1. Introduction
We benchmarked deepseek-ai/DeepSeek-V4-Flash-0731 served through vLLM on a local cluster of 4 NVIDIA DGX Spark machines, measuring prefill and token-generation throughput with llama-benchy. All measurements were taken in a fully offline environment (HF_HUB_OFFLINE=1); both the model weights and the tokenizer come entirely from the local cache.
2. Hardware Architecture
- Nodes: NVIDIA DGX Spark x4 (128 GB unified memory per node, shared between CPU and GPU)
- Interconnect: 200 Gbps HPE 3700M switch
- Cables: QSFP 200G factory cables
Our single-node throughput had been stuck at 40 Gbps and wouldn’t climb any higher. After reading a few forum threads, we learned that after plugging in the interconnect cables, the system needs to be fully powered off and left for a while before the network recovers full-speed communication.
| Metric | Before (old) | After (MTU + cold boot) | Improvement |
| Cold-boot throughput | 157.35 tok/s | 369.61 tok/s | ×2.35 |
| Hot-boot R3 throughput (runs=3) | 340.05 tok/s | 577.10 tok/s | ×1.70 |
3. Software Stack
- Inference engine: vLLM (B12X-optimized stack, vllm-node-b12x container)
- Distribution: 4 nodes, tensor parallel TP=4 (one GPU per node)
- Benchmark tool: llama-benchy 0.4.0
- Tokenizer: deepseek-ai/DeepSeek-V4-Flash-0731 (local HF cache)
- Offline flags: HF_HUB_OFFLINE=1, TRANSFORMERS_OFFLINE=1
vLLM launch configuration (key flags):
vllm serve deepseek-ai/DeepSeek-V4-Flash-0731
–host 0.0.0.0 --port 8000
–tensor-parallel-size 4
–kv-cache-dtype fp8 --block-size 256
–max-model-len auto --max-num-seqs 128 --max-num-batched-tokens 16384
–gpu-memory-utilization 0.85
–enable-prefix-caching
–tokenizer-mode deepseek_v4 --reasoning-parser deepseek_v4
–load-format instanttensor
–moe-backend b12x --linear-backend b12x --attention-backend B12X_MLA_SPARSE
–speculative-config “(method=dspark, num_speculative_tokens=5)”
–nnodes 4 --node-rank 0
–master-addr <MASTER_IP> --master-port <MASTER_PORT>
4. Results
Single-request core metrics:
- Prefill (pp2048): ~2582 t/s
- Decode (tg128): ~55.8 t/s
- Peak decode: ~62.7 t/s
Prefill throughput vs. context depth (single request):
- 4096: 3031 / 8192: 2585 / 16384: 2908 / 32768: 2898 / 65535: 2795 / 100000: 2695 t/s
- Summary: prefill still reaches ~2.7k t/s even at a 100K-token context, degrading only mildly as context grows.
Concurrency scaling (pp2048 + tg128):
- Concurrency 1: prefill total 2582, decode total 55.8, per-req 55.8
- Concurrency 2: prefill total 3055, decode total 90.7, per-req 47.6
- Concurrency 5: prefill total 2968, decode total 125.7, per-req 28.7
- Concurrency 10: prefill total 3044, decode total 110.8, per-req 19.8
- Summary: total throughput peaks around concurrency 5 (~126 t/s); beyond that it drops and per-request latency rises sharply (queuing overhead).
Cached re-prefill (pp2048 @ depth, single request):
- Depth 0: 2582, 4096: 2233, 8192: 1877, 16384: 2103, 32768: 1966, 65535: 1695, 100000: 1552
- Summary: at deep contexts, incremental 2048-token prefill is still slowed by the deep KV cache (consistent with deep-MoE model behavior).
