DeepSeek-V4-Flash (official FP8) running across 2x DGX Spark — TP=2, MTP, 200K ctx, recipe + numbers
Idk if I need to make a GitHub or something but I got this thing running 8 concurrency with 500k context and it’s fast.
Just got second Spark, was running 122B for some time on single node - DS4F feels much more powerful. And at 40 tps it’s almost the same speed I’m getting from Anthropic these days.
I run summarizing RAG stack using local model (processing raw session logs), so have real-world corpus to evaluate quality (tool benches do not tell the whole story - Qwens 3.6s are good at tools but dumb at general use).
After prompt tuning (telling Claude to rewrite them using DS guidelines) it is definitely better than Qwen 3.5 122B - less hallucinations, follows instructions well, extraction quality is clearly better.
In Claude Code and Agent0 it really feels almost like using Anthropic (especially on Anthropic’s bad days, when they enable INT0-level quants) - tool calls are to the point, synthesis is correct and concise, also the tone feels really good.
IMO, we’ve got new king here, well done, DeepSeek.
how did you get it working correctly? Mine outputs gibberish.
Did not do anything exotic, just followed recipes in this and linked threads. Took half an hour to do with Claude Code.
Definitely no gibberish, agent just returned from 30-minute loop of market research, findings are valid and well-reasoned.
My PSA: if using DSv4 Flash for coding, it helps A LOT to use xhigh/max thinking effort
If you build the community image with @jasl PR, you get an 18% speedup on prefill compared to last week’s version without MTP. (By the way, I’m not sure how to accurately benchmark generation speed with MTP, as llama-bench is showing worse results with it enabled).
results
week ago
model test t/s peak t/s ttfr (ms) est_ppt (ms) e2e_ttft (ms)
deepseek-ai/DeepSeek-V4-Flash pp1000 @ d1000 918.11 ± 100.53 2029.42 ± 238.55 2028.05 ± 238.55 2029.48 ± 238.55
deepseek-ai/DeepSeek-V4-Flash tg128 @ d1000 25.33 ± 0.06 26.00 ± 0.00
deepseek-ai/DeepSeek-V4-Flash pp1000 @ d10000 1142.69 ± 50.89 8468.58 ± 502.26 8467.21 ± 502.26 8468.62 ± 502.26
deepseek-ai/DeepSeek-V4-Flash tg128 @ d10000 23.71 ± 1.20 25.00 ± 0.00
deepseek-ai/DeepSeek-V4-Flash pp1000 @ d15000 1203.59 ± 25.76 11922.26 ± 192.96 11920.89 ± 192.96 11922.31 ± 192.96
deepseek-ai/DeepSeek-V4-Flash tg128 @ d15000 23.61 ± 0.90 25.00 ± 0.00
deepseek-ai/DeepSeek-V4-Flash pp1000 @ d20000 1165.12 ± 43.71 16071.92 ± 657.14 16070.55 ± 657.14 16071.97 ± 657.15
deepseek-ai/DeepSeek-V4-Flash tg128 @ d20000 23.76 ± 0.27 24.33 ± 0.47
deepseek-ai/DeepSeek-V4-Flash pp1000 @ d30000 1123.12 ± 12.54 24705.52 ± 293.46 24704.15 ± 293.46 24705.76 ± 293.30
deepseek-ai/DeepSeek-V4-Flash tg128 @ d30000 23.29 ± 0.04 24.00 ± 0.00
deepseek-ai/DeepSeek-V4-Flash pp1000 @ d40000 1105.78 ± 2.36 33289.92 ± 228.65 33288.55 ± 228.65 33289.96 ± 228.65
deepseek-ai/DeepSeek-V4-Flash tg128 @ d40000 22.62 ± 0.07 23.33 ± 0.47
deepseek-ai/DeepSeek-V4-Flash pp1000 @ d70000 1003.92 ± 39.04 63426.17 ± 2618.50 63424.80 ± 2618.50 63426.22 ± 2618.50
deepseek-ai/DeepSeek-V4-Flash tg128 @ d70000 19.77 ± 0.09 34.20 ± 17.97
