hi
i try to run in different resolution except demo in 720p
1080p or 640p failed
480p Success
my config like this
Copyright (c) 2018 NVIDIA Corporation. All rights reserved.
NVIDIA Corporation and its licensors retain all intellectual property
and proprietary rights in and to this software, related documentation
and any modifications thereto. Any use, reproduction, disclosure or
distribution of this software and related documentation without an express
license agreement from NVIDIA Corporation is strictly prohibited.
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
flow-original-resolution=1
#gie-kitti-output-dir=streamscl
[tiled-display]
enable=1
rows=1
columns=1
width=1280
height=720
gpu-id=0
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI
type=3
uri=file://…/…/streams/1-480.mp4
num-sources=1
gpu-id=0
[sink0]
enable=0
#Type - 1=FakeSink 2=EglSink 3=File
type=2
sync=1
source-id=0
gpu-id=0
[sink1]
enable=1
type=3
#1=mp4 2=mkv
container=1
#1=h264 2=h265 3=mpeg4
only SW mpeg4 is supported right now.
codec=3
sync=1
bitrate=2000000
output-file=out.mp4
source-id=0
[osd]
enable=1
gpu-id=0
osd-mode=1
border-width=1
text-size=15
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Arial
show-clock=1
clock-x-offset=5
clock-y-offset=5
clock-text-size=16
clock-color=1;0;0;1
[primary-gie]
enable=1
gpu-id=0
net-scale-factor=0.0039215697906911373
model-file=…/…/models/Primary_Detector/resnet10.caffemodel
proto-file=…/…/models/Primary_Detector/resnet10.prototxt
model-cache=…/…/models/Primary_Detector/resnet10.caffemodel_b4_int8.cache
labelfile-path=…/…/models/Primary_Detector/labels.txt
int8-calib-file=…/…/models/Primary_Detector/cal_trt4.bin
net-stride=16
batch-size=4
0=FP32, 1=INT8, 2=FP16 mode
network-mode=1
bbox-border-color0=1;0;0;1
bbox-border-color1=0;1;1;1
bbox-border-color2=0;0;1;1
bbox-border-color3=0;1;0;1
num-classes=4
class-thresholds=0.2;0.2;0.1;0.2
class-eps=0.2;0.2;0.2;0.2
class-group-thresholds=1;1;1;1
roi-top-offset=0;0;0;0
roi-bottom-offset=0;0;0;0
detected-min-w=0;0;0;0
detected-min-h=0;0;0;0
detected-max-w=1280;1280;1280;1280
detected-max-h=720;720;720;720
interval=0
gie-unique-id=1
parse-func=4
output-bbox-name=conv2d_bbox
output-blob-names=conv2d_cov
parser-bbox-norm=35.0;35.0
#config-file=config_infer_resnet.txt
[tracker]
enable=1
tracker-width=640
tracker-height=368
gpu-id=0
[secondary-gie0]
enable=1
net-scale-factor=1
model-file=…/…/models/Secondary_VehicleTypes/resnet18.caffemodel
proto-file=…/…/models/Secondary_VehicleTypes/resnet18.prototxt
model-cache=…/…/models/Secondary_VehicleTypes/resnet18.caffemodel_b16_int8.cache
mean-file=…/…/models/Secondary_VehicleTypes/mean.ppm
labelfile-path=…/…/models/Secondary_VehicleTypes/labels.txt
int8-calib-file=…/…/models/Secondary_VehicleTypes/cal_trt4.bin
gpu-id=0
batch-size=16
num-classes=6
network-mode=1
detected-min-w=128
detected-min-h=128
detected-max-w=1280
detected-max-h=720
model-color-format=1
gie-unique-id=4
operate-on-gie-id=1
operate-on-class-ids=0;
is-classifier=1
output-blob-names=predictions/Softmax
classifier-async-mode=1
classifier-threshold=0.51
[secondary-gie1]
enable=1
net-scale-factor=1
model-file=…/…/models/Secondary_CarColor/resnet18.caffemodel
proto-file=…/…/models/Secondary_CarColor/resnet18.prototxt
model-cache=…/…/models/Secondary_CarColor/resnet18.caffemodel_b16_int8.cache
mean-file=…/…/models/Secondary_CarColor/mean.ppm
labelfile-path=…/…/models/Secondary_CarColor/labels.txt
batch-size=16
network-mode=1
detected-min-w=128
detected-min-h=128
detected-max-w=1280
detected-max-h=720
num-classes=12
gpu-id=0
gie-unique-id=5
operate-on-gie-id=1
is-classifier=1
[secondary-gie2]
enable=1
net-scale-factor=1
model-file=…/…/models/Secondary_CarMake/resnet18.caffemodel
proto-file=…/…/models/Secondary_CarMake/resnet18.prototxt
model-cache=…/…/models/Secondary_CarMake/resnet18.caffemodel_b16_int8.cache
mean-file=…/…/models/Secondary_CarMake/mean.ppm
labelfile-path=…/…/models/Secondary_CarMake/labels.txt
int8-calib-file=…/…/models/Secondary_CarMake/cal_trt4.bin
batch-size=16
network-mode=1
num-classes=24
detected-min-w=128
detected-min-h=128
detected-max-w=1280
detected-max-h=720
gpu-id=0
gie-unique-id=6
operate-on-gie-id=1
is-classifier=1
[tests]
file-loop=0