Raw data: results_real.csv
| model | test | t/s (total) | t/s (req) | peak t/s | peak t/s (req) | ttfr (ms) | est_ppt (ms) | e2e_ttft (ms) |
| deepseek-ai/DeepSeek-V4-Flash-0731 | pp2048 (c1) | 2581.91 ± 42.81 | 2581.91 ± 42.81 | 794.41 ± 13.00 | 793.43 ± 13.00 | 794.41 ± 13.00 | ||
| deepseek-ai/DeepSeek-V4-Flash-0731 | tg128 (c1) | 55.77 ± 4.87 | 55.77 ± 4.87 | 62.67 ± 3.68 | 62.67 ± 3.68 | |||
| deepseek-ai/DeepSeek-V4-Flash-0731 | pp2048 (c2) | 3054.76 ± 8.46 | 1529.02 ± 4.26 | 1340.41 ± 3.73 | 1339.43 ± 3.73 | 1340.41 ± 3.73 | ||
| deepseek-ai/DeepSeek-V4-Flash-0731 | tg128 (c2) | 90.72 ± 7.19 | 47.60 ± 3.40 | 106.67 ± 3.09 | 55.17 ± 3.62 | |||
| deepseek-ai/DeepSeek-V4-Flash-0731 | pp2048 (c5) | 2967.66 ± 44.35 | 743.98 ± 75.30 | 2787.41 ± 332.82 | 2786.43 ± 332.82 | 2787.41 ± 332.82 | ||
| deepseek-ai/DeepSeek-V4-Flash-0731 | tg128 (c5) | 125.65 ± 5.77 | 28.67 ± 3.41 | 171.67 ± 7.04 | 40.40 ± 4.81 | |||
| deepseek-ai/DeepSeek-V4-Flash-0731 | pp2048 (c10) | 3044.41 ± 37.15 | 546.46 ± 438.62 | 5383.62 ± 2080.92 | 5382.64 ± 2080.92 | 5383.62 ± 2080.92 | ||
| deepseek-ai/DeepSeek-V4-Flash-0731 | tg128 (c10) | 110.84 ± 5.10 | 19.76 ± 4.74 | 242.67 ± 4.92 | 31.30 ± 2.67 | |||
| deepseek-ai/DeepSeek-V4-Flash-0731 | ctx_pp @ d4096 (c1) | 3031.46 ± 22.51 | 3031.46 ± 22.51 | 1352.55 ± 10.09 | 1351.57 ± 10.09 | 1352.55 ± 10.09 | ||
| deepseek-ai/DeepSeek-V4-Flash-0731 | ctx_tg @ d4096 (c1) | 67.79 ± 5.34 | 67.79 ± 5.34 | 75.00 ± 5.66 | 75.00 ± 5.66 | |||
| deepseek-ai/DeepSeek-V4-Flash-0731 | pp2048 @ d4096 (c1) | 2233.03 ± 5.17 | 2233.03 ± 5.17 | 918.13 ± 2.13 | 917.15 ± 2.13 | 918.13 ± 2.13 | ||
| deepseek-ai/DeepSeek-V4-Flash-0731 | tg128 @ d4096 (c1) | 61.43 ± 2.51 | 61.43 ± 2.51 | 67.33 ± 6.94 | 67.33 ± 6.94 | |||
| deepseek-ai/DeepSeek-V4-Flash-0731 | ctx_pp @ d4096 (c2) | 3060.73 ± 3.09 | 1531.25 ± 1.59 | 2676.58 ± 2.77 | 2675.60 ± 2.77 | 2676.58 ± 2.77 | ||
| deepseek-ai/DeepSeek-V4-Flash-0731 | ctx_tg @ d4096 (c2) | 88.98 ± 5.54 | 49.41 ± 6.16 | 106.67 ± 2.05 | 56.00 ± 5.60 | |||
| deepseek-ai/DeepSeek-V4-Flash-0731 | pp2048 @ d4096 (c2) | 2217.61 ± 13.68 | 1687.11 ± 577.89 | 1376.13 ± 470.83 | 1375.15 ± 470.83 | 1376.13 ± 470.83 | ||
