the same prompt at temperature 0. That means a shared prefix, decode in lockstep, identical MTP acceptance on every stream, and 16 identical outputs. Every wave in that run produced one output hash. It’s a best case. Since you used my prompts the comparison is fair, but it flatters real traffic. The same bench has “portable” cases that I think are a better basis for comparing stacks: a distinct prompt per stream, reasoning off, and exactly 256 tokens. I’d be glad to line up on those with you.
On metrics:
  • tps is total completion tokens divided by wall time, including TTFT and the tail.
  • The manifest also records the decode-window rate, which was 871 for C16 code.
  • For tuning I mostly trust step_ms and tokens per step. Acceptance follows the generated text, so tok/s moves with the text, while step time stays fairly steady.
Atomic admission: synchronized waves are exactly where it should help most, and real agent traffic arrives staggered. That’s why I also tune with AgentX. It’s SemiAnalysis’s agent-trace replay: one hour at C8 and C16, each point started from a fresh boot with an empty prefix cache. I’d really like to know whether your change holds up there. Your Hermes first-tool-call result (3.52 s vs 7.65 s) suggests it could.
On the remaining gap (728 vs 805): one difference may be that I don’t set a GPU clock cap in my profile, and you’re running at 2 GHz. I’d want to check that before reading much into it.
All of my benching is in the repo: the harness is spark_ds41f/bench.py, every reference run is under manifests/benchmarks/, and tuning runs are under experiments/. I’m very open to opinions on how to bench better. Benching is hard, and threads like this one are how it gets better.
One more heads-up: a release is landing in the next few hours that should change these numbers a lot. It’s probably worth waiting for it before comparing further against the 1030 results.
