Ok, take your time.
I think when you use the postprocess in your env, there are some problems with the memory. So your label shows some error code.
Hi, I have just tested on jetson nano and it work properly with default config and my custom model. Maybe problem only appear on my jetson NX.
Yeah, maybe. We have jetson NX with the same env. It works well. You can try to flash the JP version on your NX device if it is convenient. Thanks
Thank you. I will try to flash my NX when I get the device.
Do you still need support for this topic? Or should we close it? Thanks.