| deepseek-ai/DeepSeek-V4-Flash-0731 | tg128 @ d4096 (c2) | 67.51 ± 9.75 | 41.20 ± 9.37 | 102.00 ± 15.12 | 55.67 ± 5.31 | |||
| deepseek-ai/DeepSeek-V4-Flash-0731 | ctx_pp @ d4096 (c5) | 3056.47 ± 45.89 | 927.25 ± 296.09 | 4856.51 ± 1436.19 | 4855.53 ± 1436.19 | 4856.51 ± 1436.19 | ||
| deepseek-ai/DeepSeek-V4-Flash-0731 | ctx_tg @ d4096 (c5) | 85.55 ± 7.41 | 23.05 ± 6.63 | 167.00 ± 19.51 | 38.33 ± 5.24 | |||
| deepseek-ai/DeepSeek-V4-Flash-0731 | pp2048 @ d4096 (c5) | 2487.18 ± 183.86 | 809.47 ± 559.93 | 3397.63 ± 1311.04 | 3396.65 ± 1311.04 | 3400.18 ± 1306.21 | ||
| deepseek-ai/DeepSeek-V4-Flash-0731 | tg128 @ d4096 (c5) | 86.91 ± 9.02 | 29.23 ± 6.14 | 185.00 ± 4.24 | 42.33 ± 2.98 | |||
| deepseek-ai/DeepSeek-V4-Flash-0731 | ctx_pp @ d4096 (c10) | 3078.18 ± 2.62 | 690.47 ± 781.28 | 9419.05 ± 3741.13 | 9418.07 ± 3741.13 | 9474.27 ± 3785.51 | ||
| deepseek-ai/DeepSeek-V4-Flash-0731 | ctx_tg @ d4096 (c10) | 69.78 ± 1.22 | 15.62 ± 5.24 | 248.67 ± 2.87 | 31.03 ± 5.30 | |||
| deepseek-ai/DeepSeek-V4-Flash-0731 | pp2048 @ d4096 (c10) | 2046.48 ± 453.77 | 428.62 ± 541.36 | 8367.84 ± 3489.43 | 8366.86 ± 3489.43 | 8367.84 ± 3489.43 | ||
| deepseek-ai/DeepSeek-V4-Flash-0731 | tg128 @ d4096 (c10) | 82.68 ± 10.27 | 17.93 ± 4.59 | 250.00 ± 7.79 | 30.97 ± 3.83 | |||
| deepseek-ai/DeepSeek-V4-Flash-0731 | ctx_pp @ d8192 (c1) | 2585.30 ± 610.66 | 2585.30 ± 610.66 | 3397.55 ± 963.13 | 3396.57 ± 963.13 | 3397.55 ± 963.13 | ||
| deepseek-ai/DeepSeek-V4-Flash-0731 | ctx_tg @ d8192 (c1) | 53.20 ± 8.71 | 53.20 ± 8.71 | 60.00 ± 8.52 | 60.00 ± 8.52 | |||
| deepseek-ai/DeepSeek-V4-Flash-0731 | pp2048 @ d8192 (c1) | 1876.75 ± 323.76 | 1876.75 ± 323.76 | 1129.54 ± 216.84 | 1128.56 ± 216.84 | 1129.54 ± 216.84 | ||
| deepseek-ai/DeepSeek-V4-Flash-0731 | tg128 @ d8192 (c1) | 57.18 ± 22.43 | 57.18 ± 22.43 | 67.33 ± 24.46 | 67.33 ± 24.46 | |||
| deepseek-ai/DeepSeek-V4-Flash-0731 | ctx_pp @ d8192 (c2) | 3037.64 ± 2.80 | 2278.39 ± 759.29 | 4046.22 ± 1348.11 | 4045.24 ± 1348.11 | 4046.22 ± 1348.11 | ||
| deepseek-ai/DeepSeek-V4-Flash-0731 | ctx_tg @ d8192 (c2) | 48.77 ± 0.91 | 38.46 ± 13.47 | 111.00 ± 2.94 | 59.83 ± 3.44 | |||