deepseek-ai/DeepSeek-V4-Flash pp1000 @ d100000 972.62 ± 14.11 93052.63 ± 1199.68 93051.26 ± 1199.68 93052.67 ± 1199.68
deepseek-ai/DeepSeek-V4-Flash tg128 @ d100000 19.13 ± 0.45 21.33 ± 0.47
deepseek-ai/DeepSeek-V4-Flash pp1000 @ d130000 930.19 ± 20.29 126303.23 ± 3034.33 126301.86 ± 3034.33 126303.29 ± 3034.32
deepseek-ai/DeepSeek-V4-Flash tg128 @ d130000 18.34 ± 0.17 13.67 ± 8.96
today:
deepseek-ai/DeepSeek-V4-Flash pp1000 @ d1000 844.91 ± 250.09 2449.36 ± 931.07 2429.47 ± 931.07 2449.40 ± 931.08
deepseek-ai/DeepSeek-V4-Flash tg128 @ d1000 25.20 ± 0.45 26.00 ± 0.00
deepseek-ai/DeepSeek-V4-Flash pp1000 @ d10000 1320.27 ± 17.46 7588.38 ± 123.31 7568.49 ± 123.31 7588.43 ± 123.31
deepseek-ai/DeepSeek-V4-Flash tg128 @ d10000 24.78 ± 0.05 25.67 ± 0.47
deepseek-ai/DeepSeek-V4-Flash pp1000 @ d15000 1398.10 ± 3.06 10312.15 ± 18.60 10292.26 ± 18.60 10312.20 ± 18.60
deepseek-ai/DeepSeek-V4-Flash tg128 @ d15000 23.78 ± 0.88 25.62 ± 0.88
deepseek-ai/DeepSeek-V4-Flash pp1000 @ d20000 1110.99 ± 216.48 17613.41 ± 2919.23 17593.53 ± 2919.23 17613.46 ± 2919.24
deepseek-ai/DeepSeek-V4-Flash tg128 @ d20000 24.22 ± 0.05 25.00 ± 0.00
deepseek-ai/DeepSeek-V4-Flash pp1000 @ d30000 1421.89 ± 3.20 19472.32 ± 100.78 19452.43 ± 100.78 19472.36 ± 100.78
deepseek-ai/DeepSeek-V4-Flash tg128 @ d30000 23.57 ± 0.03 24.33 ± 0.47
deepseek-ai/DeepSeek-V4-Flash pp1000 @ d40000 1391.89 ± 10.45 26410.38 ± 383.42 26390.49 ± 383.42 26410.43 ± 383.42
deepseek-ai/DeepSeek-V4-Flash tg128 @ d40000 22.83 ± 0.13 24.00 ± 0.00
deepseek-ai/DeepSeek-V4-Flash pp1000 @ d70000 1276.75 ± 7.37 49667.62 ± 404.97 49647.73 ± 404.97 49667.66 ± 404.97
deepseek-ai/DeepSeek-V4-Flash tg128 @ d70000 21.35 ± 0.05 22.67 ± 0.47
deepseek-ai/DeepSeek-V4-Flash pp1000 @ d100000 1186.91 ± 11.80 76158.60 ± 830.15 76138.71 ± 830.15 76158.65 ± 830.15
deepseek-ai/DeepSeek-V4-Flash tg128 @ d100000 19.85 ± 0.07 21.33 ± 0.47
deepseek-ai/DeepSeek-V4-Flash pp1000 @ d130000 1098.38 ± 27.00 106745.53 ± 2722.10 106725.64 ± 2722.10 106745.57 ± 2722.10
deepseek-ai/DeepSeek-V4-Flash tg128 @ d130000 18.47 ± 0.01 13.67 ± 8.96
I get around that for token gen on this one minimax m2.7 quant that feels a lot more intelligent than the cyanwiki awq 4bit quant. Most intelligent quant of this model I have used it was made for a dual strix halo setup but works great on sparks since its just a more intelligently made quant ayysasha/MiniMax-M2.7-AWQ-G32-STRIX-2H · Hugging Face
tried pointing a gemma model to understand this ..even that is very confused .. can someeone pls help summarize what I should do .. just a few concrete pointers would help
am i to git clone this repo ? feat_custom_repos
or which one is latest add-deepseek-v4-flash-recipe
Whats the final build args pls
./build-and-copy.sh --vllm-repo `https://github.com/jasl/vllm.git\` --vllm-ref dda4668b59567416f86956cfe7bbc1eab371a61e --rebuild-vllm -t vllm-node-dsv4 -c or
--rebuild-vllm
and which recipe pls
Here is what I did, there are easier ways but this was straight forward for me and has been working fine. I had help from many on this forum which I have already recognized in earlier posts. This setup works great for me and this is the best model I have used on the Spark to date.
