DeepStream 3.0-18.11 on GTX 10x
Wondering if the DeepStream container (e.g. sudo docker pull nvcr.io/nvidia/deepstream:3.0-18.11 ) examples work on GTX 10x . Thanks.
It work on Geforce cards, just go ahead use it, and report bugs if you met specific issues.
Thanks that is helpful. Looks like all the 3 examples require UI access. Is there any sample code / example that does not require UI access ?
you can use sink type 1 FakeSink and 3 File for output.