| deepseek-ai/DeepSeek-V4-Flash-0731 | pp2048 @ d8192 (c2) | 2177.72 ± 3.65 | 1650.35 ± 560.87 | 1403.97 ± 476.81 | 1402.99 ± 476.81 | 1403.97 ± 476.81 | ||
| deepseek-ai/DeepSeek-V4-Flash-0731 | tg128 @ d8192 (c2) | 73.48 ± 3.83 | 46.06 ± 9.57 | 119.33 ± 7.72 | 61.83 ± 9.01 | |||
| deepseek-ai/DeepSeek-V4-Flash-0731 | ctx_pp @ d8192 (c5) | 3024.61 ± 1.09 | 1186.85 ± 940.52 | 10060.86 ± 4224.77 | 10059.88 ± 4224.77 | 10060.86 ± 4224.77 | ||
| deepseek-ai/DeepSeek-V4-Flash-0731 | ctx_tg @ d8192 (c5) | 41.76 ± 0.99 | 22.92 ± 10.16 | 175.00 ± 4.32 | 40.00 ± 3.61 | |||
| deepseek-ai/DeepSeek-V4-Flash-0731 | pp2048 @ d8192 (c5) | 2510.89 ± 8.90 | 840.69 ± 676.34 | 3447.89 ± 1256.58 | 3446.91 ± 1256.58 | 3447.89 ± 1256.58 | ||
| deepseek-ai/DeepSeek-V4-Flash-0731 | tg128 @ d8192 (c5) | 86.41 ± 6.08 | 30.57 ± 6.99 | 180.67 ± 20.29 | 42.47 ± 4.72 | |||
| deepseek-ai/DeepSeek-V4-Flash-0731 | ctx_pp @ d8192 (c10) | 3055.29 ± 2.59 | 754.02 ± 792.28 | 17377.70 ± 7710.28 | 17376.72 ± 7710.28 | 17377.70 ± 7710.28 | ||
| deepseek-ai/DeepSeek-V4-Flash-0731 | ctx_tg @ d8192 (c10) | 41.93 ± 0.74 | 11.60 ± 6.60 | 254.33 ± 8.22 | 31.40 ± 3.18 | |||
| deepseek-ai/DeepSeek-V4-Flash-0731 | pp2048 @ d8192 (c10) | 2582.85 ± 38.52 | 493.45 ± 567.61 | 6215.34 ± 1896.64 | 6214.36 ± 1896.64 | 6222.74 ± 1903.52 | ||
| deepseek-ai/DeepSeek-V4-Flash-0731 | tg128 @ d8192 (c10) | 91.46 ± 5.67 | 18.58 ± 3.75 | 238.00 ± 12.36 | 31.70 ± 7.37 | |||
| deepseek-ai/DeepSeek-V4-Flash-0731 | ctx_pp @ d16384 (c1) | 2908.02 ± 4.49 | 2908.02 ± 4.49 | 5635.41 ± 8.70 | 5634.43 ± 8.70 | 5637.14 ± 8.53 | ||
| deepseek-ai/DeepSeek-V4-Flash-0731 | ctx_tg @ d16384 (c1) | 60.44 ± 2.38 | 60.44 ± 2.38 | 68.00 ± 2.45 | 68.00 ± 2.45 | |||
| deepseek-ai/DeepSeek-V4-Flash-0731 | pp2048 @ d16384 (c1) | 2103.13 ± 8.38 | 2103.13 ± 8.38 | 974.78 ± 3.89 | 973.80 ± 3.89 | 976.20 ± 4.17 | ||
| deepseek-ai/DeepSeek-V4-Flash-0731 | tg128 @ d16384 (c1) | 71.92 ± 3.79 | 71.92 ± 3.79 | 77.33 ± 4.64 | 77.33 ± 4.64 | |||
| deepseek-ai/DeepSeek-V4-Flash-0731 | ctx_pp @ d16384 (c2) | 2930.14 ± 3.97 | 2188.95 ± 723.50 | 8404.32 ± 2777.50 | 8403.34 ± 2777.50 | 8405.83 ± 2777.63 | ||