  1. Create a Dockerfile in an empty folder with these two lines in it:
FROM aidendle94/sparkrun-vllm-ds4-gb10:production-ready
WORKDIR /workspace
  1. Build the image using a docker command from the folder with the Dockerfile, after the -t you can name the image whatever you want:
docker build . -t vllm-node-dsv4
At this point you have a compatible vllm image that will work with the community scripts from @eugr_nv.
  1. Copy the image over to your other node, I used the build-and-copy.sh script, after the -t use whatever name you named your image:
./build-and-copy.sh -t vllm-node-dsv4 —no-build -c
Then you can just use the recipe in this thread from @wolttam utilizing the container name you built previously. Do not forget to use the --no-ray parameter because of memory constraints.
This is the configuration that worked
Thank you - I finally have DS4 working! I’ve been using single-node antirez’s custom llama so far, since there was no way to run it on both of the SPARKs I work with… But now that I can, there’s no comparison - 11.5 fps against 40+!.. And that’s with the llama benchy’s Project Gutenberg stuff; on coding (where MTP is very good at predicting tokens) it runs even faster, avg-ing 55-60 in my pi.dev sessions - and with very encouraging (intelligence-wise) result. Put simply - this feels very Sonnet-y.
Only issue so far is that I don’t know how to control effort in pi.dev - settings/thinking level shows “Off (no reasoning)” even though I can clearly see the model is thinking its way through.
A quick llama-benchy result:
$ .venv/bin/llama-benchy --base-url http://localhost:8081/v1 --model deepseek-v4-flash --tokenizer /home/coder/.cache/huggingface/hub/models–deepseek-ai–DeepSeek-V4-Flash/snapshots/6976c7ff1b30a1b2cb7805021b8ba4684041f136/ --pp 2048 --tg 2048 --depth 2048
[transformers] PyTorch was not found. Models won’t be available and only tokenizers, configuration and file/data utilities can be used.
llama-benchy (0.3.7)
Date: 2026-06-07 14:13:46
Benchmarking model: deepseek-v4-flash at http://localhost:8081/v1
Concurrency levels: [1]
Loading text from cache: /home/coder/.cache/llama-benchy/cc6a0b5782734ee3b9069aa3b64cc62c.txt
Total tokens available in text corpus: 142813
Warming up…
Warmup (User only) complete. Delta: 4 tokens (Server: 26, Local: 22)
Warmup (System+Empty) complete. Delta: 4 tokens (Server: 26, Local: 22)
Running coherence test…
Coherence test PASSED.
Measuring latency using mode: api…
Average latency (api): 5.04 ms
Running test: pp=2048, tg=2048, depth=2048, concurrency=1
Run 1/3 (batch size 1)…
Run 2/3 (batch size 1)…
Run 3/3 (batch size 1)…
Printing results in MD format:
deepseek-v4-flash pp2048 @ d2048 1955.99 ± 80.21 2102.73 ± 88.23 2097.70 ± 88.23 2102.73 ± 88.23
deepseek-v4-flash tg2048 @ d2048 38.16 ± 3.48 48.67 ± 2.62
date: 2026-06-07 14:13:46 | latency mode: api
Those are awesome numbers! What recipe did you use?
I had a working docker but thought “hey let’s delete it and try vLLM 0.22 which has all of these DS4 specific fixes!” I trusted my luck too much - didn’t work at all (sparks stuck after loading weights).
Enlighten me please =)
I followed bernisse’s instructions to the letter; meaning…
  • I used aidendle94’s Docker image (copied to both nodes)
  • the recipe from wolttam ( higher up in the thread ).
  • …and launched with --no-ray.
Perfect, I was able to reproduce it as well.
