deepstream 1.5 sample on TX2 always end up core dump
My Tx2 is equipped with jetpack3.3 and deepstream 1.5. The tool nvgstiva-app always gave me a core dump like:
nvidia@tegra-ubuntu:~$ nvgstiva-app -c configs/PGIE-FP16-CarType-CarMake-CarColor.txt
------------> 0,128,128:1,0,0:2,0,0:3,0,0:4,0,0:5,0,0: -----------------
------------> 0,1920,1080:1,100,1080:2,1920,1080:3,1920,1080:4,0,0:5,0,0: -----------------
		CLASS_IDS TO OEPRATE ON gie_id(0) : 2:
------------> 0,128,128:1,0,0:2,0,0:3,0,0:4,0,0:5,0,0:6,0,0:7,0,0:8,0,0:9,0,0:10,0,0:11,0,0: -----------------
------------> 0,1920,1080:1,100,1080:2,1920,1080:3,1920,1080:4,0,0:5,0,0:6,0,0:7,0,0:8,0,0:9,0,0:10,0,0:11,0,0: -----------------
------------> 0,128,128:1,0,0:2,0,0:3,0,0:4,0,0:5,0,0:6,0,0:7,0,0:8,0,0:9,0,0:10,0,0:11,0,0:12,0,0:13,0,0:14,0,0:15,0,0:16,128,1920:17,0,100:18,0,1920:19,0,1920:20,0,0:21,0,0:22,0,0:23,0,0: -----------------
------------> 0,1920,1080:1,100,1080:2,1920,1080:3,1920,1080:4,0,0:5,0,0:6,0,0:7,0,0:8,0,0:9,0,0:10,0,0:11,0,0:12,0,0:13,0,0:14,0,0:15,0,0:16,1080,1:17,1080,1:18,1080,4:19,1080,4:20,0,0:21,0,0:22,0,0:23,0,0: -----------------
------------> 0,0:1,0:2,0: -----------------
------------> 0,0,0:1,0,0:2,0,0: -----------------
------------> 0,1920,1080:1,100,1080:2,1920,1080: -----------------
------------> 0,0.200000,0.100000,3,0:1,0.200000,0.100000,3,0:2,0.200000,0.100000,3,0: -----------------
CPU usage measurement requires governor to be set to performance------------> 0,0.0,1.0,0.0:1,0.0,1.0,1.0:2,0.0,0.0,1.0:3,1.0,1.0,0.0 -----------------
Deploy Name : /home/nvidia/Model/IVASecondary_Make_V1/deploy.prototxt
Model Name : /home/nvidia/Model/IVASecondary_Make_V1/snapshot_iter_6240.caffemodel
Model Cache Name : /home/nvidia/Model/IVASecondary_Make_V1/snapshot_iter_6240.caffemodel_b2_fp16.cache
Batch_Size 2
>>> Using Cached GIE model /home/nvidia/Model/IVASecondary_Make_V1/snapshot_iter_6240.caffemodel_b2_fp16.cache crypto flags(0)
I just can’t find anything useful from the output above. Any idea?
Luckily,I found the answer here:
https://devtalk.nvidia.com/default/topic/1042842/deepstream-sdk-on-jetson/segmentation-error/post/5291549/#5291549
Hope this will help you and save your time.
Glad to hear you have it working. DS 4.0 would be released soon, please make sure to you move to it then.
hello
I am getting same erroe, after clearing all caches the issue still happening. any idea what may be the cause?
I followe this recomendation
https://devtalk.nvidia.com/default/topic/1042842/deepstream-sdk/segmentation-error/post/5293224/#5293224
it did not work.
Please create a new question with all the info about your issue.