| deepseek-ai/DeepSeek-V4-Flash-0731 | ctx_tg @ d16384 (c2) | 30.04 ± 0.89 | 29.82 ± 14.48 | 102.00 ± 6.98 | 53.67 ± 4.96 | |||
| deepseek-ai/DeepSeek-V4-Flash-0731 | pp2048 @ d16384 (c2) | 2110.27 ± 7.08 | 1582.36 ± 526.28 | 1456.15 ± 483.82 | 1455.17 ± 483.82 | 1457.38 ± 483.20 | ||
| deepseek-ai/DeepSeek-V4-Flash-0731 | tg128 @ d16384 (c2) | 64.86 ± 7.57 | 42.79 ± 9.88 | 105.00 ± 9.42 | 57.67 ± 7.61 | |||
| deepseek-ai/DeepSeek-V4-Flash-0731 | ctx_pp @ d16384 (c5) | 2987.83 ± 3.23 | 1180.53 ± 874.43 | 19417.50 ± 7995.50 | 19416.52 ± 7995.50 | 19767.23 ± 7486.75 | ||
| deepseek-ai/DeepSeek-V4-Flash-0731 | ctx_tg @ d16384 (c5) | 23.25 ± 4.47 | 16.37 ± 10.70 | 149.00 ± 10.61 | 38.16 ± 10.84 | |||
| deepseek-ai/DeepSeek-V4-Flash-0731 | pp2048 @ d16384 (c5) | 2433.86 ± 21.11 | 812.96 ± 647.64 | 3544.75 ± 1286.21 | 3543.77 ± 1286.21 | 3550.99 ± 1288.61 | ||
| deepseek-ai/DeepSeek-V4-Flash-0731 | tg128 @ d16384 (c5) | 71.42 ± 7.65 | 29.77 ± 8.57 | 157.67 ± 13.89 | 43.36 ± 8.25 | |||
| deepseek-ai/DeepSeek-V4-Flash-0731 | ctx_pp @ d16384 (c10) | 3008.92 ± 1.17 | 760.94 ± 747.64 | 33579.14 ± 15427.84 | 33578.16 ± 15427.84 | 33580.33 ± 15428.30 | ||
| deepseek-ai/DeepSeek-V4-Flash-0731 | ctx_tg @ d16384 (c10) | 22.88 ± 0.08 | 8.05 ± 6.57 | 232.67 ± 11.09 | 31.33 ± 3.65 | |||
| deepseek-ai/DeepSeek-V4-Flash-0731 | pp2048 @ d16384 (c10) | 2532.84 ± 14.15 | 478.22 ± 541.02 | 6349.66 ± 1929.53 | 6348.68 ± 1929.53 | 6361.18 ± 1935.49 | ||
| deepseek-ai/DeepSeek-V4-Flash-0731 | tg128 @ d16384 (c10) | 81.90 ± 7.34 | 16.89 ± 4.41 | 210.33 ± 20.37 | 28.77 ± 8.40 | |||
| deepseek-ai/DeepSeek-V4-Flash-0731 | ctx_pp @ d32768 (c1) | 2898.00 ± 6.58 | 2898.00 ± 6.58 | 11308.47 ± 25.70 | 11307.49 ± 25.70 | 11311.24 ± 25.71 | ||
| deepseek-ai/DeepSeek-V4-Flash-0731 | ctx_tg @ d32768 (c1) | 51.47 ± 16.12 | 51.47 ± 16.12 | 59.64 ± 17.01 | 59.64 ± 17.01 | |||
| deepseek-ai/DeepSeek-V4-Flash-0731 | pp2048 @ d32768 (c1) | 1965.65 ± 34.54 | 1965.65 ± 34.54 | 1043.20 ± 18.18 | 1042.22 ± 18.18 | 1046.25 ± 18.22 | ||
| deepseek-ai/DeepSeek-V4-Flash-0731 | tg128 @ d32768 (c1) | 58.57 ± 8.25 | 58.57 ± 8.25 | 65.67 ± 8.99 | 65.67 ± 8.99 | |||