Click to see container build instructions and recipe
DeepSeek V4 Flash — DGX Spark Cluster Setup
Container Build
WORKDIR /workspace
On spark1:
Recipe
recipe_version: "1"
description: DeepSeek V4 Flash FP8 on dual DGX Spark TP=2
model: deepseek-ai/DeepSeek-V4-Flash
container: vllm-node-dsv4:latest
cluster_only: true
mods: []
defaults:
  port: 8000
  host: 0.0.0.0
  tensor_parallel: 2
  pipeline_parallel: 1
  gpu_memory_utilization: 0.85
  block_size: 256
  max_model_len: 200000
  max_num_batched_tokens: 8192
  max_num_seqs: 2
  served_model_name: deepseek-v4-flash
env:
  HF_HOME: /root/.cache/huggingface
  HF_HUB_OFFLINE: "1"
  TRANSFORMERS_OFFLINE: "1"
  VLLM_ALLOW_LONG_MAX_MODEL_LEN: "1"
  VLLM_USE_B12X_MOE: "1"
  VLLM_SPARSE_INDEXER_MAX_LOGITS_MB: "256"
  VLLM_TRITON_MLA_SPARSE: "1"
  TORCH_CUDA_ARCH_LIST: 12.1a
  TRITON_CACHE_DIR: "/root/.triton"
  VLLM_ENGINE_READY_TIMEOUT_S: "7200"
command: |
  vllm serve deepseek-ai/DeepSeek-V4-Flash \
      --served-model-name {served_model_name} \
      --host {host} \
      --port {port} \
      --trust-remote-code \
      --tensor-parallel-size {tensor_parallel} \
      --pipeline-parallel-size {pipeline_parallel} \
      --kv-cache-dtype fp8 \
      --block-size {block_size} \
      --enable-prefix-caching \
      --max-model-len {max_model_len} \
      --max-num-seqs {max_num_seqs} \
      --enable-chunked-prefill \
      --max-num-batched-tokens {max_num_batched_tokens} \
      --gpu-memory-utilization {gpu_memory_utilization} \
      --distributed-executor-backend mp \
      --speculative-config '{{"method":"mtp","num_speculative_tokens":2}}' \
      --tokenizer-mode deepseek_v4 \
      --tool-call-parser deepseek_v4 \
      --enable-auto-tool-choice \
      --reasoning-parser deepseek_v4 \
      --reasoning-config '{{"reasoning_parser":"deepseek_v4","reasoning_start_str":"<think>","reasoning_end_str":"</think>"}}' \
      --default-chat-template-kwargs '{{"thinking":true,"preserve_thinking":true}}' \
      --load-format safetensors \
      --nnodes 2
I tried using instanttensor, but it introduced many issues (not in itself, but adding it to the container downgraded NCCL for some reason, leading to stuck nodes).
I’ve been loving DS4 Flash through DeepSeek API and now it’s running GREAT on my 2xSpark.
Running on 2x Spark with above recipe:
Speed from DeepSeek API:
⚠️ PSA: Prefix caching bug in vLLM V1 engine (PR #44237)
If you’re running with --enable-prefix-caching on the V1 engine (default in recent vLLM), there’s a bug in vllm/v1/core/block_pool.py that causes:
kv_cache_usage_perc only goes up, never down
Linear RSS growth over time
Prefix cache progressively loses effectiveness → more cold starts
Root cause: In _maybe_evict_cached_block(), block.reset_hash() is only called when pop() succeeds. When a hash collision occurs, pop() returns None, reset_hash() is skipped, and the block keeps its stale hash. This causes cache_full_blocks() assertion to fail, preventing new tokens from being cached.
Fix: PR #44237 — move block.reset_hash() outside the conditional so it always executes. Single-file patch, only affects vllm/v1/core/block_pool.py.
Link: [Bugfix] Fix linear host RSS growth under sustained classification load with prefix caching (V1) by Oxygen56 · Pull Request #44237 · vllm-project/vllm · GitHub
Workaround: Manually patch the file in your Docker container (or mount with -v). No other dependencies.
I can confirm the symptom. Cache keeps accumulating until 99%, and vLLM struggles until it’s cleared. After patching the image with PR #44237, the cache clears immediately after request completion. DSv4F is running much better at higher context now.
Thank you @aidendle94 for making DSv4F run great on Spark. It is now my main model, even without vision.
Thanks for the PSA!
Confirm the sympoms - KV cache ratcheting up, near-zero prompt cache hits. Did not crash, but after an hour or so performance severely degraded.
Patch definitely helped, now back to normal.
Which VLLM image are you using? I have not seen this with the one I am using from @aidendle94. I am wondering if I should recompile it with this PR.
Could I please ask you to upload the patched file so I can replace it inside the image?
Here you go: kanthai/spark-vllm-dsv4f-aidendle94:production-ready-pr44237
It’s on docker hub now. The patched file is already in the image.