| deepseek-ai/DeepSeek-V4-Flash-0731 | ctx_pp @ d32768 (c2) | 2933.11 ± 2.10 | 1752.99 ± 286.23 | 19206.17 ± 3135.80 | 19205.19 ± 3135.80 | 19208.87 ± 3135.20 | ||
| deepseek-ai/DeepSeek-V4-Flash-0731 | ctx_tg @ d32768 (c2) | 28.75 ± 0.14 | 32.24 ± 17.60 | 107.33 ± 1.70 | 56.33 ± 3.59 | |||
| deepseek-ai/DeepSeek-V4-Flash-0731 | pp2048 @ d32768 (c2) | 1999.76 ± 6.33 | 1476.42 ± 474.14 | 1547.63 ± 496.71 | 1546.65 ± 496.71 | 1550.84 ± 496.71 | ||
| deepseek-ai/DeepSeek-V4-Flash-0731 | tg128 @ d32768 (c2) | 58.02 ± 11.44 | 44.63 ± 9.95 | 90.67 ± 20.50 | 61.06 ± 13.85 | |||
| deepseek-ai/DeepSeek-V4-Flash-0731 | ctx_pp @ d32768 (c5) | 2954.10 ± 1.86 | 1081.22 ± 526.05 | 36818.94 ± 14213.41 | 36817.96 ± 14213.41 | 36822.20 ± 14213.37 | ||
| deepseek-ai/DeepSeek-V4-Flash-0731 | ctx_tg @ d32768 (c5) | 14.44 ± 0.20 | 11.28 ± 11.33 | 166.00 ± 10.98 | 37.73 ± 6.18 | |||
| deepseek-ai/DeepSeek-V4-Flash-0731 | pp2048 @ d32768 (c5) | 2321.18 ± 3.49 | 763.62 ± 595.14 | 3726.07 ± 1338.49 | 3725.09 ± 1338.49 | 3733.32 ± 1340.76 | ||
| deepseek-ai/DeepSeek-V4-Flash-0731 | tg128 @ d32768 (c5) | 72.61 ± 5.31 | 28.79 ± 9.22 | 159.33 ± 16.82 | 38.66 ± 6.12 | |||
| deepseek-ai/DeepSeek-V4-Flash-0731 | ctx_pp @ d32768 (c10) | 2947.84 ± 1.12 | 721.58 ± 516.64 | 64266.36 ± 30611.87 | 64265.38 ± 30611.87 | 64269.34 ± 30611.87 | ||
| deepseek-ai/DeepSeek-V4-Flash-0731 | ctx_tg @ d32768 (c10) | 12.57 ± 0.05 | 5.24 ± 6.55 | 236.67 ± 11.47 | 31.00 ± 4.14 | |||
| deepseek-ai/DeepSeek-V4-Flash-0731 | pp2048 @ d32768 (c10) | 2421.72 ± 6.11 | 444.93 ± 491.37 | 6726.65 ± 2023.43 | 6725.67 ± 2023.43 | 6733.43 ± 2024.09 | ||
| deepseek-ai/DeepSeek-V4-Flash-0731 | tg128 @ d32768 (c10) | 86.93 ± 2.66 | 16.84 ± 3.24 | 220.33 ± 5.25 | 29.90 ± 3.57 | |||
| deepseek-ai/DeepSeek-V4-Flash-0731 | ctx_pp @ d65535 (c1) | 2794.53 ± 0.86 | 2794.53 ± 0.86 | 23452.53 ± 7.20 | 23451.55 ± 7.20 | 23457.41 ± 6.77 | ||
| deepseek-ai/DeepSeek-V4-Flash-0731 | ctx_tg @ d65535 (c1) | 61.29 ± 4.06 | 61.29 ± 4.06 | 70.67 ± 1.70 | 70.67 ± 1.70 | |||
| deepseek-ai/DeepSeek-V4-Flash-0731 | pp2048 @ d65535 (c1) | 1695.06 ± 16.72 | 1695.06 ± 16.72 | 1209.31 ± 11.88 | 1208.33 ± 11.88 | 1213.64 ± 11.34 | ||
| deepseek-ai/DeepSeek-V4-Flash-0731 | tg128 @ d65535 (c1) | 54.23 ± 6.88 | 54.23 ± 6.88 | 42.33 ± 29.78 | 42.33 ± 29.78 | |||
| deepseek-ai/DeepSeek-V4-Flash-0731 | ctx_pp @ d65535 (c2) | 2820.34 ± 1.95 | 1879.56 ± 469.22 | 37186.11 ± 9283.02 | 37185.13 ± 9283.02 | 37190.96 ± 9282.70 | ||
| deepseek-ai/DeepSeek-V4-Flash-0731 | ctx_tg @ d65535 (c2) | 12.07 ± 0.07 | 29.78 ± 23.75 | 108.33 ± 1.25 | 56.17 ± 5.05 | |||
| deepseek-ai/DeepSeek-V4-Flash-0731 | pp2048 @ d65535 (c2) | 1791.43 ± 2.61 | 1290.60 ± 392.87 | 1749.72 ± 531.89 | 1748.74 ± 531.89 | 1754.08 ± 532.14 | ||
| deepseek-ai/DeepSeek-V4-Flash-0731 | tg128 @ d65535 (c2) | 52.21 ± 8.09 | 42.70 ± 15.48 | 84.67 ± 9.43 | 46.33 ± 24.45 | |||
| deepseek-ai/DeepSeek-V4-Flash-0731 | ctx_pp @ d65535 (c5) | 2826.16 ± 2.08 | 1160.92 ± 644.62 | 72442.41 ± 31255.71 | 72441.43 ± 31255.71 | 72805.84 ± 31287.75 | ||
| deepseek-ai/DeepSeek-V4-Flash-0731 | ctx_tg @ d65535 (c5) | 6.61 ± 0.40 | 9.55 ± 13.68 | 168.67 ± 5.73 | 37.93 ± 10.74 | |||
| deepseek-ai/DeepSeek-V4-Flash-0731 | pp2048 @ d65535 (c5) | 2104.02 ± 6.52 | 674.52 ± 505.39 | 4127.99 ± 1455.93 | 4127.01 ± 1455.93 | 4133.37 ± 1456.43 | ||
| deepseek-ai/DeepSeek-V4-Flash-0731 | tg128 @ d65535 (c5) | 68.39 ± 1.97 | 25.23 ± 5.36 | 163.33 ± 15.37 | 39.67 ± 4.13 | |||
| deepseek-ai/DeepSeek-V4-Flash-0731 | ctx_pp @ d65535 (c10) | 2926.87 ± 147.32 | 794.62 ± 609.67 | 124031.94 ± 64530.81 | 124030.96 ± 64530.81 | 124037.10 ± 64531.05 | ||
| deepseek-ai/DeepSeek-V4-Flash-0731 | ctx_tg @ d65535 (c10) | 6.06 ± 0.05 | 3.87 ± 6.60 | 196.00 ± 9.09 | 26.97 ± 8.73 | |||
| deepseek-ai/DeepSeek-V4-Flash-0731 | pp2048 @ d65535 (c10) | 97.13 ± 3.94 | 26.63 ± 20.31 | 116686.34 ± 61492.60 | 116685.36 ± 61492.60 | 117595.07 ± 61516.45 | ||
| deepseek-ai/DeepSeek-V4-Flash-0731 | tg128 @ d65535 (c10) | 5.92 ± 0.53 | 4.88 ± 8.92 | 184.67 ± 8.96 | 26.20 ± 12.88 | |||
| deepseek-ai/DeepSeek-V4-Flash-0731 | ctx_pp @ d100000 (c1) | 2694.64 ± 1.06 | 2694.64 ± 1.06 | 37112.11 ± 14.56 | 37111.13 ± 14.56 | 37118.97 ± 14.14 | ||
| deepseek-ai/DeepSeek-V4-Flash-0731 | ctx_tg @ d100000 (c1) | 56.48 ± 8.97 | 56.48 ± 8.97 | 68.33 ± 12.28 | 68.33 ± 12.28 | |||
| deepseek-ai/DeepSeek-V4-Flash-0731 | pp2048 @ d100000 (c1) | 1551.75 ± 5.33 | 1551.75 ± 5.33 | 1320.79 ± 4.52 | 1319.81 ± 4.52 | 1327.61 ± 5.26 | ||
| deepseek-ai/DeepSeek-V4-Flash-0731 | tg128 @ d100000 (c1) | 51.86 ± 8.23 | 51.86 ± 8.23 | 61.00 ± 7.07 | 61.00 ± 7.07 | |||
| deepseek-ai/DeepSeek-V4-Flash-0731 | ctx_pp @ d100000 (c2) | 2703.00 ± 1.89 | 1900.78 ± 549.11 | 57401.75 ± 16582.32 | 57400.77 ± 16582.32 | 57409.98 ± 16581.90 | ||
| deepseek-ai/DeepSeek-V4-Flash-0731 | ctx_tg @ d100000 (c2) | 7.03 ± 0.10 | 24.53 ± 21.61 | 104.67 ± 6.94 | 55.83 ± 5.15 | |||
| deepseek-ai/DeepSeek-V4-Flash-0731 | pp2048 @ d100000 (c2) | 1690.37 ± 6.79 | 1189.80 ± 340.35 | 1875.64 ± 536.14 | 1874.66 ± 536.14 | 1883.87 ± 539.03 | ||
| deepseek-ai/DeepSeek-V4-Flash-0731 | tg128 @ d100000 (c2) | 56.52 ± 7.76 | 34.95 ± 6.03 | 99.00 ± 13.59 | 52.50 ± 7.78 | |||
| deepseek-ai/DeepSeek-V4-Flash-0731 | ctx_pp @ d100000 (c5) | 2699.53 ± 2.09 | 1170.55 ± 690.74 | 113217.68 ± 51613.09 | 113216.70 ± 51613.09 | 113223.84 ± 51613.90 | ||
| deepseek-ai/DeepSeek-V4-Flash-0731 | ctx_tg @ d100000 (c5) | 4.05 ± 0.29 | 8.05 ± 12.83 | 140.33 ± 15.08 | 33.47 ± 10.20 | |||
| deepseek-ai/DeepSeek-V4-Flash-0731 | pp2048 @ d100000 (c5) | 167.58 ± 53.36 | 285.78 ± 494.25 | 39452.51 ± 28562.29 | 39451.53 ± 28562.29 | 39462.83 ± 28562.56 | ||
| deepseek-ai/DeepSeek-V4-Flash-0731 | tg128 @ d100000 (c5) | 11.05 ± 2.55 | 9.47 ± 9.86 | 131.33 ± 16.74 | 35.85 ± 6.16 | |||
| deepseek-ai/DeepSeek-V4-Flash-0731 | ctx_pp @ d100000 (c10) | 2667.54 ± 5.29 | 745.33 ± 625.07 | 208343.63 ± 106943.22 | 208342.65 ± 106943.22 | 208526.04 ± 106730.92 | ||
| deepseek-ai/DeepSeek-V4-Flash-0731 | ctx_tg @ d100000 (c10) | 3.76 ± 0.01 | 4.12 ± 9.23 | 170.33 ± 19.01 | 22.90 ± 13.84 | |||
| deepseek-ai/DeepSeek-V4-Flash-0731 | pp2048 @ d100000 (c10) | 56.36 ± 2.27 | 112.03 ± 360.81 | 188649.94 ± 112263.69 | 188648.96 ± 112263.69 | 188659.74 ± 112267.79 | ||
| deepseek-ai/DeepSeek-V4-Flash-0731 | tg128 @ d100000 (c10) | 3.42 ± 0.11 | 2.98 ± 6.40 | 118.33 ± 33.56 | 17.30 ± 10.61 |
